[pdal-commits] [PDAL/PDAL] 091baa: Eliminate pragmas. (#2094)
GitHub noreply at github.com
Mon Jul 23 07:29:42 PDT 2018
  Branch: refs/heads/issue-2087
  Home:   https://github.com/PDAL/PDAL
  Commit: 091baaa05bd4b93b4187fe081e014ac40c3016b0
      https://github.com/PDAL/PDAL/commit/091baaa05bd4b93b4187fe081e014ac40c3016b0
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2018-07-20 (Fri, 20 Jul 2018)
  Changed paths:
    M pdal/PointView.hpp
    M pdal/util/Uuid.hpp
  Log Message:
  Commit: 6f257118f625e23a7771ba913f38296b7ad8bdea
      https://github.com/PDAL/PDAL/commit/6f257118f625e23a7771ba913f38296b7ad8bdea
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    M filters/DEMFilter.hpp
    M io/GDALReader.cpp
    M io/GDALReader.hpp
    M test/unit/io/GDALReaderTest.cpp
  Log Message:
  make readers.gdal streamable (#2096)
* make readers.gdal streamable
* add tiff/tif/jpeg/jpg to readers.gdal identification
* modifications as requested by review
  Commit: 016e970ece57d4f1b1aae814acffee5ea210bbfa
      https://github.com/PDAL/PDAL/commit/016e970ece57d4f1b1aae814acffee5ea210bbfa
  Date:   2018-07-23 (Mon, 23 Jul 2018)
  Changed paths:
    M io/GDALGrid.hpp
    M test/unit/io/GDALWriterTest.cpp
  Log Message:
  Use correct math to compute vertical index in GDALGrid. (#2097)
* Fix calculation of verticalIndex().
* Export GDAL Grid for testing.
  Commit: a5f1b7ceecc4f7213a1527b8231425818a32067c
      https://github.com/PDAL/PDAL/commit/a5f1b7ceecc4f7213a1527b8231425818a32067c
  Changed paths:
    M io/GDALReader.cpp
    M io/GDALReader.hpp
    M io/GDALWriter.cpp
    M io/GDALWriter.hpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into issue-2087
Small updates.
Compare: https://github.com/PDAL/PDAL/compare/f69bbe174037...a5f1b7ceecc4
      **NOTE:** This service been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
      Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits mailing list
