[pdal-commits] [PDAL/PDAL] daa8a5: I3S and SLPK readers (#2176)
GitHub
noreply at github.com
Fri Oct 5 07:40:56 PDT 2018
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: daa8a505ccf04be26c582a67abc394e8cc55d3a6
https://github.com/PDAL/PDAL/commit/daa8a505ccf04be26c582a67abc394e8cc55d3a6
Author: Kyle Mann <39525199+kylemann16 at users.noreply.github.com>
Date: 2018-10-05 (Fri, 05 Oct 2018)
Changed paths:
M appveyor.yml
M cmake/examples/hobu-config.sh
M cmake/examples/hobu-windows.bat
M cmake/options.cmake
A doc/stages/readers.i3s.rst
A doc/stages/readers.slpk.rst
M pdal/StageExtensions.cpp
M pdal/StageFactory.cpp
M pdal/util/FileUtils.cpp
M pdal/util/FileUtils.hpp
M plugins/CMakeLists.txt
A plugins/i3s/CMakeLists.txt
A plugins/i3s/io/EsriReader.cpp
A plugins/i3s/io/EsriReader.hpp
A plugins/i3s/io/EsriUtil.cpp
A plugins/i3s/io/EsriUtil.hpp
A plugins/i3s/io/I3SReader.cpp
A plugins/i3s/io/I3SReader.hpp
A plugins/i3s/io/SlpkExtractor.cpp
A plugins/i3s/io/SlpkExtractor.hpp
A plugins/i3s/io/SlpkReader.cpp
A plugins/i3s/io/SlpkReader.hpp
A plugins/i3s/io/pool.hpp
A plugins/i3s/lepcc/CMakeLists.txt
A plugins/i3s/lepcc/src/BitMask.cpp
A plugins/i3s/lepcc/src/BitMask.h
A plugins/i3s/lepcc/src/BitStuffer2.cpp
A plugins/i3s/lepcc/src/BitStuffer2.h
A plugins/i3s/lepcc/src/ClusterRGB.cpp
A plugins/i3s/lepcc/src/ClusterRGB.h
A plugins/i3s/lepcc/src/Common.cpp
A plugins/i3s/lepcc/src/Common.h
A plugins/i3s/lepcc/src/FlagBytes.cpp
A plugins/i3s/lepcc/src/FlagBytes.h
A plugins/i3s/lepcc/src/Huffman.cpp
A plugins/i3s/lepcc/src/Huffman.h
A plugins/i3s/lepcc/src/Intensity.cpp
A plugins/i3s/lepcc/src/Intensity.h
A plugins/i3s/lepcc/src/LEPCC.cpp
A plugins/i3s/lepcc/src/LEPCC.h
A plugins/i3s/lepcc/src/Test_C_Api.cpp
A plugins/i3s/lepcc/src/include/lepcc_c_api.h
A plugins/i3s/lepcc/src/include/lepcc_tpl_api.h
A plugins/i3s/lepcc/src/include/lepcc_types.h
A plugins/i3s/lepcc/src/lepcc_c_api_impl.cpp
A plugins/i3s/lepcc/src/utl_const_array.h
A plugins/i3s/test/SlpkReaderTest.cpp
A plugins/i3s/test/i3sReaderTest.cpp
M scripts/appveyor/config.cmd
M scripts/appveyor/test.cmd
M scripts/ci/script.sh
A test/data/i3s/SMALL_AUTZEN_LAS_All .zip
A test/data/i3s/SMALL_AUTZEN_LAS_All.bin
A test/data/i3s/SMALL_AUTZEN_LAS_All.slpk
A test/data/i3s/SMALL_AUTZEN_LAS_All/3dSceneLayer.json.gz
A test/data/i3s/SMALL_AUTZEN_LAS_All/@specialIndexFileHASH128@
A test/data/i3s/SMALL_AUTZEN_LAS_All/metadata.json
A test/data/i3s/SMALL_AUTZEN_LAS_All/nodepages/0.json.gz
A test/data/i3s/SMALL_AUTZEN_LAS_All/nodes/0/attributes/1024.bin.gz
A test/data/i3s/SMALL_AUTZEN_LAS_All/nodes/0/attributes/128.bin.gz
A test/data/i3s/SMALL_AUTZEN_LAS_All/nodes/0/attributes/16.bin.gz
A test/data/i3s/SMALL_AUTZEN_LAS_All/nodes/0/attributes/2.bin.pccint
A test/data/i3s/SMALL_AUTZEN_LAS_All/nodes/0/attributes/256.bin.gz
A test/data/i3s/SMALL_AUTZEN_LAS_All/nodes/0/attributes/32.bin.gz
A test/data/i3s/SMALL_AUTZEN_LAS_All/nodes/0/attributes/512.bin.gz
A test/data/i3s/SMALL_AUTZEN_LAS_All/nodes/0/attributes/8.bin.gz
A test/data/i3s/SMALL_AUTZEN_LAS_All/nodes/0/geometries/0.bin.pccxyz
A test/data/i3s/SMALL_AUTZEN_LAS_All/statistics/1.json.gz
A test/data/i3s/SMALL_AUTZEN_LAS_All/statistics/1024.json.gz
A test/data/i3s/SMALL_AUTZEN_LAS_All/statistics/128.json.gz
A test/data/i3s/SMALL_AUTZEN_LAS_All/statistics/16.json.gz
A test/data/i3s/SMALL_AUTZEN_LAS_All/statistics/2.json.gz
A test/data/i3s/SMALL_AUTZEN_LAS_All/statistics/256.json.gz
A test/data/i3s/SMALL_AUTZEN_LAS_All/statistics/32.json.gz
A test/data/i3s/SMALL_AUTZEN_LAS_All/statistics/512.json.gz
A test/data/i3s/SMALL_AUTZEN_LAS_All/statistics/8.json.gz
A test/data/i3s/plineAutzen.json
A test/data/i3s/plineHelsinki.json
M vendor/arbiter/arbiter.hpp
Log Message:
* scans info file and adds dimensions to pointtable layout
* reads binary files from geometries url'
* added lepcc src files to i3s
* Update arbiter bundle for gzip decompression support.
* Add include.
* Include guards.
* Try bundling rapidxml before gzip.
* got decompression working and put into view. need to add gzip decomp and search children nodes
* translates all node geometries, but only xyz's
* RGB, Intensity, XYZ working. Reading only from leaf nodes currently.
* Add include.
* Include guards.
* updated lepcc repo
* can't get m_arbiter to be declared in lambda scope
* Threading with 2 pools
* Threading works. Adding args
* bounds and thread counts working. tested with info and translate on provided autzen i3s file
* remove tailing / from input url
* making qol improvements
* now working with oriented bounding boxes
* added test files for i3sreader
* pre fetch commit
* Add SlpkExtractor.
* added test file
* can now read slpk as well as from http, created tests for bounding in local and remote files with autzen and small autzen
* added string include to clusterRGB
* added overrides and changed iterator to size_t to match size()
* made visual changes
* A bit of styling consistency.
* More no-op styling tweaks.
* added copyrights
* changed catch to fileExists test. Added slpk to stage extensions
* created docs
* style changes to i3s doc, added doc link to i3sReader.cpp
* added copyright
* Virtualize i3s/slpk readers.
* quat changes
* Quaternion calculations.
* Add pseudo-code for generic i3s dimension handling.
* dimension changes
* Get generic types working.
* String comparison.
* set as changes
* Fix SRS handling.
* changed dimensions for fewer elses
* added slpk reader doc and slpk from i3s doc
* changed loop in esrireader to not use errors. Throw errors on bad lepcc decompressions. Removed random if statement in infokernel. Other minor style fixes.
* removed couts
* Don't change byte order of magic number.
* Better description for createDirectories.
* Made requested changes: shortened file Utils, fixed bad copies in decompression
* adding throwErrors and minor adjustments
* changed from EsriReceiver to EsriUtil. Made some clearer variable names in parsebox
* Doc typos
* Add json check
* added else for undefined dimension
* changed json to be correct
* added dimType map. fixed json test
* elevation no longer inserts to dimmap
* added zlib check to cmake
* fixed thread problems, added await(), added size checks on data)
* switch on I3S
* I3S for appveyor
* fixed test file, fixed if else chain in addDimensions
* get windows happier
* fetch cacert so curl works for ssl, only output curl noise in debug mode
* make I3S tests an optional build/run -- the SLPK reader tests the basic software, and the I3S does remote-over-the-internet requests which take about 60s. to run
* added json checks
* added dimensions option
* added dimensions to docs and made them case insensitive
* unpacking returns correctly
* added lod option and corresponding examples in docs
* added lod tests
* changed lod to depth of node tree
* added depth test
* changed depth to min and max density searches
* updated docs
* adjusted std::max and density logic
* changed parentheses locations
* look for nodePerIndexPage in json
* works with Esri pointcloud 1.6 as long as it's lepcc encoding
* added version functionality. added pipeline jsons to test/data/i3s
* Remove much include file cruft.
Remove EsriUtil code from global pdal namespace.
Use consistent throw/catch.
Formatting stuff.
Various small changes.
* Remove comment.
* added retry block
* removed cout
* changed continue to break in retry
* Simplify ternary logic.
* changed try logic
* Don't throwError() on last line to avoid return warning.
* Fix logic bug.
* changed i3s test variable
* Build cleanup.
* Update arbiter bundle for namespacing gzip functionality.
**NOTE:** This service has been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits
