[pdal-commits] [PDAL/PDAL] 7e652d: support 'polygon' query limiter, which smartly lim...
Andrew Bell
noreply at github.com
Mon Aug 19 16:30:00 PDT 2019
Branch: refs/heads/ept-polygon-limit
Home: https://github.com/PDAL/PDAL
Commit: 7e652da6cedd9f8a3a465908a4a5d3a66ddcdec7
https://github.com/PDAL/PDAL/commit/7e652da6cedd9f8a3a465908a4a5d3a66ddcdec7
Author: Howard Butler <howard at hobu.co>
Date: 2019-08-12 (Mon, 12 Aug 2019)
Changed paths:
M filters/CropFilter.cpp
M io/EptReader.cpp
M io/EptReader.hpp
Log Message:
support 'polygon' query limiter, which smartly limits fetches based on box intersections of the polygon(s) given
Commit: 58e20cd81d4b2618631d8d38a7b62cfc25ed0542
https://github.com/PDAL/PDAL/commit/58e20cd81d4b2618631d8d38a7b62cfc25ed0542
Changed paths:
M doc/stages/readers.ept.rst
Log Message:
update ept doc
Commit: 88bfbf2f3104150a586ff2c4f7039b24bfa7dc4f
https://github.com/PDAL/PDAL/commit/88bfbf2f3104150a586ff2c4f7039b24bfa7dc4f
Changed paths:
M io/EptReader.cpp
M test/unit/CMakeLists.txt
Log Message:
need to link GDAL for Ept for polygon clipping
Commit: ef650999746da3f856b2c837b279af123b0aac11
https://github.com/PDAL/PDAL/commit/ef650999746da3f856b2c837b279af123b0aac11
Date: 2019-08-13 (Tue, 13 Aug 2019)
Changed paths:
M filters/StatsFilter.cpp
M pdal/StageExtensions.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into ept-polygon-limit
Commit: 16dc7b343bc7827d3a5302230c90e9ea016a6f1d
https://github.com/PDAL/PDAL/commit/16dc7b343bc7827d3a5302230c90e9ea016a6f1d
Changed paths:
M io/EptReader.cpp
M io/EptReader.hpp
M test/unit/io/EptReaderTest.cpp
Log Message:
support polygon cropping in readers.ept
Commit: e811c330c48071d6f8fefc9dbb2048a82758c3de
https://github.com/PDAL/PDAL/commit/e811c330c48071d6f8fefc9dbb2048a82758c3de
Changed paths:
M pdal/Polygon.cpp
M pdal/Polygon.hpp
Log Message:
fill out D9IM for #2670
Commit: fff6e334e64cbc075ffa61101fa2a5b820e4769b
https://github.com/PDAL/PDAL/commit/fff6e334e64cbc075ffa61101fa2a5b820e4769b
Changed paths:
M io/EptReader.cpp
A test/data/ept/1.2-with-color/ept-build.json
A test/data/ept/1.2-with-color/ept-data/0-0-0-0.laz
A test/data/ept/1.2-with-color/ept-hierarchy/0-0-0-0.json
A test/data/ept/1.2-with-color/ept-sources/0.json
A test/data/ept/1.2-with-color/ept-sources/list.json
A test/data/ept/1.2-with-color/ept.json
Log Message:
test 'polygon' option for EPT reader
Commit: a7a0ff3ab54cb6c9dd9ad40b68f5376a0d9e2cf2
https://github.com/PDAL/PDAL/commit/a7a0ff3ab54cb6c9dd9ad40b68f5376a0d9e2cf2
Changed paths:
M io/EptReader.cpp
Log Message:
use disjoint instead of intersects for testing bbox - polygon interaction
Commit: 86b646d58207e9ae84d449cc82adcc40ab0c09e1
https://github.com/PDAL/PDAL/commit/86b646d58207e9ae84d449cc82adcc40ab0c09e1
Changed paths:
M io/EptReader.cpp
M io/EptReader.hpp
Log Message:
attempt to support reprojected input polys -- WIP
Commit: 8ca2170b3350d2e5a490f349da98c49ec59fb06f
https://github.com/PDAL/PDAL/commit/8ca2170b3350d2e5a490f349da98c49ec59fb06f
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2019-08-15 (Thu, 15 Aug 2019)
Changed paths:
M pdal/GDALUtils.cpp
M pdal/GDALUtils.hpp
Log Message:
Support SRS at the end of geometry specifications.
Commit: 19ea499aab53aae03e6880ed93f8d4e2cb9f19e5
https://github.com/PDAL/PDAL/commit/19ea499aab53aae03e6880ed93f8d4e2cb9f19e5
Changed paths:
M filters/ColorinterpFilter.cpp
M filters/ColorinterpFilter.hpp
M filters/ColorizationFilter.cpp
M filters/ColorizationFilter.hpp
M filters/DEMFilter.cpp
M filters/DEMFilter.hpp
M filters/OverlayFilter.cpp
M io/EptReader.cpp
M io/EptReader.hpp
M io/GDALReader.cpp
M io/GDALReader.hpp
M io/Ilvis2MetadataReader.cpp
M io/OGRWriter.cpp
M io/OGRWriter.hpp
R io/OGRWriterV1.cpp
M io/TIndexReader.hpp
M kernels/DensityKernel.cpp
M kernels/TIndexKernel.cpp
M kernels/TIndexKernel.hpp
M kernels/private/density/OGR.cpp
M pdal/Geometry.cpp
M pdal/Geometry.hpp
M pdal/Polygon.cpp
M plugins/oci/io/OciWriter.cpp
M plugins/oci/io/OciWriter.hpp
Log Message:
Commit: e415d8cb2387149e5080272a38cdc61390bdb8fd
https://github.com/PDAL/PDAL/commit/e415d8cb2387149e5080272a38cdc61390bdb8fd
Date: 2019-08-16 (Fri, 16 Aug 2019)
Changed paths:
M io/EptReader.hpp
Log Message:
Remove dead code.
Commit: 8eb495cfd1f42afce41cecd54729366719f47a37
https://github.com/PDAL/PDAL/commit/8eb495cfd1f42afce41cecd54729366719f47a37
Changed paths:
M io/EptReader.cpp
M io/EptReader.hpp
M plugins/python/filters/PythonFilter.cpp
M plugins/python/filters/PythonFilter.hpp
Log Message:
Commit: 749fda41f10e6cbfc3504ccbc2209c2a1c52bc6e
https://github.com/PDAL/PDAL/commit/749fda41f10e6cbfc3504ccbc2209c2a1c52bc6e
Changed paths:
M io/EptReader.cpp
M pdal/Geometry.cpp
M test/data/autzen/autzen-selection.json
M test/unit/PolygonTest.cpp
Log Message:
Finish getting tests working for EPT polygon clipping.
Commit: ff0e3ea50258baadb2b3692bccebc9dc4c92c769
https://github.com/PDAL/PDAL/commit/ff0e3ea50258baadb2b3692bccebc9dc4c92c769
Date: 2019-08-19 (Mon, 19 Aug 2019)
Changed paths:
M pdal/Geometry.cpp
Log Message:
Add check in case SRS was included with new geometry.
Compare: https://github.com/PDAL/PDAL/compare/7e652da6cedd%5E...ff0e3ea50258
More information about the pdal-commits
