[pdal-commits] [PDAL/PDAL] 3ca5e7: * Write polygon with sufficient precision when usi...
    GitHub
    noreply at github.com
    Fri Nov 16 07:08:15 PST 2018
  Branch: refs/heads/1.8-maintenance
  Home:   https://github.com/PDAL/PDAL
  Commit: 3ca5e72a85f55d4918e953153106676c360ca655
      https://github.com/PDAL/PDAL/commit/3ca5e72a85f55d4918e953153106676c360ca655
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2018-11-16 (Fri, 16 Nov 2018)
  Changed paths:
    M kernels/TIndexKernel.cpp
  Log Message:
  * Write polygon with sufficient precision when using fast_boundary.
Fix conversion of WKT to EPSG code.
Close #2271
* Remove stray output.
      **NOTE:** This service has been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
      Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits
