[pdal-commits] [PDAL/PDAL] 7570b0: Improve filters.stats (#2034)
GitHub
noreply at github.com
Mon Jun 18 13:29:06 PDT 2018
Branch: refs/heads/issue-2038
Home: https://github.com/PDAL/PDAL
Commit: 7570b0a4f2d133ced720dc6fc5fc23bd8ddf558e
https://github.com/PDAL/PDAL/commit/7570b0a4f2d133ced720dc6fc5fc23bd8ddf558e
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2018-05-24 (Thu, 24 May 2018)
Changed paths:
M filters/ColorinterpFilter.cpp
M filters/StatsFilter.cpp
M filters/StatsFilter.hpp
M test/unit/filters/StatsFilterTest.cpp
Log Message:
* Fix comment.
* Enhance stats filter test to check higher-order statistics.
* Only compute average once.
Simplify a little math.
Add comments.
* Only run skewness/kurtosis in advanced mode.
Commit: ef27755cf6a8126c2d228aaa19390878d2403f81
https://github.com/PDAL/PDAL/commit/ef27755cf6a8126c2d228aaa19390878d2403f81
Author: Howard Butler <howard at hobu.co>
Date: 2018-05-29 (Tue, 29 May 2018)
Changed paths:
R scripts/docker/1.4-maintenance/alpine/10-backtrace-guards.patch
R scripts/docker/1.4-maintenance/alpine/Dockerfile
R scripts/docker/1.4-maintenance/ubuntu/Dockerfile
R scripts/docker/1.5-maintenance/alpine/10-backtrace-guards.patch
R scripts/docker/1.5-maintenance/alpine/Dockerfile
R scripts/docker/1.5-maintenance/ubuntu/Dockerfile
R scripts/docker/1.6-maintenance/alpine/Dockerfile
R scripts/docker/1.6-maintenance/ubuntu/Dockerfile
R scripts/docker/dependencies/Dockerfile
A scripts/docker/ubuntu/Dockerfile
A scripts/docker/ubuntu/dependencies/Dockerfile
Log Message:
ubuntu-based docker build
Commit: 3c5a0698a797df6e346081e91bf7d9b381936f5c
https://github.com/PDAL/PDAL/commit/3c5a0698a797df6e346081e91bf7d9b381936f5c
Author: Carl Anderson <carl.anderson at vadose.org>
Date: 2018-05-31 (Thu, 31 May 2018)
Changed paths:
M io/LasReader.cpp
M pdal/util/ProgramArgs.hpp
Log Message:
fix argument error message for true/false (#2039)
Commit: 9ef03d61a17509a26bd06b07694a8379fa2b55dd
https://github.com/PDAL/PDAL/commit/9ef03d61a17509a26bd06b07694a8379fa2b55dd
Author: chambbj <brad.chambers at gmail.com>
Date: 2018-06-01 (Fri, 01 Jun 2018)
Changed paths:
M .travis.yml
M scripts/ci/script.sh
A scripts/docker/Dockerfile.alpinedeps
Log Message:
Add Dockerfile to create pdal/dependencies:alpine and update build scripts to use it on Travis (#2040)
Commit: 5722e156ffcd3a1e2fda7d0f0f1cba254377ca96
https://github.com/PDAL/PDAL/commit/5722e156ffcd3a1e2fda7d0f0f1cba254377ca96
Date: 2018-06-03 (Sun, 03 Jun 2018)
Changed paths:
M vendor/arbiter/CMakeLists.txt
M vendor/arbiter/arbiter.cpp
M vendor/arbiter/arbiter.hpp
Log Message:
update arbiter to support windows globbing (#2043)
* update arbiter to support windows globbing
* need SHLWAPI for arbiter now for windows
Commit: d0cb25f18b81c802588d5a938b3bf8485b87aeb1
https://github.com/PDAL/PDAL/commit/d0cb25f18b81c802588d5a938b3bf8485b87aeb1
Date: 2018-06-05 (Tue, 05 Jun 2018)
Changed paths:
M plugins/rdb/CMakeLists.txt
Log Message:
link RDB with JSONCPP (#2046)
Commit: 54e35ebd3fe1255031eb983c04cb634ae7c72527
https://github.com/PDAL/PDAL/commit/54e35ebd3fe1255031eb983c04cb634ae7c72527
Date: 2018-06-06 (Wed, 06 Jun 2018)
Changed paths:
M filters/PMFFilter.cpp
M filters/SMRFilter.cpp
M pdal/Segmentation.cpp
Log Message:
Fix segmentation of last returns (#2045)
segmentLastReturns now defines last returns as those points whose ReturnNumber
equals the NumberOfReturns when the NumberOfReturns is greater than 1.
This segmentation is used in both the SMRF and PMF ground segmentation filters,
so ground segmentation results may differ from what was previously returned.
Commit: 75cded9bb61f23b7ec54ebf9c1111f1cfd718129
https://github.com/PDAL/PDAL/commit/75cded9bb61f23b7ec54ebf9c1111f1cfd718129
Changed paths:
Log Message:
update RDB linking as suggested in #2046 (#2048)
Commit: 9ad065975db7a4220c94d20c09310705e0bc4df9
https://github.com/PDAL/PDAL/commit/9ad065975db7a4220c94d20c09310705e0bc4df9
Date: 2018-06-07 (Thu, 07 Jun 2018)
Changed paths:
M vendor/kazhdan/PoissonRecon.h
M vendor/kazhdan/point_source/AsciiPointSource.inl
M vendor/kazhdan/point_source/MemoryPointSource.h
M vendor/kazhdan/point_source/PlyPointSource.inl
M vendor/kazhdan/point_source/PointSource.h
M vendor/kazhdan/point_source/TransformedPointSource.h
Log Message:
Compiler updates for poisson filter (#2031)
* Updates from Mark Loyman.
* Set thread count to 1.
Commit: de8ca415e43eb8401040a51adcedc5ea90e734af
https://github.com/PDAL/PDAL/commit/de8ca415e43eb8401040a51adcedc5ea90e734af
Date: 2018-06-11 (Mon, 11 Jun 2018)
Changed paths:
M doc/python.rst
Log Message:
Add some Conda docs to python pages (#2052)
Fixes #2047 (assuming the Python compilation page is just stale output)
Commit: 80f876b1d7df7ef6f51b2f3f856912faeeeb8039
https://github.com/PDAL/PDAL/commit/80f876b1d7df7ef6f51b2f3f856912faeeeb8039
Changed paths:
M apps/pdal.cpp
M cmake/execinfo.cmake
A cmake/modules/FindLibexecinfo.cmake
A cmake/modules/FindLibunwind.cmake
A cmake/unwind.cmake
M dimbuilder/CMakeLists.txt
A pdal/util/Backtrace.cpp
A pdal/util/Backtrace.hpp
M pdal/util/CMakeLists.txt
M pdal/util/Utils.cpp
M pdal/util/Utils.hpp
A pdal/util/private/BacktraceExecinfo.cpp
A pdal/util/private/BacktraceImpl.hpp
A pdal/util/private/BacktraceNone.cpp
A pdal/util/private/BacktraceUnwind.cpp
Log Message:
Implement Backtrace for Libunwind (#2037)
* Add backtrace support for libunwind.
* Use proper execinfo backtrace function.
* Remove cruft.
* Make backtrace work on a system w/o libunwind.
* Small fixes.
Commit: e300f5bbc356ce839a9e8370deecfe9e591e7c9e
https://github.com/PDAL/PDAL/commit/e300f5bbc356ce839a9e8370deecfe9e591e7c9e
Changed paths:
M .travis.yml
M apps/pdal.cpp
M doc/python.rst
M io/LasReader.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into issue-2038
Commit: 0796de17e2c0505ea17d4ff7b8604db7674e5747
https://github.com/PDAL/PDAL/commit/0796de17e2c0505ea17d4ff7b8604db7674e5747
Author: Éric Lemoine <eric.lemoine at gmail.com>
Date: 2018-06-13 (Wed, 13 Jun 2018)
Changed paths:
M doc/stages/writers.pgpointcloud.rst
M plugins/pgpointcloud/io/PgCommon.hpp
M plugins/pgpointcloud/io/PgWriter.cpp
Log Message:
Add pgpointcloud lazperf support (#2051)
Commit: cc254abfff1bb2a2d5ad845182973c52d92762fc
https://github.com/PDAL/PDAL/commit/cc254abfff1bb2a2d5ad845182973c52d92762fc
Changed paths:
M kernels/GroundKernel.cpp
M kernels/GroundKernel.hpp
Log Message:
Add prefiltering options to ground kernel (#2054)
- Add a switch to optionally reset classifications prior to segmenting ground returns
- Add a switch to optionally denoise prior to segmenting ground returns
Fixes #1579
Commit: 6e2d2a7363b2969b6e895d21b7e8381978cad7cf
https://github.com/PDAL/PDAL/commit/6e2d2a7363b2969b6e895d21b7e8381978cad7cf
Changed paths:
M doc/quickstart.rst
Log Message:
Rewrite quickstart docs with Conda focus, dropping Docker (#2056)
* Initial cut at rewriting Quickstart, short of replacing images
* Provide some sample outputs and update the autzen.laz download link
Careful readers will note the warning about datum.csv, etc. not being found.
This is a real thing. They exist and are installed, but are not being located
for some reason.
Commit: 809e1b35d237a838205cf91775884c80f48d4011
https://github.com/PDAL/PDAL/commit/809e1b35d237a838205cf91775884c80f48d4011
Date: 2018-06-18 (Mon, 18 Jun 2018)
Changed paths:
Log Message:
Compare: https://github.com/PDAL/PDAL/compare/21c77f590e5b...809e1b35d237
**NOTE:** This service been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits
