[pdal-commits] [PDAL/PDAL] a65222: Workshop updates (#2683)
Adam Steer
noreply at github.com
Wed Aug 21 12:46:25 PDT 2019
Branch: refs/heads/1.9-maintenance
Home: https://github.com/PDAL/PDAL
Commit: a65222e580534a6417b54f71b3d19a9e468b093c
https://github.com/PDAL/PDAL/commit/a65222e580534a6417b54f71b3d19a9e468b093c
Author: Adam Steer <adamsteer at users.noreply.github.com>
Date: 2019-08-21 (Wed, 21 Aug 2019)
Changed paths:
M doc/development/compilation/dependencies.rst
M doc/workshop/agenda.rst
M doc/workshop/capstone.rst
A doc/workshop/conda.rst
M doc/workshop/conf.py
M doc/workshop/exercises/analysis/boundary/boundary-command-boundary.txt
A doc/workshop/exercises/analysis/boundary/boundary-command-tindex-win.txt
M doc/workshop/exercises/analysis/boundary/boundary-command-tindex.txt
M doc/workshop/exercises/analysis/boundary/boundary.rst
M doc/workshop/exercises/analysis/clipping/attributes.vrt
M doc/workshop/exercises/analysis/clipping/clipping-run-command.txt
M doc/workshop/exercises/analysis/clipping/clipping.json
M doc/workshop/exercises/analysis/clipping/clipping.rst
M doc/workshop/exercises/analysis/colorization/colorization-run-command.txt
M doc/workshop/exercises/analysis/colorization/colorization.rst
M doc/workshop/exercises/analysis/colorization/colorize.json
M doc/workshop/exercises/analysis/denoising/denoise.json
R doc/workshop/exercises/analysis/denoising/denoising-docker-machine-create.txt
R doc/workshop/exercises/analysis/denoising/denoising-docker-machine-delete.txt
M doc/workshop/exercises/analysis/denoising/denoising-run-command.txt
M doc/workshop/exercises/analysis/denoising/denoising.rst
A doc/workshop/exercises/analysis/density/density-command-win.txt
M doc/workshop/exercises/analysis/density/density-command.txt
M doc/workshop/exercises/analysis/density/density.rst
A doc/workshop/exercises/analysis/dtm/dtm-hillshade-command-win.txt
M doc/workshop/exercises/analysis/dtm/dtm-hillshade-command.txt
M doc/workshop/exercises/analysis/dtm/dtm-run-command.txt
M doc/workshop/exercises/analysis/dtm/dtm.rst
M doc/workshop/exercises/analysis/dtm/gdal.json
A doc/workshop/exercises/analysis/ground/ground-run-ground-only-win.txt
M doc/workshop/exercises/analysis/ground/ground-run-ground-only.txt
A doc/workshop/exercises/analysis/ground/ground-run-no-filter-win.txt
M doc/workshop/exercises/analysis/ground/ground-run-no-filter.txt
M doc/workshop/exercises/analysis/ground/ground.rst
A doc/workshop/exercises/analysis/ground/translate-run-ground-only-win.txt
M doc/workshop/exercises/analysis/ground/translate-run-ground-only.txt
A doc/workshop/exercises/analysis/meshing/meshing-buildings-win.txt
A doc/workshop/exercises/analysis/meshing/meshing-buildings.txt
A doc/workshop/exercises/analysis/meshing/meshing-terrain.txt
A doc/workshop/exercises/analysis/meshing/meshing-win.txt
A doc/workshop/exercises/analysis/meshing/meshing.rst
A doc/workshop/exercises/analysis/meshing/meshing.txt
M doc/workshop/exercises/analysis/rasterize/classification.json
M doc/workshop/exercises/analysis/rasterize/classify-command.txt
M doc/workshop/exercises/analysis/rasterize/gdaldem-run-command.txt
A doc/workshop/exercises/analysis/rasterize/intensity-run-command-win.txt
M doc/workshop/exercises/analysis/rasterize/intensity-run-command.txt
M doc/workshop/exercises/analysis/rasterize/ramp.txt
M doc/workshop/exercises/analysis/rasterize/rasterize-run-command.txt
M doc/workshop/exercises/analysis/rasterize/rasterize.rst
A doc/workshop/exercises/analysis/thinning/thinning-run-dartsample-win.txt
M doc/workshop/exercises/analysis/thinning/thinning-run-dartsample.txt
M doc/workshop/exercises/analysis/thinning/thinning.rst
A doc/workshop/exercises/batch_processing/batch-dtm-bash.txt
A doc/workshop/exercises/batch_processing/batch-dtm-powershell.txt
A doc/workshop/exercises/batch_processing/batch-processing.rst
R doc/workshop/exercises/batch_processing/batch-processing.rst.save
R doc/workshop/exercises/batch_processing/batch_dtm-powershell.txt
M doc/workshop/exercises/batch_processing/batch_srs_gdal.json
A doc/workshop/exercises/georeferencing/georeferencing-command-win.txt
M doc/workshop/exercises/georeferencing/georeferencing-command.txt
M doc/workshop/exercises/georeferencing/index.rst
M doc/workshop/exercises/index.rst
A doc/workshop/exercises/info/metadata-command-jq-win.txt
M doc/workshop/exercises/info/metadata-command-jq.txt
M doc/workshop/exercises/info/metadata-command.txt
M doc/workshop/exercises/info/metadata.rst
M doc/workshop/exercises/info/near-command-1.txt
M doc/workshop/exercises/info/near-command-2.txt
M doc/workshop/exercises/info/single-point-command.txt
M doc/workshop/exercises/info/single-point.rst
M doc/workshop/exercises/python/histogram-command.txt
M doc/workshop/exercises/python/histogram.json
M doc/workshop/exercises/python/histogram.py
M doc/workshop/exercises/python/histogram.rst
A doc/workshop/exercises/translation/compression-command-verify-win.txt
M doc/workshop/exercises/translation/compression-command-verify.txt
A doc/workshop/exercises/translation/compression-command-win.txt
M doc/workshop/exercises/translation/compression-command.txt
M doc/workshop/exercises/translation/compression.rst
A doc/workshop/exercises/translation/entwine-build-command.txt
A doc/workshop/exercises/translation/entwine-cd-command.txt
A doc/workshop/exercises/translation/entwine-command.txt
A doc/workshop/exercises/translation/entwine-info-command.txt
A doc/workshop/exercises/translation/entwine.json
A doc/workshop/exercises/translation/entwine.rst
R doc/workshop/exercises/translation/greyhound-cd-command.txt
R doc/workshop/exercises/translation/greyhound-command.txt
R doc/workshop/exercises/translation/greyhound-info-command.txt
R doc/workshop/exercises/translation/greyhound.json
R doc/workshop/exercises/translation/greyhound.rst
A doc/workshop/exercises/translation/reprojection-command-1-win.txt
M doc/workshop/exercises/translation/reprojection-command-1.txt
A doc/workshop/exercises/translation/reprojection-command-2-win.txt
M doc/workshop/exercises/translation/reprojection-command-2.txt
M doc/workshop/exercises/translation/reprojection.rst
A doc/workshop/images/batch-processing-dtm-qgis.png
M doc/workshop/images/boundary-text-output.png
M doc/workshop/images/boundary-tindex-run.png
M doc/workshop/images/clipping-run-command.png
M doc/workshop/images/colorize-run-command.png
M doc/workshop/images/compression-verify.png
M doc/workshop/images/denoise-run-command.png
M doc/workshop/images/density-command-run.png
M doc/workshop/images/dtm-run-command.png
A doc/workshop/images/entwine-command.png
A doc/workshop/images/entwine-info-verify.png
A doc/workshop/images/entwine-view.png
A doc/workshop/images/first-mesh.png
M doc/workshop/images/georeferencing-run-command.png
M doc/workshop/images/ground-run-command.png
M doc/workshop/images/info-interesting-metadata-jq.png
M doc/workshop/images/info-interesting-metadata.png
M doc/workshop/images/info-interesting-single-point.png
M doc/workshop/images/info-near-bbox.png
M doc/workshop/images/info-near-point.png
A doc/workshop/images/meshing-building-result.png
A doc/workshop/images/meshing-buildings.png
A doc/workshop/images/meshing.png
M doc/workshop/images/python-histogram-command.png
M doc/workshop/images/python-histogram.png
M doc/workshop/images/rasterization-classification-run-command.png
M doc/workshop/images/rasterization-colored-classification.png
M doc/workshop/images/rasterization-colored-intensity.png
M doc/workshop/images/rasterization-denmark-no-ramp.png
A doc/workshop/images/rasterization-qgis-load-color-palette.png
M doc/workshop/images/reprojection-first-point.png
M doc/workshop/images/reprojection-proper-scale.png
M doc/workshop/images/reprojection-run-command.png
M doc/workshop/images/reprojection-run-with-scale.png
M doc/workshop/images/reprojection-wrong-scale.png
M doc/workshop/images/thinning-command-run.png
M doc/workshop/includes/substitutions.rst
M doc/workshop/index.rst
M doc/workshop/slides/source/analysis.rst
M doc/workshop/slides/source/basic_info.rst
M doc/workshop/slides/source/boundary.rst
M doc/workshop/slides/source/clipping.rst
M doc/workshop/slides/source/colorization.rst
M doc/workshop/slides/source/conf.py
M doc/workshop/slides/source/denoising.rst
M doc/workshop/slides/source/density.rst
M doc/workshop/slides/source/dtm.rst
M doc/workshop/slides/source/ground.rst
A doc/workshop/slides/source/img/terminal.png
M doc/workshop/slides/source/index.rst
M doc/workshop/slides/source/introduction.rst
A doc/workshop/slides/source/meshing.rst
M doc/workshop/slides/source/rasterization.rst
M doc/workshop/slides/source/software.rst
M doc/workshop/slides/source/thinning.rst
M doc/workshop/slides/source/translation.rst
M doc/workshop/software.rst
Log Message:
* Add windows powershell batch processing exercise to workshop
* Update batch exercise, correct references, move include file to inside
* adding workshop branch
* more entwine replacing
* mds updates based on adam steer fork
* add conda and correct toc
* more workshop updates
* remove data
* de-windows path
* added meshing skeleton
* workshop updates
* add windows style commands, p1
* more updates
* more updates, complete except for meshing
* working on meshing instructions
* removing greyhound references
* added Mike Smith and Adam Steer as authors, date to FOSS4G workshop date
* tidied ept resource URL
* using entwine now
* command for building meshing works
* meshing page update
* tidying up meshing commands
* meshing updates
* updates for pdf
* update agenda urls and links
* update slides
* fix sphinx conf files
* adding Python module to conda setup line
More information about the pdal-commits
