[pdal-commits] [PDAL/PDAL] 81e952: Compare SRS directly in test, use quick-info outpu...
GitHub
noreply at github.com
Fri Oct 5 08:52:16 PDT 2018
Branch: refs/heads/default-srs
Home: https://github.com/PDAL/PDAL
Commit: 81e952432c2295dbfcf3b0813d4d6a2cda7f0e44
https://github.com/PDAL/PDAL/commit/81e952432c2295dbfcf3b0813d4d6a2cda7f0e44
Author: Connor Manning <connor at hobu.co>
Date: 2018-10-05 (Fri, 05 Oct 2018)
Changed paths:
M test/unit/SpatialReferenceTest.cpp
Log Message:
Compare SRS directly in test, use quick-info output to test against.
**NOTE:** This service has been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits
