[pdal-commits] [PDAL/PDAL] 931b0d: Make sure scaling works for BPF and LAS when using...
GitHub noreply at github.com
Wed Nov 7 14:13:33 PST 2018
  Branch: refs/heads/issue-1983
  Home:   https://github.com/PDAL/PDAL
  Commit: 931b0d77165b3cab9eee1180a623199f1001ca44
      https://github.com/PDAL/PDAL/commit/931b0d77165b3cab9eee1180a623199f1001ca44
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2018-11-07 (Wed, 07 Nov 2018)
  Changed paths:
    M io/BpfWriter.cpp
    M io/BpfWriter.hpp
    M io/LasWriter.cpp
    M io/LasWriter.hpp
    M pdal/DbWriter.cpp
    M pdal/FlexWriter.hpp
    M pdal/PointView.cpp
    M pdal/PointView.hpp
    M pdal/Scaling.cpp
    M pdal/Scaling.hpp
    M pdal/Stage.cpp
    M pdal/Stage.hpp
    M test/unit/PointViewTest.cpp
    M test/unit/io/LasWriterTest.cpp
  Log Message:
  Make sure scaling works for BPF and LAS when using multiple inputs and
a single output.
Close #1983
      **NOTE:** This service has been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
      Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits mailing list
