[pdal-commits] [PDAL/PDAL] f353c6: EptReader: use throwError utility for errors.
GitHub
noreply at github.com
Mon Sep 17 10:51:17 PDT 2018
Branch: refs/heads/ept
Home: https://github.com/PDAL/PDAL
Commit: f353c6fe6f0e7e75b578892e3f336d0d5ca8c0b8
https://github.com/PDAL/PDAL/commit/f353c6fe6f0e7e75b578892e3f336d0d5ca8c0b8
Author: Connor Manning <connor at hobu.co>
Date: 2018-09-17 (Mon, 17 Sep 2018)
Changed paths:
M io/EptReader.cpp
M io/EptReader.hpp
Log Message:
Commit: 83d34855951e1f975033eb9639f153a56158290d
https://github.com/PDAL/PDAL/commit/83d34855951e1f975033eb9639f153a56158290d
Changed paths:
M doc/stages/readers.ept.rst
M io/EptReader.cpp
M io/EptReader.hpp
M io/private/EptSupport.hpp
Log Message:
EptReader review fixes.
- Explicitly handle unexpected JSON values.
- Thread count specification and note about the 4-thread minimum in the
doc.
- Remove spurious try-catch around SRS handling.
- Absolute-value around scaling math.
- Use Utils::remove, remove confusing default argument, and initialize
values in ready().
Compare: https://github.com/PDAL/PDAL/compare/b7d5187e8e9a...83d34855951e
**NOTE:** This service has been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits
