[pdal-commits] [PDAL/PDAL] 8cfa74: Default/override SRS options for all readers (#221...
GitHub
noreply at github.com
Mon Oct 15 05:28:38 PDT 2018
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 8cfa74929831ddea8080bd5a6b64dd36d238374e
https://github.com/PDAL/PDAL/commit/8cfa74929831ddea8080bd5a6b64dd36d238374e
Author: Connor Manning <connor at hobu.co>
Date: 2018-10-15 (Mon, 15 Oct 2018)
Changed paths:
M io/BpfReader.cpp
M io/EptReader.cpp
M io/GDALReader.cpp
M io/Ilvis2Reader.cpp
M io/LasReader.cpp
M io/OptechReader.cpp
M io/TIndexReader.cpp
M pdal/Reader.cpp
M pdal/Reader.hpp
M pdal/Stage.cpp
M pdal/Stage.hpp
M plugins/greyhound/io/GreyhoundReader.cpp
M plugins/icebridge/io/IcebridgeReader.cpp
M plugins/matlab/io/MatlabReader.cpp
M plugins/pgpointcloud/io/PgReader.cpp
M plugins/rdb/io/RdbReader.cpp
M test/unit/SpatialReferenceTest.cpp
Log Message:
Default/override SRS options for all readers (#2210)
* Add default_srs and override_srs reader options. Make addSpatialReference apply this logic instead of each reader.
* Use addSynonym for override_srs/spatialreference args instead of double-registering.
* Handle default/override-SRS options in Reader.
* Remove addSpatialReferenceArg call from PgReader - this is now handled at the Reader level.
* Remove useless try/catch.
* Correct comment.
* Throw if both default and override SRS options are set.
* Debug log if setSpatialReference no-ops due to an override existing.
* Compare SRS directly in test, use quick-info output to test against.
* Naming.
* Isolate override/default SRS members to Reader.
* Use Srs::valid instead of negating Srs::empty.
* Maintain public visibility of Stage::setSpatialReference within derived Reader.
**NOTE:** This service has been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits
