[pdal-commits] [PDAL/PDAL] 299623: Don't create files for empty views when writing te...
    GitHub
    noreply at github.com
    Fri Mar 23 13:36:20 PDT 2018
  Branch: refs/heads/mbio
  Home:   https://github.com/PDAL/PDAL
  Commit: 299623f2068b0d35712be8f9f21556f4fe61cb5f
      https://github.com/PDAL/PDAL/commit/299623f2068b0d35712be8f9f21556f4fe61cb5f
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2018-03-22 (Thu, 22 Mar 2018)
  Changed paths:
    M pdal/FlexWriter.hpp
  Log Message:
  Don't create files for empty views when writing template-based files. (#1865)
  Commit: 0d310ba03ffb7b9d17fb405cb9cf8aafeb02e6ee
      https://github.com/PDAL/PDAL/commit/0d310ba03ffb7b9d17fb405cb9cf8aafeb02e6ee
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    M cmake/laszip.cmake
    M cmake/modules/FindLASzip.cmake
  Log Message:
  use laszip3 as the windows dll package to find for LASzip and allow 3.1+ for the version
  Commit: 7f52787a879076de0e552b60f8b4a10f1747f643
      https://github.com/PDAL/PDAL/commit/7f52787a879076de0e552b60f8b4a10f1747f643
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Changed paths:
    M plugins/nitf/io/tre_plugins.hpp
  Log Message:
  More warning suppression
  Commit: 66161311563c1947a492949bdcf0d1a235e0b9f7
      https://github.com/PDAL/PDAL/commit/66161311563c1947a492949bdcf0d1a235e0b9f7
  Changed paths:
    M io/TextReader.cpp
  Log Message:
  Make sure line is initialized to 0.
  Commit: 62e6406254917b9b876c731a6178009fb38270e0
      https://github.com/PDAL/PDAL/commit/62e6406254917b9b876c731a6178009fb38270e0
  Changed paths:
    R doc/stages/filters.computerange.rst
    R filters/ComputeRangeFilter.cpp
    R filters/ComputeRangeFilter.hpp
    M test/unit/CMakeLists.txt
    R test/unit/filters/ComputeRangeFilterTest.cpp
  Log Message:
  Remove the ComputeRange filter
  Commit: d73509730858bccc00cd95d2d2a689971e48591e
      https://github.com/PDAL/PDAL/commit/d73509730858bccc00cd95d2d2a689971e48591e
  Date:   2018-03-23 (Fri, 23 Mar 2018)
  Changed paths:
    M doc/stages/writers.text.rst
    M io/TextWriter.cpp
    M io/TextWriter.hpp
    M test/unit/io/TextWriterTest.cpp
  Log Message:
  Add support for individual dimension precisions.
Close #1869
  Commit: 837ba6aef3a46b15e70826acb03eb15a02410451
      https://github.com/PDAL/PDAL/commit/837ba6aef3a46b15e70826acb03eb15a02410451
  Changed paths:
    M io/TextWriter.cpp
    M io/TextWriter.hpp
  Log Message:
Close #1869
  Commit: a526df59a9ffa1cc9add0b2e5d872f575c27c6db
      https://github.com/PDAL/PDAL/commit/a526df59a9ffa1cc9add0b2e5d872f575c27c6db
  Changed paths:
    M io/TextReader.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: ebd9f807584ce2ef2bbc72e5c6b620f84e478c36
      https://github.com/PDAL/PDAL/commit/ebd9f807584ce2ef2bbc72e5c6b620f84e478c36
  Changed paths:
    M kernels/TranslateKernel.cpp
  Log Message:
  Allow pdal translate to stream.
  Commit: 3b681d150e294d04db4c1650edfb330764d702cd
      https://github.com/PDAL/PDAL/commit/3b681d150e294d04db4c1650edfb330764d702cd
  Changed paths:
    M pdal/PluginManager.hpp
  Log Message:
  fix #1872 -- need to include <functional> for some compilers
  Commit: fb90efc3d955627ecd39a3778eb892e9cba7cef3
      https://github.com/PDAL/PDAL/commit/fb90efc3d955627ecd39a3778eb892e9cba7cef3
  Changed paths:
    M io/TextReader.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into mbio
Compare: https://github.com/PDAL/PDAL/compare/783f1a3b56c6...fb90efc3d955
More information about the pdal-commits
