[pdal-commits] [PDAL/PDAL] 30c368: PCL plugin still requires that we have Eigen insta...
    GitHub
    noreply at github.com
    Thu May 31 08:10:14 PDT 2018
  Branch: refs/heads/conda-build-based-travis
  Home:   https://github.com/PDAL/PDAL
  Commit: 30c3687e5092a3c50704f61181b93325651db570
      https://github.com/PDAL/PDAL/commit/30c3687e5092a3c50704f61181b93325651db570
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2018-05-31 (Thu, 31 May 2018)
  Changed paths:
    M scripts/ci/meta.yaml
  Log Message:
  PCL plugin still requires that we have Eigen installed (should probably change this to do what the rest of the library does)
      **NOTE:** This service been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
      Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits
