[pdal-commits] [PDAL/PDAL] fc7316: Don't bleed PDAL build info into subprojects (#199...
GitHub
noreply at github.com
Mon May 7 11:39:20 PDT 2018
Branch: refs/heads/1.7-maintenance
Home: https://github.com/PDAL/PDAL
Commit: fc7316e91b60ff27e28d879d8dc193ad39c22524
https://github.com/PDAL/PDAL/commit/fc7316e91b60ff27e28d879d8dc193ad39c22524
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2018-05-07 (Mon, 07 May 2018)
Changed paths:
M .gitignore
M CMakeLists.txt
M apps/CMakeLists.txt
M cmake/json.cmake
M cmake/macros.cmake
M cmake/unix_compiler_options.cmake
M cmake/win32_compiler_options.cmake
M plugins/greyhound/CMakeLists.txt
M plugins/hexbin/CMakeLists.txt
M plugins/nitf/CMakeLists.txt
M plugins/oci/CMakeLists.txt
M plugins/pgpointcloud/CMakeLists.txt
M plugins/python/filters/CMakeLists.txt
M plugins/python/io/NumpyReader.cpp
M plugins/sqlite/CMakeLists.txt
M test/unit/CMakeLists.txt
M test/unit/OptionsTest.cpp
M test/unit/PolygonTest.cpp
R vendor/pdalboost/Jamroot
R vendor/pdalboost/boost.css
R vendor/pdalboost/boost.png
R vendor/pdalboost/boost/archive/detail/auto_link_archive.hpp
R vendor/pdalboost/boost/archive/detail/auto_link_warchive.hpp
R vendor/pdalboost/boost/atomic/detail/link.hpp
R vendor/pdalboost/boost/chrono/config.hpp
M vendor/pdalboost/boost/date_time/compiler_config.hpp
M vendor/pdalboost/boost/filesystem/config.hpp
R vendor/pdalboost/boost/iostreams/detail/config/auto_link.hpp
M vendor/pdalboost/boost/iostreams/detail/config/bzip2.hpp
M vendor/pdalboost/boost/iostreams/detail/config/zlib.hpp
M vendor/pdalboost/boost/serialization/config.hpp
M vendor/pdalboost/boost/system/config.hpp
R vendor/pdalboost/boost/test/debug.hpp
R vendor/pdalboost/boost/test/debug_config.hpp
R vendor/pdalboost/boost/test/detail/config.hpp
R vendor/pdalboost/boost/test/detail/enable_warnings.hpp
R vendor/pdalboost/boost/test/detail/fwd_decl.hpp
R vendor/pdalboost/boost/test/detail/global_typedef.hpp
R vendor/pdalboost/boost/test/detail/log_level.hpp
R vendor/pdalboost/boost/test/detail/pp_variadic.hpp
R vendor/pdalboost/boost/test/detail/suppress_warnings.hpp
R vendor/pdalboost/boost/test/detail/throw_exception.hpp
R vendor/pdalboost/boost/test/detail/workaround.hpp
R vendor/pdalboost/boost/test/execution_monitor.hpp
R vendor/pdalboost/boost/test/framework.hpp
R vendor/pdalboost/boost/test/impl/compiler_log_formatter.ipp
R vendor/pdalboost/boost/test/impl/cpp_main.ipp
R vendor/pdalboost/boost/test/impl/debug.ipp
R vendor/pdalboost/boost/test/impl/decorator.ipp
R vendor/pdalboost/boost/test/impl/execution_monitor.ipp
R vendor/pdalboost/boost/test/impl/framework.ipp
R vendor/pdalboost/boost/test/impl/plain_report_formatter.ipp
R vendor/pdalboost/boost/test/impl/progress_monitor.ipp
R vendor/pdalboost/boost/test/impl/results_collector.ipp
R vendor/pdalboost/boost/test/impl/results_reporter.ipp
R vendor/pdalboost/boost/test/impl/test_main.ipp
R vendor/pdalboost/boost/test/impl/test_tools.ipp
R vendor/pdalboost/boost/test/impl/test_tree.ipp
R vendor/pdalboost/boost/test/impl/unit_test_log.ipp
R vendor/pdalboost/boost/test/impl/unit_test_main.ipp
R vendor/pdalboost/boost/test/impl/unit_test_monitor.ipp
R vendor/pdalboost/boost/test/impl/unit_test_parameters.ipp
R vendor/pdalboost/boost/test/impl/xml_log_formatter.ipp
R vendor/pdalboost/boost/test/impl/xml_report_formatter.ipp
R vendor/pdalboost/boost/test/included/prg_exec_monitor.hpp
R vendor/pdalboost/boost/test/minimal.hpp
R vendor/pdalboost/boost/test/output/compiler_log_formatter.hpp
R vendor/pdalboost/boost/test/output/plain_report_formatter.hpp
R vendor/pdalboost/boost/test/output/xml_log_formatter.hpp
R vendor/pdalboost/boost/test/output/xml_report_formatter.hpp
R vendor/pdalboost/boost/test/parameterized_test.hpp
R vendor/pdalboost/boost/test/prg_exec_monitor.hpp
R vendor/pdalboost/boost/test/progress_monitor.hpp
R vendor/pdalboost/boost/test/results_collector.hpp
R vendor/pdalboost/boost/test/results_reporter.hpp
R vendor/pdalboost/boost/test/test_tools.hpp
R vendor/pdalboost/boost/test/tools/assertion.hpp
R vendor/pdalboost/boost/test/tools/assertion_result.hpp
R vendor/pdalboost/boost/test/tools/collection_comparison_op.hpp
R vendor/pdalboost/boost/test/tools/context.hpp
R vendor/pdalboost/boost/test/tools/cstring_comparison_op.hpp
R vendor/pdalboost/boost/test/tools/detail/bitwise_manip.hpp
R vendor/pdalboost/boost/test/tools/detail/expression_holder.hpp
R vendor/pdalboost/boost/test/tools/detail/fwd.hpp
R vendor/pdalboost/boost/test/tools/detail/indirections.hpp
R vendor/pdalboost/boost/test/tools/detail/it_pair.hpp
R vendor/pdalboost/boost/test/tools/detail/lexicographic_manip.hpp
R vendor/pdalboost/boost/test/tools/detail/per_element_manip.hpp
R vendor/pdalboost/boost/test/tools/detail/print_helper.hpp
R vendor/pdalboost/boost/test/tools/detail/tolerance_manip.hpp
R vendor/pdalboost/boost/test/tools/floating_point_comparison.hpp
R vendor/pdalboost/boost/test/tools/fpc_op.hpp
R vendor/pdalboost/boost/test/tools/fpc_tolerance.hpp
R vendor/pdalboost/boost/test/tools/interface.hpp
R vendor/pdalboost/boost/test/tools/old/impl.hpp
R vendor/pdalboost/boost/test/tools/old/interface.hpp
R vendor/pdalboost/boost/test/tools/output_test_stream.hpp
R vendor/pdalboost/boost/test/tree/auto_registration.hpp
R vendor/pdalboost/boost/test/tree/decorator.hpp
R vendor/pdalboost/boost/test/tree/fixture.hpp
R vendor/pdalboost/boost/test/tree/global_fixture.hpp
R vendor/pdalboost/boost/test/tree/observer.hpp
R vendor/pdalboost/boost/test/tree/test_case_counter.hpp
R vendor/pdalboost/boost/test/tree/test_case_template.hpp
R vendor/pdalboost/boost/test/tree/test_unit.hpp
R vendor/pdalboost/boost/test/tree/traverse.hpp
R vendor/pdalboost/boost/test/tree/visitor.hpp
R vendor/pdalboost/boost/test/unit_test.hpp
R vendor/pdalboost/boost/test/unit_test_log.hpp
R vendor/pdalboost/boost/test/unit_test_log_formatter.hpp
R vendor/pdalboost/boost/test/unit_test_monitor.hpp
R vendor/pdalboost/boost/test/unit_test_parameters.hpp
R vendor/pdalboost/boost/test/unit_test_suite.hpp
R vendor/pdalboost/boost/test/utils/algorithm.hpp
R vendor/pdalboost/boost/test/utils/assign_op.hpp
R vendor/pdalboost/boost/test/utils/basic_cstring/basic_cstring.hpp
R vendor/pdalboost/boost/test/utils/basic_cstring/basic_cstring_fwd.hpp
R vendor/pdalboost/boost/test/utils/basic_cstring/bcs_char_traits.hpp
R vendor/pdalboost/boost/test/utils/basic_cstring/compare.hpp
R vendor/pdalboost/boost/test/utils/basic_cstring/io.hpp
R vendor/pdalboost/boost/test/utils/class_properties.hpp
R vendor/pdalboost/boost/test/utils/custom_manip.hpp
R vendor/pdalboost/boost/test/utils/foreach.hpp
R vendor/pdalboost/boost/test/utils/is_cstring.hpp
R vendor/pdalboost/boost/test/utils/is_forward_iterable.hpp
R vendor/pdalboost/boost/test/utils/iterator/input_iterator_facade.hpp
R vendor/pdalboost/boost/test/utils/iterator/token_iterator.hpp
R vendor/pdalboost/boost/test/utils/lazy_ostream.hpp
R vendor/pdalboost/boost/test/utils/named_params.hpp
R vendor/pdalboost/boost/test/utils/rtti.hpp
R vendor/pdalboost/boost/test/utils/runtime/argument.hpp
R vendor/pdalboost/boost/test/utils/runtime/argument_factory.hpp
R vendor/pdalboost/boost/test/utils/runtime/cla/argv_traverser.hpp
R vendor/pdalboost/boost/test/utils/runtime/cla/parser.hpp
R vendor/pdalboost/boost/test/utils/runtime/env/fetch.hpp
R vendor/pdalboost/boost/test/utils/runtime/errors.hpp
R vendor/pdalboost/boost/test/utils/runtime/finalize.hpp
R vendor/pdalboost/boost/test/utils/runtime/fwd.hpp
R vendor/pdalboost/boost/test/utils/runtime/modifier.hpp
R vendor/pdalboost/boost/test/utils/runtime/parameter.hpp
R vendor/pdalboost/boost/test/utils/setcolor.hpp
R vendor/pdalboost/boost/test/utils/string_cast.hpp
R vendor/pdalboost/boost/test/utils/trivial_singleton.hpp
R vendor/pdalboost/boost/test/utils/wrap_stringstream.hpp
R vendor/pdalboost/boost/test/utils/xml_printer.hpp
R vendor/pdalboost/boost/timer/config.hpp
R vendor/pdalboost/doc/src/minimal.css
R vendor/pdalboost/libs/config/test/config_info.cpp
R vendor/pdalboost/libs/filesystem/doc/Jamfile.v2
R vendor/pdalboost/libs/filesystem/doc/POSIX_filename_encoding.txt
R vendor/pdalboost/libs/filesystem/doc/build_tutorial.bat
R vendor/pdalboost/libs/filesystem/doc/deprecated.html
R vendor/pdalboost/libs/filesystem/doc/design.htm
R vendor/pdalboost/libs/filesystem/doc/do_list.html
R vendor/pdalboost/libs/filesystem/doc/faq.htm
R vendor/pdalboost/libs/filesystem/doc/index.htm
R vendor/pdalboost/libs/filesystem/doc/issue_reporting.html
R vendor/pdalboost/libs/filesystem/doc/path_table.cpp
R vendor/pdalboost/libs/filesystem/doc/path_table.txt
R vendor/pdalboost/libs/filesystem/doc/portability_guide.htm
R vendor/pdalboost/libs/filesystem/doc/publish.bat
R vendor/pdalboost/libs/filesystem/doc/reference.html
R vendor/pdalboost/libs/filesystem/doc/relative_proposal.html
R vendor/pdalboost/libs/filesystem/doc/release_history.html
R vendor/pdalboost/libs/filesystem/doc/styles.css
R vendor/pdalboost/libs/filesystem/doc/tickets.html
R vendor/pdalboost/libs/filesystem/doc/tutorial.html
R vendor/pdalboost/libs/filesystem/doc/v3.html
R vendor/pdalboost/libs/filesystem/doc/v3_design.html
R vendor/pdalboost/libs/filesystem/example/Jamfile.v2
R vendor/pdalboost/libs/filesystem/example/directory_symlink_parent_resolution.cpp
R vendor/pdalboost/libs/filesystem/example/error_demo.cpp
R vendor/pdalboost/libs/filesystem/example/file_size.cpp
R vendor/pdalboost/libs/filesystem/example/file_status.cpp
R vendor/pdalboost/libs/filesystem/example/mbcopy.cpp
R vendor/pdalboost/libs/filesystem/example/mbpath.cpp
R vendor/pdalboost/libs/filesystem/example/mbpath.hpp
R vendor/pdalboost/libs/filesystem/example/msvc/common.props
R vendor/pdalboost/libs/filesystem/example/path_info.cpp
R vendor/pdalboost/libs/filesystem/example/simple_ls.cpp
R vendor/pdalboost/libs/filesystem/example/stems.cpp
R vendor/pdalboost/libs/filesystem/example/tchar.cpp
R vendor/pdalboost/libs/filesystem/example/test/Jamfile.v2
R vendor/pdalboost/libs/filesystem/example/test/build.bat
R vendor/pdalboost/libs/filesystem/example/test/build.sh
R vendor/pdalboost/libs/filesystem/example/test/setup.bat
R vendor/pdalboost/libs/filesystem/example/test/setup.sh
R vendor/pdalboost/libs/filesystem/example/tut0.cpp
R vendor/pdalboost/libs/filesystem/example/tut1.cpp
R vendor/pdalboost/libs/filesystem/example/tut2.cpp
R vendor/pdalboost/libs/filesystem/example/tut3.cpp
R vendor/pdalboost/libs/filesystem/example/tut4.cpp
R vendor/pdalboost/libs/filesystem/example/tut5.cpp
R vendor/pdalboost/libs/filesystem/example/tut6a.cpp
R vendor/pdalboost/libs/filesystem/example/tut6b.cpp
R vendor/pdalboost/libs/filesystem/example/tut6c.cpp
R vendor/pdalboost/libs/filesystem/test/Jamfile.v2
R vendor/pdalboost/libs/filesystem/test/convenience_test.cpp
R vendor/pdalboost/libs/filesystem/test/deprecated_test.cpp
R vendor/pdalboost/libs/filesystem/test/design_use_cases.cpp
R vendor/pdalboost/libs/filesystem/test/equivalent.cpp
R vendor/pdalboost/libs/filesystem/test/fstream_test.cpp
R vendor/pdalboost/libs/filesystem/test/issues/10038.cpp
R vendor/pdalboost/libs/filesystem/test/issues/10205.cpp
R vendor/pdalboost/libs/filesystem/test/issues/10485.cpp
R vendor/pdalboost/libs/filesystem/test/issues/10641.cpp
R vendor/pdalboost/libs/filesystem/test/issues/11166-remove-race.cpp
R vendor/pdalboost/libs/filesystem/test/issues/11228--filtered-recursive_directory_iterator-range.cpp
R vendor/pdalboost/libs/filesystem/test/issues/3332/test.cpp
R vendor/pdalboost/libs/filesystem/test/issues/4329.-basename.cpp
R vendor/pdalboost/libs/filesystem/test/issues/5300-temp-dir-path-130.cpp
R vendor/pdalboost/libs/filesystem/test/issues/6638-global-init-fails-3.cpp
R vendor/pdalboost/libs/filesystem/test/issues/8930.cpp
R vendor/pdalboost/libs/filesystem/test/issues/9054_static_const_codecvt_segfault_pre_main.cpp
R vendor/pdalboost/libs/filesystem/test/issues/9219.cpp
R vendor/pdalboost/libs/filesystem/test/issues/Jamfile.v2
R vendor/pdalboost/libs/filesystem/test/issues/boost-no-inspect
R vendor/pdalboost/libs/filesystem/test/issues/copy_file-compilation-error-2015-05-04.cpp
R vendor/pdalboost/libs/filesystem/test/issues/fchmodat_AT_SYMLINK_NOFOLLOW_6659.cpp
R vendor/pdalboost/libs/filesystem/test/issues/hello_filesystem.cpp
R vendor/pdalboost/libs/filesystem/test/issues/readme.txt
R vendor/pdalboost/libs/filesystem/test/issues/recurse_dir_iter_5403.cpp
R vendor/pdalboost/libs/filesystem/test/large_file_support_test.cpp
R vendor/pdalboost/libs/filesystem/test/locale_info.cpp
R vendor/pdalboost/libs/filesystem/test/long_path_test.cpp
R vendor/pdalboost/libs/filesystem/test/macro_default_test.cpp
R vendor/pdalboost/libs/filesystem/test/msvc/boost-no-inspect
R vendor/pdalboost/libs/filesystem/test/msvc/common.props
R vendor/pdalboost/libs/filesystem/test/odr1_test.cpp
R vendor/pdalboost/libs/filesystem/test/odr2_test.cpp
R vendor/pdalboost/libs/filesystem/test/operations_test.cpp
R vendor/pdalboost/libs/filesystem/test/operations_unit_test.cpp
R vendor/pdalboost/libs/filesystem/test/path_test.cpp
R vendor/pdalboost/libs/filesystem/test/path_times.cpp
R vendor/pdalboost/libs/filesystem/test/path_unit_test.cpp
R vendor/pdalboost/libs/filesystem/test/relative_test.cpp
R vendor/pdalboost/libs/filesystem/test/sample_test.cpp
R vendor/pdalboost/libs/filesystem/test/test_codecvt.hpp
R vendor/pdalboost/libs/filesystem/test/windows_attributes.cpp
R vendor/pdalboost/libs/iostreams/test/Jamfile.v2
R vendor/pdalboost/libs/iostreams/test/array_test.cpp
R vendor/pdalboost/libs/iostreams/test/auto_close_test.cpp
R vendor/pdalboost/libs/iostreams/test/bool_trait_test.cpp
R vendor/pdalboost/libs/iostreams/test/buffer_size_test.cpp
R vendor/pdalboost/libs/iostreams/test/bzip2_test.cpp
R vendor/pdalboost/libs/iostreams/test/close_test.cpp
R vendor/pdalboost/libs/iostreams/test/code_converter_test.cpp
R vendor/pdalboost/libs/iostreams/test/combine_test.cpp
R vendor/pdalboost/libs/iostreams/test/component_access_test.cpp
R vendor/pdalboost/libs/iostreams/test/compose_test.cpp
R vendor/pdalboost/libs/iostreams/test/copy_test.cpp
R vendor/pdalboost/libs/iostreams/test/counter_test.cpp
R vendor/pdalboost/libs/iostreams/test/deprecated_file_descriptor_test.cpp
R vendor/pdalboost/libs/iostreams/test/detail/closable.hpp
R vendor/pdalboost/libs/iostreams/test/detail/constants.hpp
R vendor/pdalboost/libs/iostreams/test/detail/file_handle.hpp
R vendor/pdalboost/libs/iostreams/test/detail/filters.hpp
R vendor/pdalboost/libs/iostreams/test/detail/null_padded_codecvt.hpp
R vendor/pdalboost/libs/iostreams/test/detail/operation_sequence.hpp
R vendor/pdalboost/libs/iostreams/test/detail/sequence.hpp
R vendor/pdalboost/libs/iostreams/test/detail/temp_file.hpp
R vendor/pdalboost/libs/iostreams/test/detail/utf8_codecvt_facet.cpp
R vendor/pdalboost/libs/iostreams/test/detail/utf8_codecvt_facet.hpp
R vendor/pdalboost/libs/iostreams/test/detail/verification.hpp
R vendor/pdalboost/libs/iostreams/test/direct_adapter_test.cpp
R vendor/pdalboost/libs/iostreams/test/example_test.cpp
R vendor/pdalboost/libs/iostreams/test/execute_test.cpp
R vendor/pdalboost/libs/iostreams/test/file_descriptor_test.cpp
R vendor/pdalboost/libs/iostreams/test/file_test.cpp
R vendor/pdalboost/libs/iostreams/test/filter_test.cpp
R vendor/pdalboost/libs/iostreams/test/filtering_stream_flush_test.hpp
R vendor/pdalboost/libs/iostreams/test/filtering_stream_test.cpp
R vendor/pdalboost/libs/iostreams/test/finite_state_filter_test.cpp
R vendor/pdalboost/libs/iostreams/test/flush_test.cpp
R vendor/pdalboost/libs/iostreams/test/grep_test.cpp
R vendor/pdalboost/libs/iostreams/test/gzip_test.cpp
R vendor/pdalboost/libs/iostreams/test/invert_test.cpp
R vendor/pdalboost/libs/iostreams/test/large_file_test.cpp
R vendor/pdalboost/libs/iostreams/test/line_filter_test.cpp
R vendor/pdalboost/libs/iostreams/test/mapped_file_test.cpp
R vendor/pdalboost/libs/iostreams/test/newline_test.cpp
R vendor/pdalboost/libs/iostreams/test/null_test.cpp
R vendor/pdalboost/libs/iostreams/test/operation_sequence_test.cpp
R vendor/pdalboost/libs/iostreams/test/path_test.cpp
R vendor/pdalboost/libs/iostreams/test/pipeline_test.cpp
R vendor/pdalboost/libs/iostreams/test/putback_test.hpp
R vendor/pdalboost/libs/iostreams/test/read_bidir_filter_test.hpp
R vendor/pdalboost/libs/iostreams/test/read_bidir_streambuf_test.hpp
R vendor/pdalboost/libs/iostreams/test/read_bidir_test.hpp
R vendor/pdalboost/libs/iostreams/test/read_input_filter_test.hpp
R vendor/pdalboost/libs/iostreams/test/read_input_istream_test.hpp
R vendor/pdalboost/libs/iostreams/test/read_input_seq_test.hpp
R vendor/pdalboost/libs/iostreams/test/read_input_test.hpp
R vendor/pdalboost/libs/iostreams/test/read_seekable_seq_test.hpp
R vendor/pdalboost/libs/iostreams/test/read_seekable_test.hpp
R vendor/pdalboost/libs/iostreams/test/regex_filter_test.cpp
R vendor/pdalboost/libs/iostreams/test/restrict_test.cpp
R vendor/pdalboost/libs/iostreams/test/seek_test.hpp
R vendor/pdalboost/libs/iostreams/test/seekable_file_test.cpp
R vendor/pdalboost/libs/iostreams/test/seekable_filter_test.cpp
R vendor/pdalboost/libs/iostreams/test/sequence_test.cpp
R vendor/pdalboost/libs/iostreams/test/slice_test.cpp
R vendor/pdalboost/libs/iostreams/test/stdio_filter_test.cpp
R vendor/pdalboost/libs/iostreams/test/stream_offset_32bit_test.cpp
R vendor/pdalboost/libs/iostreams/test/stream_offset_64bit_test.cpp
R vendor/pdalboost/libs/iostreams/test/stream_state_test.cpp
R vendor/pdalboost/libs/iostreams/test/symmetric_filter_test.cpp
R vendor/pdalboost/libs/iostreams/test/tee_test.cpp
R vendor/pdalboost/libs/iostreams/test/wide_stream_test.cpp
R vendor/pdalboost/libs/iostreams/test/windows_pipe_test.cpp
R vendor/pdalboost/libs/iostreams/test/write_bidir_filter_test.hpp
R vendor/pdalboost/libs/iostreams/test/write_bidir_streambuf_test.hpp
R vendor/pdalboost/libs/iostreams/test/write_bidir_test.hpp
R vendor/pdalboost/libs/iostreams/test/write_output_filter_test.hpp
R vendor/pdalboost/libs/iostreams/test/write_output_iterator_test.hpp
R vendor/pdalboost/libs/iostreams/test/write_output_ostream_test.hpp
R vendor/pdalboost/libs/iostreams/test/write_output_seq_test.hpp
R vendor/pdalboost/libs/iostreams/test/write_output_test.hpp
R vendor/pdalboost/libs/iostreams/test/write_seekable_seq_test.hpp
R vendor/pdalboost/libs/iostreams/test/write_seekable_test.hpp
R vendor/pdalboost/libs/iostreams/test/zlib_test.cpp
R vendor/pdalboost/libs/program_options/doc/Jamfile.v2
R vendor/pdalboost/libs/program_options/doc/acknowledgements.xml
R vendor/pdalboost/libs/program_options/doc/alternatives
R vendor/pdalboost/libs/program_options/doc/changes.xml
R vendor/pdalboost/libs/program_options/doc/design.xml
R vendor/pdalboost/libs/program_options/doc/glossary.dox
R vendor/pdalboost/libs/program_options/doc/glossary.xml
R vendor/pdalboost/libs/program_options/doc/howto.xml
R vendor/pdalboost/libs/program_options/doc/index.html
R vendor/pdalboost/libs/program_options/doc/overview.xml
R vendor/pdalboost/libs/program_options/doc/post_review_plan.txt
R vendor/pdalboost/libs/program_options/doc/program_options.dox
R vendor/pdalboost/libs/program_options/doc/program_options.ent
R vendor/pdalboost/libs/program_options/doc/program_options.xml
R vendor/pdalboost/libs/program_options/doc/questions
R vendor/pdalboost/libs/program_options/doc/questions.dox
R vendor/pdalboost/libs/program_options/doc/rationale
R vendor/pdalboost/libs/program_options/doc/rationale.dox
R vendor/pdalboost/libs/program_options/doc/recipes.dox
R vendor/pdalboost/libs/program_options/doc/requirements-Rozental
R vendor/pdalboost/libs/program_options/doc/todo.txt
R vendor/pdalboost/libs/program_options/doc/tutorial.xml
R vendor/pdalboost/libs/program_options/example/Jamfile.v2
R vendor/pdalboost/libs/program_options/example/custom_syntax.cpp
R vendor/pdalboost/libs/program_options/example/first.cpp
R vendor/pdalboost/libs/program_options/example/multiple_sources.cfg
R vendor/pdalboost/libs/program_options/example/multiple_sources.cpp
R vendor/pdalboost/libs/program_options/example/option_groups.cpp
R vendor/pdalboost/libs/program_options/example/options_description.cpp
R vendor/pdalboost/libs/program_options/example/real.cpp
R vendor/pdalboost/libs/program_options/example/regex.cpp
R vendor/pdalboost/libs/program_options/example/response_file.cpp
R vendor/pdalboost/libs/program_options/example/response_file.rsp
R vendor/pdalboost/libs/program_options/index.html
R vendor/pdalboost/libs/program_options/meta/libraries.json
R vendor/pdalboost/libs/program_options/src/cmdline.cpp
R vendor/pdalboost/libs/program_options/src/config_file.cpp
R vendor/pdalboost/libs/program_options/src/convert.cpp
R vendor/pdalboost/libs/program_options/src/options_description.cpp
R vendor/pdalboost/libs/program_options/src/parsers.cpp
R vendor/pdalboost/libs/program_options/src/positional_options.cpp
R vendor/pdalboost/libs/program_options/src/split.cpp
R vendor/pdalboost/libs/program_options/src/utf8_codecvt_facet.cpp
R vendor/pdalboost/libs/program_options/src/value_semantic.cpp
R vendor/pdalboost/libs/program_options/src/variables_map.cpp
R vendor/pdalboost/libs/program_options/src/winmain.cpp
R vendor/pdalboost/libs/program_options/test/Jamfile.v2
R vendor/pdalboost/libs/program_options/test/cmdline_test.cpp
R vendor/pdalboost/libs/program_options/test/config_test.cfg
R vendor/pdalboost/libs/program_options/test/exception_test.cpp
R vendor/pdalboost/libs/program_options/test/exception_txt_test.cpp
R vendor/pdalboost/libs/program_options/test/minitest.hpp
R vendor/pdalboost/libs/program_options/test/options_description_test.cpp
R vendor/pdalboost/libs/program_options/test/parsers_test.cpp
R vendor/pdalboost/libs/program_options/test/positional_options_test.cpp
R vendor/pdalboost/libs/program_options/test/program_options_size_test.py
R vendor/pdalboost/libs/program_options/test/required_test.cfg
R vendor/pdalboost/libs/program_options/test/required_test.cpp
R vendor/pdalboost/libs/program_options/test/split_test.cpp
R vendor/pdalboost/libs/program_options/test/test_convert.cpp
R vendor/pdalboost/libs/program_options/test/ucs2.txt
R vendor/pdalboost/libs/program_options/test/unicode_test.cpp
R vendor/pdalboost/libs/program_options/test/unrecognized_test.cpp
R vendor/pdalboost/libs/program_options/test/utf8.txt
R vendor/pdalboost/libs/program_options/test/variable_map_test.cpp
R vendor/pdalboost/libs/program_options/test/winmain.cpp
R vendor/pdalboost/libs/program_options/test/winmain.py
R vendor/pdalboost/libs/property_tree/test/Jamfile.v2
R vendor/pdalboost/libs/property_tree/test/custom-build/Makefile-Common
R vendor/pdalboost/libs/property_tree/test/custom-build/debug_settings.xml
R vendor/pdalboost/libs/property_tree/test/custom-build/gcc.mak
R vendor/pdalboost/libs/property_tree/test/custom-build/icc.mak
R vendor/pdalboost/libs/property_tree/test/custom-build/sandbox.vcproj
R vendor/pdalboost/libs/property_tree/test/custom-build/settings_fully-existent.info
R vendor/pdalboost/libs/property_tree/test/custom-build/settings_non-existent.info
R vendor/pdalboost/libs/property_tree/test/custom-build/settings_partially-existent.info
R vendor/pdalboost/libs/property_tree/test/custom-build/test_example_custom_data_type.vcproj
R vendor/pdalboost/libs/property_tree/test/custom-build/test_example_debug_settings.vcproj
R vendor/pdalboost/libs/property_tree/test/custom-build/test_example_empty_ptree_trick.vcproj
R vendor/pdalboost/libs/property_tree/test/custom-build/test_info_grammar_spirit.vcproj
R vendor/pdalboost/libs/property_tree/test/custom-build/test_info_parser.vcproj
R vendor/pdalboost/libs/property_tree/test/custom-build/test_ini_parser.vcproj
R vendor/pdalboost/libs/property_tree/test/custom-build/test_json_parser.vcproj
R vendor/pdalboost/libs/property_tree/test/custom-build/test_multi_module.vcproj
R vendor/pdalboost/libs/property_tree/test/custom-build/test_property_tree.vcproj
R vendor/pdalboost/libs/property_tree/test/custom-build/test_xml_parser.vcproj
R vendor/pdalboost/libs/property_tree/test/custom-build/vc.mak
R vendor/pdalboost/libs/property_tree/test/prefixing_callbacks.hpp
R vendor/pdalboost/libs/property_tree/test/sandbox.cpp
R vendor/pdalboost/libs/property_tree/test/test_info_parser.cpp
R vendor/pdalboost/libs/property_tree/test/test_ini_parser.cpp
R vendor/pdalboost/libs/property_tree/test/test_json_parser.cpp
R vendor/pdalboost/libs/property_tree/test/test_json_parser2.cpp
R vendor/pdalboost/libs/property_tree/test/test_multi_module1.cpp
R vendor/pdalboost/libs/property_tree/test/test_multi_module2.cpp
R vendor/pdalboost/libs/property_tree/test/test_property_tree.cpp
R vendor/pdalboost/libs/property_tree/test/test_property_tree.hpp
R vendor/pdalboost/libs/property_tree/test/test_utils.hpp
R vendor/pdalboost/libs/property_tree/test/test_xml_parser_common.hpp
R vendor/pdalboost/libs/property_tree/test/test_xml_parser_rapidxml.cpp
R vendor/pdalboost/libs/property_tree/test/xml_parser_test_data.hpp
R vendor/pdalboost/libs/regex/test/config_info/regex_config_info.cpp
R vendor/pdalboost/libs/system/doc/index.html
R vendor/pdalboost/libs/system/doc/reference.html
R vendor/pdalboost/libs/system/test/Jamfile.v2
R vendor/pdalboost/libs/system/test/config_test.cpp
R vendor/pdalboost/libs/system/test/dynamic_link_test.cpp
R vendor/pdalboost/libs/system/test/error_code_test.cpp
R vendor/pdalboost/libs/system/test/error_code_user_test.cpp
R vendor/pdalboost/libs/system/test/header_only_test.cpp
R vendor/pdalboost/libs/system/test/initialization_test.cpp
R vendor/pdalboost/libs/system/test/system/common.props
R vendor/pdalboost/libs/system/test/system_error_test.cpp
R vendor/pdalboost/libs/system/test/throw_test.cpp
R vendor/pdalboost/libs/test/src/compiler_log_formatter.cpp
R vendor/pdalboost/libs/test/src/cpp_main.cpp
R vendor/pdalboost/libs/test/src/debug.cpp
R vendor/pdalboost/libs/test/src/decorator.cpp
R vendor/pdalboost/libs/test/src/execution_monitor.cpp
R vendor/pdalboost/libs/test/src/framework.cpp
R vendor/pdalboost/libs/test/src/plain_report_formatter.cpp
R vendor/pdalboost/libs/test/src/progress_monitor.cpp
R vendor/pdalboost/libs/test/src/results_collector.cpp
R vendor/pdalboost/libs/test/src/results_reporter.cpp
R vendor/pdalboost/libs/test/src/test_main.cpp
R vendor/pdalboost/libs/test/src/test_tools.cpp
R vendor/pdalboost/libs/test/src/test_tree.cpp
R vendor/pdalboost/libs/test/src/unit_test_log.cpp
R vendor/pdalboost/libs/test/src/unit_test_main.cpp
R vendor/pdalboost/libs/test/src/unit_test_monitor.cpp
R vendor/pdalboost/libs/test/src/unit_test_parameters.cpp
R vendor/pdalboost/libs/test/src/xml_log_formatter.cpp
R vendor/pdalboost/libs/test/src/xml_report_formatter.cpp
R vendor/pdalboost/libs/uuid/test/Jamfile.v2
R vendor/pdalboost/libs/uuid/test/compile_name_generator.cpp
R vendor/pdalboost/libs/uuid/test/compile_nil_generator.cpp
R vendor/pdalboost/libs/uuid/test/compile_random_generator.cpp
R vendor/pdalboost/libs/uuid/test/compile_seed_rng.cpp
R vendor/pdalboost/libs/uuid/test/compile_string_generator.cpp
R vendor/pdalboost/libs/uuid/test/compile_uuid.cpp
R vendor/pdalboost/libs/uuid/test/compile_uuid_generators.cpp
R vendor/pdalboost/libs/uuid/test/compile_uuid_io.cpp
R vendor/pdalboost/libs/uuid/test/compile_uuid_serialize.cpp
R vendor/pdalboost/libs/uuid/test/test_generators.cpp
R vendor/pdalboost/libs/uuid/test/test_include1.cpp
R vendor/pdalboost/libs/uuid/test/test_include2.cpp
R vendor/pdalboost/libs/uuid/test/test_io.cpp
R vendor/pdalboost/libs/uuid/test/test_msvc_simd_bug981648.hpp
R vendor/pdalboost/libs/uuid/test/test_msvc_simd_bug981648_foo.cpp
R vendor/pdalboost/libs/uuid/test/test_msvc_simd_bug981648_main.cpp
R vendor/pdalboost/libs/uuid/test/test_name_generator.cpp
R vendor/pdalboost/libs/uuid/test/test_nil_generator.cpp
R vendor/pdalboost/libs/uuid/test/test_random_generator.cpp
R vendor/pdalboost/libs/uuid/test/test_serialization.cpp
R vendor/pdalboost/libs/uuid/test/test_sha1.cpp
R vendor/pdalboost/libs/uuid/test/test_string_generator.cpp
R vendor/pdalboost/libs/uuid/test/test_tagging.cpp
R vendor/pdalboost/libs/uuid/test/test_uuid.cpp
R vendor/pdalboost/libs/uuid/test/test_uuid_class.cpp
R vendor/pdalboost/libs/uuid/test/test_uuid_in_map.cpp
R vendor/pdalboost/libs/uuid/test/test_uuid_no_simd.cpp
R vendor/pdalboost/libs/uuid/test/test_wserialization.cpp
Log Message:
Don't bleed PDAL build info into subprojects (#1998)
* Don't bleed PDAL options into other projects.
* Don't make libraries PDAL needs part of the external link interface.
* Link with util since we haven't installed.
* Remove stray paren.
* Add back variable so we don't require boost libraries.
* Remove much boost.
* Re-enable NOMINMAX.
* Add winsock back :(
* Add winsock.
* Test.
* Run cmake in verbose mode.
* Move Uuid code to .cpp file to simplify Windows linking.
* Revert "Move Uuid code to .cpp file to simplify Windows linking."
This reverts commit b063449f99aea3d250811b1cdaa4187c087efda7.
* Link with necessary target-based libraries.
* NITF needs GDAL, apparently.
* Make C++11 really required.
Small clean-ups.
* Remove GDAL link for NITF tests.
* Use if-logic that works on older cmake.
**NOTE:** This service been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits
