[pdal-commits] [PDAL/PDAL] 3c5a06: fix argument error message for true/false (#2039)
GitHub
noreply at github.com
Thu Jun 7 10:16:12 PDT 2018
Branch: refs/heads/issue-1904
Home: https://github.com/PDAL/PDAL
Commit: 3c5a0698a797df6e346081e91bf7d9b381936f5c
https://github.com/PDAL/PDAL/commit/3c5a0698a797df6e346081e91bf7d9b381936f5c
Author: Carl Anderson <carl.anderson at vadose.org>
Date: 2018-05-31 (Thu, 31 May 2018)
Changed paths:
M io/LasReader.cpp
M pdal/util/ProgramArgs.hpp
Log Message:
Commit: 9ef03d61a17509a26bd06b07694a8379fa2b55dd
https://github.com/PDAL/PDAL/commit/9ef03d61a17509a26bd06b07694a8379fa2b55dd
Author: chambbj <brad.chambers at gmail.com>
Date: 2018-06-01 (Fri, 01 Jun 2018)
Changed paths:
M .travis.yml
M scripts/ci/script.sh
A scripts/docker/Dockerfile.alpinedeps
Log Message:
Add Dockerfile to create pdal/dependencies:alpine and update build scripts to use it on Travis (#2040)
Commit: 5722e156ffcd3a1e2fda7d0f0f1cba254377ca96
https://github.com/PDAL/PDAL/commit/5722e156ffcd3a1e2fda7d0f0f1cba254377ca96
Author: Howard Butler <howard at hobu.co>
Date: 2018-06-03 (Sun, 03 Jun 2018)
Changed paths:
M vendor/arbiter/CMakeLists.txt
M vendor/arbiter/arbiter.cpp
M vendor/arbiter/arbiter.hpp
Log Message:
update arbiter to support windows globbing (#2043)
* update arbiter to support windows globbing
* need SHLWAPI for arbiter now for windows
Commit: d0cb25f18b81c802588d5a938b3bf8485b87aeb1
https://github.com/PDAL/PDAL/commit/d0cb25f18b81c802588d5a938b3bf8485b87aeb1
Date: 2018-06-05 (Tue, 05 Jun 2018)
Changed paths:
M plugins/rdb/CMakeLists.txt
Log Message:
link RDB with JSONCPP (#2046)
Commit: 54e35ebd3fe1255031eb983c04cb634ae7c72527
https://github.com/PDAL/PDAL/commit/54e35ebd3fe1255031eb983c04cb634ae7c72527
Date: 2018-06-06 (Wed, 06 Jun 2018)
Changed paths:
M filters/PMFFilter.cpp
M filters/SMRFilter.cpp
M pdal/Segmentation.cpp
Log Message:
Fix segmentation of last returns (#2045)
segmentLastReturns now defines last returns as those points whose ReturnNumber
equals the NumberOfReturns when the NumberOfReturns is greater than 1.
This segmentation is used in both the SMRF and PMF ground segmentation filters,
so ground segmentation results may differ from what was previously returned.
Commit: 75cded9bb61f23b7ec54ebf9c1111f1cfd718129
https://github.com/PDAL/PDAL/commit/75cded9bb61f23b7ec54ebf9c1111f1cfd718129
Changed paths:
Log Message:
update RDB linking as suggested in #2046 (#2048)
Commit: 9ad065975db7a4220c94d20c09310705e0bc4df9
https://github.com/PDAL/PDAL/commit/9ad065975db7a4220c94d20c09310705e0bc4df9
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2018-06-07 (Thu, 07 Jun 2018)
Changed paths:
M vendor/kazhdan/PoissonRecon.h
M vendor/kazhdan/point_source/AsciiPointSource.inl
M vendor/kazhdan/point_source/MemoryPointSource.h
M vendor/kazhdan/point_source/PlyPointSource.inl
M vendor/kazhdan/point_source/PointSource.h
M vendor/kazhdan/point_source/TransformedPointSource.h
Log Message:
Compiler updates for poisson filter (#2031)
* Updates from Mark Loyman.
* Set thread count to 1.
Commit: c7322358ca15a2df09721aede03b25872d88b9d3
https://github.com/PDAL/PDAL/commit/c7322358ca15a2df09721aede03b25872d88b9d3
Changed paths:
M .travis.yml
M io/LasReader.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into issue-1904
Compare: https://github.com/PDAL/PDAL/compare/864ec9d25aae...c7322358ca15
**NOTE:** This service been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits
