[pdal-commits] [PDAL/PDAL] f34e22: First whack at removing PCL plugin
chambbj
noreply at github.com
Fri Aug 2 06:01:24 PDT 2019
Branch: refs/heads/remove-pcl-plugin
Home: https://github.com/PDAL/PDAL
Commit: f34e2254f60704cfd39d86366de9a1a9ce59ad71
https://github.com/PDAL/PDAL/commit/f34e2254f60704cfd39d86366de9a1a9ce59ad71
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2019-08-02 (Fri, 02 Aug 2019)
Changed paths:
M cmake/examples/hobu-config.sh
M cmake/examples/hobu-windows.bat
M cmake/options.cmake
M doc/about.rst
R doc/apps/pcl.rst
M doc/apps/translate.rst
M doc/faq.rst
R doc/stages/filters.gridprojection.rst
R doc/stages/filters.movingleastsquares.rst
R doc/stages/filters.pclblock.rst
M doc/stages/filters.rst
R doc/stages/filters.voxelgrid.rst
M doc/tutorial/index.rst
R doc/tutorial/pcl_block_tutorial.rst
R doc/tutorial/pcl_ground/after-front1.png
R doc/tutorial/pcl_ground/after-front2.png
R doc/tutorial/pcl_ground/after-front3.png
R doc/tutorial/pcl_ground/after-top1.png
R doc/tutorial/pcl_ground/after-top2.png
R doc/tutorial/pcl_ground/after-top3.png
R doc/tutorial/pcl_ground/index.rst
R doc/tutorial/pcl_ground/original.png
R doc/tutorial/pcl_ground/sor_pmf.json
R doc/tutorial/pcl_ground/sor_pmf2.json
R doc/tutorial/pcl_spec.rst
M plugins/CMakeLists.txt
R plugins/pcl/CMakeLists.txt
R plugins/pcl/PCLConversions.hpp
R plugins/pcl/filters/GridProjectionFilter.cpp
R plugins/pcl/filters/GridProjectionFilter.hpp
R plugins/pcl/filters/MovingLeastSquaresFilter.cpp
R plugins/pcl/filters/MovingLeastSquaresFilter.hpp
R plugins/pcl/filters/PCLBlock.cpp
R plugins/pcl/filters/PCLBlock.hpp
R plugins/pcl/filters/VoxelGridFilter.cpp
R plugins/pcl/filters/VoxelGridFilter.hpp
R plugins/pcl/kernel/PCLKernel.cpp
R plugins/pcl/kernel/PCLKernel.hpp
R plugins/pcl/kernel/SmoothKernel.cpp
R plugins/pcl/kernel/SmoothKernel.hpp
R plugins/pcl/pipeline/PCLPipeline.cpp
R plugins/pcl/pipeline/PCLPipeline.h
R plugins/pcl/pipeline/PCLPipeline.hpp
R plugins/pcl/test/PCLBlockFilterTest.cpp
M scripts/appveyor/conda/build.cmd
M scripts/appveyor/conda/recipe/bld.bat
M scripts/appveyor/conda/recipe/build.sh
M scripts/appveyor/conda/recipe/meta.yaml
M scripts/appveyor/test/build.cmd
M scripts/conda/osx-setup.sh
M scripts/conda/osx.sh
M scripts/conda/win64-setup.bat
M scripts/conda/win64.bat
M scripts/docker/rivlib/Dockerfile
M scripts/docker/ubuntu/Dockerfile
R scripts/linux-install-scripts/pcl.sh
M scripts/linux-install-scripts/pdal.sh
M scripts/osgeo4w/config.cmd
R test/data/filters/pcl/example_PassThrough_1.json
R test/data/filters/pcl/example_PassThrough_2.json
R test/data/filters/pcl/filter_ConditionalRemoval_1.json
R test/data/filters/pcl/filter_ConditionalRemoval_2.json
R test/data/filters/pcl/filter_GridMinimum.json
R test/data/filters/pcl/filter_NormalEstimation_1.json
R test/data/filters/pcl/filter_NormalEstimation_2.json
R test/data/filters/pcl/filter_PassThrough_1.json
R test/data/filters/pcl/filter_PassThrough_2.json
R test/data/filters/pcl/filter_VoxelGrid.json
R test/data/filters/pcl/passthrough.json.in
Log Message:
More information about the pdal-commits
