[pdal-commits] [PDAL/PDAL] c26b03: support 'polygon' query limiter, which smartly lim...
Howard Butler
noreply at github.com
Mon Aug 19 07:55:15 PDT 2019
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: c26b03645d556c7352cc56cd33dae5129acb0a5f
https://github.com/PDAL/PDAL/commit/c26b03645d556c7352cc56cd33dae5129acb0a5f
Author: Howard Butler <howard at hobu.co>
Date: 2019-08-19 (Mon, 19 Aug 2019)
Changed paths:
M doc/stages/readers.ept.rst
M io/EptReader.cpp
M io/EptReader.hpp
M pdal/GDALUtils.cpp
M pdal/GDALUtils.hpp
M pdal/Geometry.cpp
M pdal/Polygon.cpp
M pdal/Polygon.hpp
M test/data/autzen/autzen-selection.json
A test/data/ept/1.2-with-color/ept-build.json
A test/data/ept/1.2-with-color/ept-data/0-0-0-0.laz
A test/data/ept/1.2-with-color/ept-hierarchy/0-0-0-0.json
A test/data/ept/1.2-with-color/ept-sources/0.json
A test/data/ept/1.2-with-color/ept-sources/list.json
A test/data/ept/1.2-with-color/ept.json
M test/unit/CMakeLists.txt
M test/unit/PolygonTest.cpp
M test/unit/io/EptReaderTest.cpp
Log Message:
support 'polygon' query limiter, which smartly limits fetches based on box intersections of the polygon(s) given (#2667)
* support 'polygon' query limiter, which smartly limits fetches based on box intersections of the polygon(s) given
* update ept doc
* need to link GDAL for Ept for polygon clipping
* support polygon cropping in readers.ept
* fill out D9IM for #2670
* test 'polygon' option for EPT reader
* use disjoint instead of intersects for testing bbox - polygon interaction
* attempt to support reprojected input polys -- WIP
* Support SRS at the end of geometry specifications.
* Remove dead code.
* Finish getting tests working for EPT polygon clipping.
* Add check in case SRS was included with new geometry.
More information about the pdal-commits
