[pdal-commits] [PDAL/PDAL] 64abe7: Support cast of double -> float of NaN. (#2240)
GitHub noreply at github.com
Wed Oct 24 08:36:31 PDT 2018
  Branch: refs/heads/conda-windows-tests
  Home:   https://github.com/PDAL/PDAL
  Commit: 64abe7b02aa56c68cbb3f3b360bc5a186940cfe9
      https://github.com/PDAL/PDAL/commit/64abe7b02aa56c68cbb3f3b360bc5a186940cfe9
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2018-10-23 (Tue, 23 Oct 2018)
  Changed paths:
    M pdal/PointView.hpp
    M pdal/util/Utils.hpp
    M test/unit/PointViewTest.cpp
    M test/unit/UtilsTest.cpp
  Log Message:
* Support cast of double -> float of NaN.
Close #2239
* Actually test something in the test.
  Commit: 1b4d902b76260584004f3b858687c295dd254a1a
      https://github.com/PDAL/PDAL/commit/1b4d902b76260584004f3b858687c295dd254a1a
  Date:   2018-10-24 (Wed, 24 Oct 2018)
  Changed paths:
    M filters/DividerFilter.cpp
    M io/HeaderVal.hpp
  Log Message:
  Make sure uint8_t gets converted to a reasonable string. (#2244)
Don't use strange characters in description.
Close #2242
  Commit: 8e618d467863f296617e5b97b0495558b7e67c0b
      https://github.com/PDAL/PDAL/commit/8e618d467863f296617e5b97b0495558b7e67c0b
  Changed paths:
    M plugins/rxp/io/RxpReader.cpp
  Log Message:
  Add the minimal option as documented. (#2229)
Close #2225
  Commit: c07438e1627b6c802b37eb877288495cbbec18fb
      https://github.com/PDAL/PDAL/commit/c07438e1627b6c802b37eb877288495cbbec18fb
  Changed paths:
    M cmake/win32_compiler_options.cmake
    M filters/ChipperFilter.cpp
    M filters/ChipperFilter.hpp
    M filters/ColorinterpFilter.cpp
    M filters/ELMFilter.cpp
    M filters/GreedyProjection.cpp
    M filters/GreedyProjection.hpp
    M filters/MongusFilter.cpp
    M filters/MortonOrderFilter.cpp
    M filters/NormalFilter.cpp
    M filters/PMFFilter.cpp
    M filters/PoissonFilter.cpp
    M filters/SMRFilter.cpp
    M filters/SplitterFilter.cpp
    M filters/private/pnp/Grid.hpp
    M filters/private/pnp/VoxelRayTrace.hpp
    M io/BpfReader.cpp
    M io/BpfWriter.cpp
    M io/FauxReader.cpp
    M io/GDALWriter.cpp
    M io/LasHeader.cpp
    M io/LasReader.cpp
    M io/LasWriter.cpp
    M io/OptechReader.hpp
    M io/private/EptSupport.hpp
    M pdal/EigenUtils.cpp
    M pdal/QuadIndex.cpp
    M plugins/fbx/io/FbxWriter.cpp
    M plugins/greyhound/io/GreyhoundWriter.cpp
    M plugins/i3s/io/EsriUtil.cpp
    M plugins/icebridge/test/IcebridgeReaderTest.cpp
    M plugins/nitf/CMakeLists.txt
    M plugins/nitf/io/NitfWriter.cpp
    M plugins/nitf/test/NitfReaderTest.cpp
    M plugins/pgpointcloud/io/PgWriter.cpp
    M plugins/python/io/NumpyReader.cpp
    M plugins/python/test/PythonFilterTest.cpp
    M plugins/sqlite/io/SQLiteWriter.cpp
    M test/unit/PointTableTest.cpp
    M test/unit/PolygonTest.cpp
    M test/unit/Support.cpp
    M test/unit/apps/InfoTest.cpp
    M test/unit/filters/DividerFilterTest.cpp
    M test/unit/filters/NeighborClassifierFilterTest.cpp
    M test/unit/filters/RandomizeFilterTest.cpp
    M test/unit/filters/RangeFilterTest.cpp
    M test/unit/filters/ReprojectionFilterTest.cpp
    M test/unit/filters/StatsFilterTest.cpp
    M test/unit/io/BufferTest.cpp
    M test/unit/io/FauxReaderTest.cpp
    M test/unit/io/Ilvis2ReaderTest.cpp
    M test/unit/io/QFITReaderTest.cpp
    M test/unit/io/SbetReaderTest.cpp
    M vendor/arbiter/arbiter.hpp
  Log Message:
  Eliminate warnings on vc++ compiler (#2243)
Eliminate lots of Windows compiler warnings.
  Commit: 9b98eab35ba2dc9fa345ea891ea5cdd4b93f065d
      https://github.com/PDAL/PDAL/commit/9b98eab35ba2dc9fa345ea891ea5cdd4b93f065d
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    M io/HeaderVal.hpp
  Log Message:
  Catch up to master
Compare: https://github.com/PDAL/PDAL/compare/0a571ff06068...9b98eab35ba2
      **NOTE:** This service has been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
      Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits mailing list
