[pdal-commits] [PDAL/PDAL] 03a500: Changes to make GCC 8 happy. (#2012)
GitHub noreply at github.com
Fri May 11 11:34:50 PDT 2018
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 03a500979a51031c1c14a7eccf13e763c1ffccb6
      https://github.com/PDAL/PDAL/commit/03a500979a51031c1c14a7eccf13e763c1ffccb6
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2018-05-11 (Fri, 11 May 2018)
  Changed paths:
    M cmake/unix_compiler_options.cmake
    M filters/AssignFilter.cpp
    M io/LasHeader.cpp
    M io/PlyReader.cpp
    M io/PlyWriter.cpp
    M kernels/TIndexKernel.cpp
    M pdal/Kernel.cpp
    M pdal/Metadata.cpp
    M pdal/Metadata.hpp
    M pdal/PDALUtils.cpp
    M pdal/pdal_types.hpp
    M pdal/util/FileUtils.cpp
    M pdal/util/Utils.hpp
    M vendor/arbiter/arbiter.cpp
    M vendor/kazhdan/Array.h
    M vendor/kazhdan/MultiGridOctreeData.System.inl
    M vendor/kazhdan/MultiGridOctreeData.h
    M vendor/kazhdan/MultiGridOctreeData.inl
    M vendor/kazhdan/PPolynomial.inl
    M vendor/kazhdan/PoissonRecon.h
    M vendor/pdalboost/boost/mpl/assert.hpp
  Log Message:
* Changes to make GCC 8 happy.
Properly handle Metadata::value<std::string>()
* Make sure returned value is properly initialized.
      **NOTE:** This service been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
      Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits mailing list
