[pdal-commits] [PDAL/PDAL] 661613: Make sure line is initialized to	0.
    GitHub
    noreply at github.com
    Sat Mar 24 00:40:57 PDT 2018
  Branch: refs/heads/conda-test
  Home:   https://github.com/PDAL/PDAL
  Commit: 66161311563c1947a492949bdcf0d1a235e0b9f7
      https://github.com/PDAL/PDAL/commit/66161311563c1947a492949bdcf0d1a235e0b9f7
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2018-03-22 (Thu, 22 Mar 2018)
  Changed paths:
    M io/TextReader.cpp
  Log Message:
  Commit: 62e6406254917b9b876c731a6178009fb38270e0
      https://github.com/PDAL/PDAL/commit/62e6406254917b9b876c731a6178009fb38270e0
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Changed paths:
    R doc/stages/filters.computerange.rst
    R filters/ComputeRangeFilter.cpp
    R filters/ComputeRangeFilter.hpp
    M test/unit/CMakeLists.txt
    R test/unit/filters/ComputeRangeFilterTest.cpp
  Log Message:
  Remove the ComputeRange filter
  Commit: 837ba6aef3a46b15e70826acb03eb15a02410451
      https://github.com/PDAL/PDAL/commit/837ba6aef3a46b15e70826acb03eb15a02410451
  Date:   2018-03-23 (Fri, 23 Mar 2018)
  Changed paths:
    M doc/stages/writers.text.rst
    M io/TextWriter.cpp
    M io/TextWriter.hpp
    M test/unit/io/TextWriterTest.cpp
  Log Message:
  Add support for individual dimension precisions.
Close #1869
  Commit: a526df59a9ffa1cc9add0b2e5d872f575c27c6db
      https://github.com/PDAL/PDAL/commit/a526df59a9ffa1cc9add0b2e5d872f575c27c6db
  Changed paths:
    M cmake/laszip.cmake
    M cmake/modules/FindLASzip.cmake
    M io/TextReader.cpp
    M pdal/FlexWriter.hpp
    M plugins/nitf/io/tre_plugins.hpp
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: ebd9f807584ce2ef2bbc72e5c6b620f84e478c36
      https://github.com/PDAL/PDAL/commit/ebd9f807584ce2ef2bbc72e5c6b620f84e478c36
  Changed paths:
    M kernels/TranslateKernel.cpp
  Log Message:
  Allow pdal translate to stream.
  Commit: 3b681d150e294d04db4c1650edfb330764d702cd
      https://github.com/PDAL/PDAL/commit/3b681d150e294d04db4c1650edfb330764d702cd
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    M pdal/PluginManager.hpp
  Log Message:
  fix #1872 -- need to include <functional> for some compilers
  Commit: c0efae4236db9bc759a7ab8174405bf0ada2a5ac
      https://github.com/PDAL/PDAL/commit/c0efae4236db9bc759a7ab8174405bf0ada2a5ac
  Author: Vicky Vergara <vicky at georepublic.de>
  Changed paths:
    A doxygen/.gitignore
    A doxygen/Doxyfile
    A doxygen/DoxygenLayout.xml
  Log Message:
  generating doxygen (#1761)
  Commit: 6d86aa138c248fd471d34e3f5b29265351654fed
      https://github.com/PDAL/PDAL/commit/6d86aa138c248fd471d34e3f5b29265351654fed
  Author: Grigory <gr.pomadchin at gmail.com>
  Changed paths:
    M CMakeLists.txt
    M HOWTORELEASE.txt
    R cmake/pdaljni.cmake
    R java/.gitignore
    R java/README.md
    R java/build.sbt
    R java/core-scala/src/main/scala/io/pdal/pipeline/ExprType.scala
    R java/core-scala/src/main/scala/io/pdal/pipeline/FilterTypes.scala
    R java/core-scala/src/main/scala/io/pdal/pipeline/Implicits.scala
    R java/core-scala/src/main/scala/io/pdal/pipeline/PipelineExpressions.scala
    R java/core-scala/src/main/scala/io/pdal/pipeline/ReaderTypes.scala
    R java/core-scala/src/main/scala/io/pdal/pipeline/WriterTypes.scala
    R java/core-scala/src/main/scala/io/pdal/pipeline/json/Implicits.scala
    R java/core-scala/src/main/scala/io/pdal/pipeline/json/package.scala
    R java/core-scala/src/main/scala/io/pdal/pipeline/package.scala
    R java/core-scala/src/test/scala/io/pdal/pipeline/PipelineExpressionsSpec.scala
    R java/core/src/main/scala/io/pdal/DimType.scala
    R java/core/src/main/scala/io/pdal/Native.scala
    R java/core/src/main/scala/io/pdal/Pipeline.scala
    R java/core/src/main/scala/io/pdal/PointCloud.scala
    R java/core/src/main/scala/io/pdal/PointLayout.scala
    R java/core/src/main/scala/io/pdal/PointView.scala
    R java/core/src/main/scala/io/pdal/PointViewIterator.scala
    R java/core/src/main/scala/io/pdal/SizedDimType.scala
    R java/core/src/test/resources/las.json
    R java/core/src/test/scala/io/pdal/PipelineSpec.scala
    R java/core/src/test/scala/io/pdal/PointCloudSpec.scala
    R java/core/src/test/scala/io/pdal/TestEnvironmentSpec.scala
    R java/native/src/Accessors.cpp
    R java/native/src/CMakeLists.txt
    R java/native/src/JavaPipeline.cpp
    R java/native/src/PointViewRawPtr.cpp
    R java/native/src/include/Accessors.hpp
    R java/native/src/include/JavaIterator.hpp
    R java/native/src/include/JavaPipeline.hpp
    R java/native/src/include/PointViewRawPtr.hpp
    R java/native/src/include/io_pdal_Pipeline.h
    R java/native/src/include/io_pdal_PointLayout.h
    R java/native/src/include/io_pdal_PointView.h
    R java/native/src/include/io_pdal_PointViewIterator.h
    R java/native/src/io_pdal_Pipeline.cpp
    R java/native/src/io_pdal_PointLayout.cpp
    R java/native/src/io_pdal_PointView.cpp
    R java/native/src/io_pdal_PointViewIterator.cpp
    R java/project/Commands.scala
    R java/project/Dependencies.scala
    R java/project/Environment.scala
    R java/project/Version.scala
    R java/project/build.properties
    R java/project/plugins.sbt
    R java/sbt
    R java/scripts/publish-212.sh
    R java/scripts/publish-all.sh
    R java/scripts/publish-javastyle.sh
    R java/scripts/publish-local-212.sh
    R java/scripts/publish-local.sh
    R java/scripts/publish.sh
  Log Message:
  Remove PDAL java package as it's in a separate repo now (#1870)
  Commit: 9a08de8e1437f7d3276fec3c4c5dd95356d4dcd8
      https://github.com/PDAL/PDAL/commit/9a08de8e1437f7d3276fec3c4c5dd95356d4dcd8
  Date:   2018-03-24 (Sat, 24 Mar 2018)
  Changed paths:
  Log Message:
  Suppressing more GCC warnings in nitro
Compare: https://github.com/PDAL/PDAL/compare/7f52787a8790...9a08de8e1437
More information about the pdal-commits
