[pdal-commits] [PDAL/PDAL] 08fb52: add CITATION file (#2063)
GitHub noreply at github.com
Mon Jul 23 14:22:49 PDT 2018
  Branch: refs/heads/issue-2065
  Home:   https://github.com/PDAL/PDAL
  Commit: 08fb529e63db71491e530f3f1b737bf2b2ffe612
      https://github.com/PDAL/PDAL/commit/08fb529e63db71491e530f3f1b737bf2b2ffe612
  Author: Howard Butler <howard at hobu.co>
  Date:   2018-06-22 (Fri, 22 Jun 2018)
  Changed paths:
    A CITATION
  Log Message:
  Commit: 9eafd35297c24fc852fc71d23d01bbc045302038
      https://github.com/PDAL/PDAL/commit/9eafd35297c24fc852fc71d23d01bbc045302038
  Author: chambbj <brad.chambers at gmail.com>
  Date:   2018-06-26 (Tue, 26 Jun 2018)
  Changed paths:
    M filters/PMFFilter.cpp
    M filters/SMRFilter.cpp
    M pdal/Segmentation.cpp
    M pdal/Segmentation.hpp
    M test/unit/CMakeLists.txt
    M test/unit/OldPCLBlockTest.cpp
    A test/unit/filters/PMFFilterTest.cpp
    A test/unit/filters/SMRFilterTest.cpp
  Log Message:
  Allow more flexible processing of return groups in ground filters (#2055)
* Allow more flexible processing of return groups in ground filters
Continue to default to processing last and only returns, but allow users to
specify any combination of "last", "first", "intermediate", and "only".
* Update the tests to handle returns as a StringList in filters.pmf
* Remove debug and unused variable
* Simplified logic
* Some error checking on returns
* Add simple tests for returns option
* Add tests for SMRF too
  Commit: 76bdabdb6a47e3395397b7d9a56f239ff5e44fd0
      https://github.com/PDAL/PDAL/commit/76bdabdb6a47e3395397b7d9a56f239ff5e44fd0
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Changed paths:
    M filters/OverlayFilter.cpp
    M pdal/Streamable.cpp
    M test/unit/StreamingTest.cpp
    M test/unit/apps/pcpipelineTestJSON.cpp
  Log Message:
  Always emit a spatialReferenceChanged when processing starts (#2060)
* Make sure we emit a single spatialReferenceChanged() when processing
points with no SRS.
* Fix overlay filter to deal with SRS change to empty SRS.
Add more info to failed pipeline test message.
  Commit: a3135db87664265ad6ded32c3b285875929ad375
      https://github.com/PDAL/PDAL/commit/a3135db87664265ad6ded32c3b285875929ad375
  Date:   2018-06-27 (Wed, 27 Jun 2018)
  Changed paths:
    M pdal/StageExtensions.cpp
    M pdal/StageExtensions.hpp
  Log Message:
  Use correct order to traversing stages when streaming (#2067)
* Process points from left to right when streaming.
Close #2023
* PDAL_DLL StageExtensions::set
* Make sure output string is assigned.
  Commit: 76b69c82b7b961d3be162ba2b5b31f0f3131e326
      https://github.com/PDAL/PDAL/commit/76b69c82b7b961d3be162ba2b5b31f0f3131e326
  Date:   2018-07-02 (Mon, 02 Jul 2018)
  Changed paths:
    M pdal/util/Utils.hpp
    M plugins/greyhound/io/GreyhoundReader.cpp
    M plugins/mbio/io/MbError.cpp
    M plugins/pcl/CMakeLists.txt
    M vendor/arbiter/arbiter.cpp
  Log Message:
  Warning updates and such for OSX High Sierra compiler. (#2058)
  Commit: d7c2352cf0a6d17e648236673fbae68d0bfd3708
      https://github.com/PDAL/PDAL/commit/d7c2352cf0a6d17e648236673fbae68d0bfd3708
  Changed paths:
    M io/TextWriter.cpp
    M io/TextWriter.hpp
    M test/unit/io/TextWriterTest.cpp
  Log Message:
  Support streaming in writers.text (#2066)
* Rearrangement prior to streaming support.
* Add streaming support for text writer.
* Fix messed-up separator in GeoJSON code.
  Commit: 1d159082b2115a014a2d720d6fbc78307be51335
      https://github.com/PDAL/PDAL/commit/1d159082b2115a014a2d720d6fbc78307be51335
  Date:   2018-07-04 (Wed, 04 Jul 2018)
  Changed paths:
    M CMakeLists.txt
    M cmake/examples/hobu-config.sh
    R cmake/modules/FindHexer.cmake
    A filters/HexBinFilter.cpp
    A filters/HexBinFilter.hpp
    A filters/private/hexer/HexGrid.cpp
    A filters/private/hexer/HexGrid.hpp
    A filters/private/hexer/HexInfo.hpp
    A filters/private/hexer/HexIter.hpp
    A filters/private/hexer/Hexagon.cpp
    A filters/private/hexer/Hexagon.hpp
    A filters/private/hexer/Mathpair.hpp
    A filters/private/hexer/Path.cpp
    A filters/private/hexer/Path.hpp
    A filters/private/hexer/Processor.cpp
    A filters/private/hexer/Processor.hpp
    A filters/private/hexer/Segment.cpp
    A filters/private/hexer/Segment.hpp
    A filters/private/hexer/exception.hpp
    A kernels/DensityKernel.cpp
    A kernels/DensityKernel.hpp
    A kernels/private/density/OGR.cpp
    A kernels/private/density/OGR.hpp
    M plugins/CMakeLists.txt
    A plugins/faux/CMakeLists.txt
    A plugins/faux/kernel/FauxPluginKernel.cpp
    A plugins/faux/kernel/FauxPluginKernel.hpp
    R plugins/hexbin/CMakeLists.txt
    R plugins/hexbin/filters/HexBin.cpp
    R plugins/hexbin/filters/HexBin.hpp
    R plugins/hexbin/kernel/DensityKernel.cpp
    R plugins/hexbin/kernel/DensityKernel.hpp
    R plugins/hexbin/kernel/OGR.cpp
    R plugins/hexbin/kernel/OGR.hpp
    R plugins/hexbin/test/HexbinFilterTest.cpp
    M test/unit/apps/AppPluginTest.cpp
    A test/unit/filters/HexbinFilterTest.cpp
  Log Message:
  Integrate hexer code into PDAL (#2073)
* include hexer source tree in PDAL (now relicensed as BSD) #2001
* Remove hexbin plugin.
Add hexbin test.
* Fix app test.
* Add faux plugin to make plugin kernel test work.
* Remove stuff from hexer that was necessary when it was its own package.
* Revert version info
Close #2001
  Commit: 05964b72ae664d7ed0f0514ba90a5a6ddb211455
      https://github.com/PDAL/PDAL/commit/05964b72ae664d7ed0f0514ba90a5a6ddb211455
  Date:   2018-07-05 (Thu, 05 Jul 2018)
  Changed paths:
  Log Message:
  Fix SRS assignment in streaming. (#2070)
Close #2069
  Commit: 4d8cdf0951413e14ccf7d81a8acf3a4227f5f405
      https://github.com/PDAL/PDAL/commit/4d8cdf0951413e14ccf7d81a8acf3a4227f5f405
  Changed paths:
    M io/LasHeader.cpp
  Log Message:
  Make more accurate error message for point type/WKT flag mismatch. (#2075)
Close #2059
  Commit: ab44c6fb09e73ac36be9e3d27031f89f16818dfe
      https://github.com/PDAL/PDAL/commit/ab44c6fb09e73ac36be9e3d27031f89f16818dfe
  Author: Jaime Soto <jsoto at simverge.com>
  Date:   2018-07-06 (Fri, 06 Jul 2018)
  Changed paths:
    M pdal/pdal_config.hpp
  Log Message:
  Remove pdal::Config::lazPerfEnabled() declaration (#2080)
This function has been replaced by pdal::Config::hasFeature() with the
pdal::Config::LAZPERF argument. See comment in #2078.
  Commit: 643b03442d6c1a9fa8dc04c776ca56f8689475a4
      https://github.com/PDAL/PDAL/commit/643b03442d6c1a9fa8dc04c776ca56f8689475a4
  Date:   2018-07-09 (Mon, 09 Jul 2018)
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Add exclusion for header files of unbuilt compression schemes.
  Commit: d77f671eb3e2820f18e6bc8e2c58197033085dce
      https://github.com/PDAL/PDAL/commit/d77f671eb3e2820f18e6bc8e2c58197033085dce
  Date:   2018-07-10 (Tue, 10 Jul 2018)
  Changed paths:
    M pdal/ArtifactManager.hpp
  Log Message:
  Delete copy assignment/ctor from ArtifactManager. (#2084)
Close #2082
  Commit: d06134de3b22b650a770614fee401cd609cc453f
      https://github.com/PDAL/PDAL/commit/d06134de3b22b650a770614fee401cd609cc453f
  Changed paths:
    M filters/ReprojectionFilter.cpp
    M filters/ReprojectionFilter.hpp
    M test/unit/filters/ReprojectionFilterTest.cpp
  Log Message:
  Handle changes in SRS with spatialReferenceChanged(). (#2081)
  Commit: 66936c950b3149926daf7886c69948a4a451b26b
      https://github.com/PDAL/PDAL/commit/66936c950b3149926daf7886c69948a4a451b26b
  Changed paths:
    A filters/NNDistanceFilter.cpp
    A filters/NNDistanceFilter.hpp
    M pdal/Dimension.json
    A test/unit/filters/NNDistanceTest.cpp
  Log Message:
  Add avg option to NNdistance filter. (#2076)
* Add nn distance dimension.
* Add general nearest neighbor distance filter.
* Migrate KDistanceFilter to more generic NNDistanceFilter.
Close #2071
* Full test.
* Add some test comments.
* Use distances, not square distances when computing averages.
* Remove unnecessary braces.
  Commit: 004a8480adff030cdadb67664d196da4132492b9
      https://github.com/PDAL/PDAL/commit/004a8480adff030cdadb67664d196da4132492b9
  Date:   2018-07-11 (Wed, 11 Jul 2018)
  Changed paths:
    M io/GDALWriter.cpp
    M test/unit/io/GDALWriterTest.cpp
  Log Message:
  Reset GDAL grid when we start a file. (#2079)
Close #2074
  Commit: 2dd6dfbeecd4366f30cb006005f9768813e747ee
      https://github.com/PDAL/PDAL/commit/2dd6dfbeecd4366f30cb006005f9768813e747ee
  Changed paths:
    M CMakeLists.txt
    M cmake/modules/FindZSTD.cmake
  Log Message:
  Fix FindZST.cmake (#2085)
* Fix FindZST.cmake.
Use proper variable for ZSTD library.
Close #2036
* Remove repetitive function.
  Commit: 6469b51d60ffae0149589f78c2bf762546d434ca
      https://github.com/PDAL/PDAL/commit/6469b51d60ffae0149589f78c2bf762546d434ca
  Date:   2018-07-16 (Mon, 16 Jul 2018)
  Changed paths:
    M pdal/PipelineReaderJSON.hpp
  Log Message:
  Make parsePipeline private.
  Commit: 973ceafb1589037ce9d073ac296fdc86bfe13ca5
      https://github.com/PDAL/PDAL/commit/973ceafb1589037ce9d073ac296fdc86bfe13ca5
  Changed paths:
    M pdal/Reader.hpp
  Log Message:
  Handle count option on readers when streaming. (#2088)
* Handle count option on readers when streaming.
* Parenthesize max for Windows.
* And min...
  Commit: 562980934836a83a24f3e3b43cc43f4a27d8b2fb
      https://github.com/PDAL/PDAL/commit/562980934836a83a24f3e3b43cc43f4a27d8b2fb
  Author: Eli L Adam <elil at users.noreply.github.com>
  Date:   2018-07-17 (Tue, 17 Jul 2018)
  Changed paths:
    M doc/stages/filters.poisson.rst
  Log Message:
  Correct trailing comma typos (#2089)
I think that I'm in the correct location now.
Are these commas typos?
  Commit: 380e186e0d62811bea416ec2119c7209bc193841
      https://github.com/PDAL/PDAL/commit/380e186e0d62811bea416ec2119c7209bc193841
  Changed paths:
    A doc/stages/filters.dem.rst
    M doc/stages/filters.rst
    A filters/DEMFilter.cpp
    A filters/DEMFilter.hpp
  Log Message:
  add filters.dem for filtering data given a GDAL-readable data source (#2090)
  Commit: 768077a1f3f541ca1563a0284d5e1cc7c3529ea4
      https://github.com/PDAL/PDAL/commit/768077a1f3f541ca1563a0284d5e1cc7c3529ea4
  Author: Brandon Barker <contact at brandonbarker.me>
  Changed paths:
    M scripts/docker/ubuntu/Dockerfile
  Log Message:
  Purging Numpy breaks numpy support (#2091)
numyp should not be purged, when it is removed the 'npy' file extension no longer works for pdal.
  Commit: ca898758fc494561f2815a889c793ff51976beab
      https://github.com/PDAL/PDAL/commit/ca898758fc494561f2815a889c793ff51976beab
  Date:   2018-07-18 (Wed, 18 Jul 2018)
  Changed paths:
    A cmake/examples/hobu-conda-win64.bat
    R cmake/modules/BuildOSGeo4W.cmake
    M cmake/modules/FindGDAL.cmake
    M cmake/modules/FindGEOS.cmake
    M cmake/modules/FindGeoTIFF.cmake
    M cmake/modules/FindLASzip.cmake
    R cmake/modules/FindP2G.cmake
    M cmake/modules/FindSQLite3.cmake
    M cmake/win32_compiler_options.cmake
  Log Message:
  De-OSGeo4W'ify CMake configuration (#2092)
* start de-OSGEO4W'ing the cmake config
* add hobu-conda example
  Commit: e4ede0b2b5865893d42ece955f776f5e7680471a
      https://github.com/PDAL/PDAL/commit/e4ede0b2b5865893d42ece955f776f5e7680471a
  Changed paths:
    M doc/about.rst
    M doc/conf.py
    M doc/development/compilation/index.rst
    M doc/development/compilation/unix.rst
    M doc/development/compilation/windows.rst
    R doc/development/contributors.rst
    M doc/development/index.rst
    M doc/development/writing-reader.rst
    M doc/development/writing.rst
    M doc/download.rst
    M doc/faq.rst
    M doc/pipeline.rst
    M doc/project/contributors.rst
    M doc/project/docs.rst
    M doc/project/testing.rst
    M doc/python.rst
    M doc/stages/filters.delaunay.rst
    M doc/stages/filters.hexbin.rst
    M doc/stages/filters.neighborclassifier.rst
    A doc/stages/filters.nndistance.rst
    M doc/stages/filters.python.rst
    A doc/stages/filters.streamcallback.rst
    R doc/stages/index.rst
    M doc/stages/readers.nitf.rst
    M doc/stages/readers.rst
    A doc/stages/readers.terrasolid.rst
    M doc/stages/references.bib
    M doc/stages/writers.pgpointcloud.rst
    M doc/tutorial/clipping/index.rst
    M doc/tutorial/ground-filters.rst
    M doc/tutorial/pcl_spec.rst
    R doc/tutorial/python-filtering.rst
    A doc/tutorial/python-filtering.rst.save
    M doc/tutorial/reading.rst
    R doc/tutorial/sampling/index.rst
    A doc/tutorial/sampling/index.rst.save
    R doc/workshop/docker.rst
    A doc/workshop/docker.rst.save
    M doc/workshop/exercises/analysis/boundary/boundary.rst
    M doc/workshop/exercises/analysis/dtm/dtm.rst
    M doc/workshop/exercises/analysis/ground/ground.rst
    M doc/workshop/exercises/analysis/rasterize/rasterize.rst
    M doc/workshop/exercises/analysis/thinning/thinning.rst
    R doc/workshop/exercises/batch_processing/batch-processing.rst
    A doc/workshop/exercises/batch_processing/batch-processing.rst.save
    M doc/workshop/exercises/info/metadata.rst
    M doc/workshop/notes.rst
    M doc/workshop/osgeo4w.rst
    M doc/workshop/software.rst
  Log Message:
  Docfixes for Sphinx (#2093)
* Fix doc warnings.
* Eliminate warnings in doc build.
* Add dummy line in an attempt to resolve warnings.
Didn't work :(
Requested here: https://github.com/mcmtroffaes/sphinxcontrib-bibtex/issues/141
  Commit: 091baaa05bd4b93b4187fe081e014ac40c3016b0
      https://github.com/PDAL/PDAL/commit/091baaa05bd4b93b4187fe081e014ac40c3016b0
  Date:   2018-07-20 (Fri, 20 Jul 2018)
  Changed paths:
    M pdal/PointView.hpp
    M pdal/util/Uuid.hpp
  Log Message:
  Eliminate pragmas. (#2094)
  Commit: 6f257118f625e23a7771ba913f38296b7ad8bdea
      https://github.com/PDAL/PDAL/commit/6f257118f625e23a7771ba913f38296b7ad8bdea
  Changed paths:
    M filters/DEMFilter.hpp
    M io/GDALReader.cpp
    M io/GDALReader.hpp
    M test/unit/io/GDALReaderTest.cpp
  Log Message:
  make readers.gdal streamable (#2096)
* make readers.gdal streamable
* add tiff/tif/jpeg/jpg to readers.gdal identification
* modifications as requested by review
  Commit: 016e970ece57d4f1b1aae814acffee5ea210bbfa
      https://github.com/PDAL/PDAL/commit/016e970ece57d4f1b1aae814acffee5ea210bbfa
  Date:   2018-07-23 (Mon, 23 Jul 2018)
  Changed paths:
    M io/GDALGrid.hpp
  Log Message:
  Use correct math to compute vertical index in GDALGrid. (#2097)
* Fix calculation of verticalIndex().
* Export GDAL Grid for testing.
  Commit: 6ee2c9d1ed6769e4270165732a101ffc3d523306
      https://github.com/PDAL/PDAL/commit/6ee2c9d1ed6769e4270165732a101ffc3d523306
  Changed paths:
    A CITATION
    M CMakeLists.txt
    M doc/about.rst
    M doc/conf.py
    M doc/download.rst
    M doc/faq.rst
    M doc/pipeline.rst
    M doc/python.rst
    M io/GDALGrid.hpp
    M io/GDALReader.cpp
    M io/GDALReader.hpp
    M io/GDALWriter.cpp
    M io/LasHeader.cpp
    M io/TextWriter.cpp
    M io/TextWriter.hpp
    M pdal/Reader.hpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into issue-2065
  Commit: e6cd93b95069ad99c39e6a2f329fd0ee0c961b28
      https://github.com/PDAL/PDAL/commit/e6cd93b95069ad99c39e6a2f329fd0ee0c961b28
  Changed paths:
    M kernels/TileKernel.cpp
    M kernels/TileKernel.hpp
  Log Message:
  Add skip support.
Add SRS support.
Fill point table when possible.
Improve logic.
Compare: https://github.com/PDAL/PDAL/compare/deeeac1e2ecf...e6cd93b95069
      **NOTE:** This service been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
      Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits mailing list
