[pdal-commits] [PDAL/PDAL] cda458: Add native PCD I/O (removing reader/writer from PC...
chambbj
noreply at github.com
Thu Aug 1 11:12:31 PDT 2019
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: cda458ac3be3996d2ace8d7afa515948b515797f
https://github.com/PDAL/PDAL/commit/cda458ac3be3996d2ace8d7afa515948b515797f
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2019-07-31 (Wed, 31 Jul 2019)
Changed paths:
M doc/stages/readers.pcd.rst
M doc/stages/writers.pcd.rst
A io/PcdHeader.cpp
A io/PcdHeader.hpp
A io/PcdReader.cpp
A io/PcdReader.hpp
A io/PcdWriter.cpp
A io/PcdWriter.hpp
A io/point_types.hpp
M plugins/pcl/CMakeLists.txt
R plugins/pcl/io/PcdCommon.hpp
R plugins/pcl/io/PcdHeader.cpp
R plugins/pcl/io/PcdHeader.hpp
R plugins/pcl/io/PcdReader.cpp
R plugins/pcl/io/PcdReader.hpp
R plugins/pcl/io/PcdWriter.cpp
R plugins/pcl/io/PcdWriter.hpp
R plugins/pcl/io/point_types.hpp
A test/data/pcd/missingheader.pcd
A test/data/pcd/utm17_comma.pcd
A test/data/pcd/utm17_space.pcd
A test/data/pcd/utm17_tab.pcd
M test/unit/CMakeLists.txt
A test/unit/io/PcdReaderTest.cpp
A test/unit/io/PcdWriterTest.cpp
Log Message:
Add native PCD I/O (removing reader/writer from PCL plugin)
- Supports reading and writing ASCII
- Supports reading and writing binary
- Readers are streamable, while writers are not
- Does NOT yet support binary compressed
- Removes need for PcdCommon header
- Adds rudimentary tests for PCD reader/writer
A note about the PCD writer. Similar to other writers, the PCD writer can
output a subset of the dimensions if keep_unspecified is set to false. In that
case, only the dimensions specified in the order parameter are written in the
output. The dimension type ("F", "I", or "U") and size (in bytes) can also be
specified, along with precision in the case of ASCII output.
This native driver for PCD will remove a long-standing issue with the previous
PCL-backed drivers, which required a conversion to a fixed, single-precision
point schema, that resulted in loss of extra dimensions (beyond XYZRGBA) and
confusion surrounding subtraction of offsets to avoid loss of precision for
certain coordinate systems.
Commit: 8c870da1d032838ca55edcec20c9ce10d843a72b
https://github.com/PDAL/PDAL/commit/8c870da1d032838ca55edcec20c9ce10d843a72b
Changed paths:
M io/PcdWriter.cpp
M test/unit/io/PcdWriterTest.cpp
Log Message:
Change PCD writer specification of output dimensions
Users may now specify a valid PDAL type, e.g., Unsigned16, and precision as
part of the `order` argument. For example, "X=Float:3,Y=Double:4,Z=Unsigned32".
Dimension type default is double precision floating point.
Commit: 7da7a2d205885c776c1c366868527ec03b5aaeb1
https://github.com/PDAL/PDAL/commit/7da7a2d205885c776c1c366868527ec03b5aaeb1
Changed paths:
M io/PcdReader.cpp
Log Message:
Replace boost is_any_of with lambda as predicate in split
Commit: 436404dae24b719cc76ea791a435adb6e2321c6b
https://github.com/PDAL/PDAL/commit/436404dae24b719cc76ea791a435adb6e2321c6b
Author: chambbj <brad.chambers at gmail.com>
Date: 2019-08-01 (Thu, 01 Aug 2019)
Changed paths:
A io/PcdHeader.cpp
A io/PcdHeader.hpp
A io/PcdReader.cpp
A io/PcdReader.hpp
A io/PcdWriter.cpp
A io/PcdWriter.hpp
Log Message:
Merge pull request #2624 from PDAL/pcd-io
Compare: https://github.com/PDAL/PDAL/compare/0baa5b8a3cdb...436404dae24b
More information about the pdal-commits
