[pdal-commits] [PDAL/PDAL] 156829: add 'memorycopy' option to readers.gdal (#2190)
GitHub
noreply at github.com
Mon Oct 29 07:58:26 PDT 2018
Branch: refs/heads/1.8rc
Home: https://github.com/PDAL/PDAL
Commit: 1568292592bf06bf51e2806b6bf2789d0c6574bc
https://github.com/PDAL/PDAL/commit/1568292592bf06bf51e2806b6bf2789d0c6574bc
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2018-10-29 (Mon, 29 Oct 2018)
Changed paths:
M io/GDALReader.cpp
M io/GDALReader.hpp
M pdal/GDALUtils.cpp
M pdal/GDALUtils.hpp
M test/unit/io/GDALReaderTest.cpp
Log Message:
* add 'memorycopy' option to readers.gdal to allow user to create a GDAL MEM driver copy of the given raster for situations where the format is degenerate for whatever reason
* make 'memorycopy' option hidden
* Close raster at the end of initialize().
Don't set m_count.
Fix EOF logic.
Commit: d6c26b06f0bcf607f4ac4e7fa005a0515dfa05c3
https://github.com/PDAL/PDAL/commit/d6c26b06f0bcf607f4ac4e7fa005a0515dfa05c3
Changed paths:
M io/GDALReader.cpp
M io/GDALReader.hpp
M pdal/QuickInfo.hpp
Log Message:
Don't use a destructed value in GDALReader::inspect. (#2247)
Commit: 04fff78dd495e79466e1d47e57214fa38b03f8cb
https://github.com/PDAL/PDAL/commit/04fff78dd495e79466e1d47e57214fa38b03f8cb
Changed paths:
M doc/stages/readers.rxp.rst
Log Message:
Clairfy description of reflectance_as_intensity. (#2251)
Close #2250
Commit: e07fe0174ea933a6a265bdf9039c78c8142f77ab
https://github.com/PDAL/PDAL/commit/e07fe0174ea933a6a265bdf9039c78c8142f77ab
Changed paths:
M kernels/InfoKernel.cpp
M kernels/InfoKernel.hpp
M test/unit/apps/InfoTest.cpp
Log Message:
Don't reference an out-of-scope PointTable. (#2255)
* Don't reference an out-of-scope PointTable.
Close #2254
* Add test for info --all.
Compare: https://github.com/PDAL/PDAL/compare/8846b0d0bc9c...e07fe0174ea9
**NOTE:** This service has been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits
