[pdal-commits] [PDAL/PDAL] b4bda6: Protect GDALWriter from zero-point pipelines (#182...
GitHub
noreply at github.com
Mon Mar 5 06:30:15 PST 2018
Branch: refs/heads/issue-1824
Home: https://github.com/PDAL/PDAL
Commit: b4bda6cd8c5b92743ba251f44c5c8f3630ec2b45
https://github.com/PDAL/PDAL/commit/b4bda6cd8c5b92743ba251f44c5c8f3630ec2b45
Author: Pete Gadomski <pete.gadomski at gmail.com>
Date: 2018-03-03 (Sat, 03 Mar 2018)
Changed paths:
M io/GDALWriter.cpp
M test/unit/io/GDALWriterTest.cpp
Log Message:
Protect GDALWriter from zero-point pipelines (#1825)
The GDALWriter throws a segfault due to an uninitialized `m_grid` member
variable when trying to execute some zero-point pipelines, e.g.:
```bash
pdal translate \
-i test/data/las/no-points.las \
-o /tmp/out.tif \
-f range --filters.range.limits="Classification[2:2]" \
--writers.gdal.resolution=1
I *think* this is due to `GDALWriter::writeView` never being called, so
the grid is never initialized.
Includes a test case.
Commit: 3d6483b38bd02467fbe850ceb848df6e1441804b
https://github.com/PDAL/PDAL/commit/3d6483b38bd02467fbe850ceb848df6e1441804b
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Changed paths:
M doc/stages/filters.ferry.rst
M filters/FerryFilter.cpp
M test/unit/filters/FerryFilterTest.cpp
Log Message:
Copy (#1811)
* Allow => in addition to = in filters.ferry syntax.
* Update documentation.
Commit: 98cba9be7038a02ffe3a945704ad4fdbae4f8ac9
https://github.com/PDAL/PDAL/commit/98cba9be7038a02ffe3a945704ad4fdbae4f8ac9
Author: chambbj <brad.chambers at gmail.com>
Date: 2018-03-05 (Mon, 05 Mar 2018)
Changed paths:
M scripts/ci/script.sh
M scripts/docker/Dockerfile
Log Message:
Add edge/community package repository (#1826)
* Add edge/community package repository
eigen-dev has been moved from edge/testing to edge/community
* Use repository pinning for edge/community and eigen-dev
* Travis uses a script, not the Dockerfile, replicate changes for Travis
Commit: cbdad61c0faca892d4bd8df8a43b73b1311e37ca
https://github.com/PDAL/PDAL/commit/cbdad61c0faca892d4bd8df8a43b73b1311e37ca
Changed paths:
M io/GDALWriter.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into issue-1824
Compare: https://github.com/PDAL/PDAL/compare/a4b04cde47a9...cbdad61c0fac
More information about the pdal-commits
