[pdal-commits] [PDAL/PDAL] 2c581e: Fix the streaming interface by making the stream-b...
GitHub
noreply at github.com
Fri Mar 30 13:36:20 PDT 2018
Branch: refs/heads/readers.numpy
Home: https://github.com/PDAL/PDAL
Commit: 2c581e5b628483272d43e4de5b0c1f0b73f846ad
https://github.com/PDAL/PDAL/commit/2c581e5b628483272d43e4de5b0c1f0b73f846ad
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2018-03-29 (Thu, 29 Mar 2018)
Changed paths:
M io/BpfReader.cpp
M pdal/Stage.hpp
M pdal/Streamable.cpp
M pdal/Streamable.hpp
M plugins/nitf/io/NitfWriter.cpp
M test/unit/filters/CropFilterTest.cpp
M test/unit/io/BPFTest.cpp
M test/unit/io/PlyReaderTest.cpp
Log Message:
Fix the streaming interface by making the stream-based execute function virtual. (#1876)
Commit: 67950cf055241436b8d4d50baabd67b737b47a6b
https://github.com/PDAL/PDAL/commit/67950cf055241436b8d4d50baabd67b737b47a6b
Author: Bradley J Chambers <brad.chambers at gmail.com>
Changed paths:
M plugins/nitf/io/tre_plugins.hpp
Log Message:
Suppress more warnings in NITF plugin
Commit: a577b70159b0f3be927a02caef94b5a54b4aac3a
https://github.com/PDAL/PDAL/commit/a577b70159b0f3be927a02caef94b5a54b4aac3a
Date: 2018-03-30 (Fri, 30 Mar 2018)
Changed paths:
M io/TextReader.cpp
Log Message:
Remove debug.
Commit: e938d5c735fc53cc0d01559199be5b0dff0ab056
https://github.com/PDAL/PDAL/commit/e938d5c735fc53cc0d01559199be5b0dff0ab056
Changed paths:
M io/BpfReader.cpp
M pdal/Stage.hpp
Log Message:
Merge remote-tracking branch 'origin/master'
Commit: b844196e8b2964c18dc3abd4691e909f259464fd
https://github.com/PDAL/PDAL/commit/b844196e8b2964c18dc3abd4691e909f259464fd
Author: chambbj <brad.chambers at gmail.com>
Changed paths:
M doc/references.rst
M doc/stages/filters.gridprojection.rst
M doc/stages/filters.mongus.rst
M doc/stages/filters.movingleastsquares.rst
M doc/stages/filters.poisson.rst
M doc/stages/filters.rst
M doc/stages/readers.rst
M doc/stages/writers.bpf.rst
M doc/stages/writers.rst
A doc/stages/writers.sbet.rst
M filters/ApproximateCoplanarFilter.cpp
M filters/AssignFilter.cpp
M filters/ClusterFilter.cpp
M filters/ELMFilter.cpp
M filters/EigenvaluesFilter.cpp
M filters/EstimateRankFilter.cpp
M filters/HAGFilter.cpp
Log Message:
Improve stage overview documentation (#1880)
Convert from bulleted TOC stage listings to definition lists, whereby the
filter name and link are shown as the "term" and a brief stage description is
provided as the definition. The intent is to provide a simpler overview of our
growing list of stages.
Filters are also broken into some categories that attempt to capture what they
do to the data (like creating new dimensions, culling points, etc.).
Commit: e8c720000928a72a3ccc56c28e114d8072024802
https://github.com/PDAL/PDAL/commit/e8c720000928a72a3ccc56c28e114d8072024802
Author: Howard Butler <howard at hobu.co>
Changed paths:
M plugins/python/io/NumpyReader.cpp
M plugins/python/io/NumpyReader.hpp
Log Message:
support assigning an explicit Z dimension, support swapping dimensions
Commit: 897afd561357f308298b289f9ed9fc4ad6e3990f
https://github.com/PDAL/PDAL/commit/897afd561357f308298b289f9ed9fc4ad6e3990f
Changed paths:
M io/TextReader.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into readers.numpy
Commit: eaee9a14572d765a061d9d0b05cae876996d2051
https://github.com/PDAL/PDAL/commit/eaee9a14572d765a061d9d0b05cae876996d2051
Changed paths:
A doc/stages/readers.numpy.rst
Log Message:
add docs
Compare: https://github.com/PDAL/PDAL/compare/0f60fbb8b54b...eaee9a14572d
More information about the pdal-commits
