[pdal-commits] [PDAL/PDAL] fdc4a0: Eliminate profiling output.
Howard Butler noreply at github.com
Wed Aug 21 14:42:54 PDT 2019
  Branch: refs/heads/azure-pipelines
  Home:   https://github.com/PDAL/PDAL
  Commit: fdc4a0c78774d86d41d0487df532716011f7e005
      https://github.com/PDAL/PDAL/commit/fdc4a0c78774d86d41d0487df532716011f7e005
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2019-08-20 (Tue, 20 Aug 2019)
  Changed paths:
    M vendor/kazhdan/PoissonRecon.h
  Log Message:
  Commit: 1f6f5a7b1b0c9cdba8ad6c5b5d00e08e7440643d
      https://github.com/PDAL/PDAL/commit/1f6f5a7b1b0c9cdba8ad6c5b5d00e08e7440643d
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
  Log Message:
  Merge remote-tracking branch 'origin/issue-2682'
  Commit: 4b21da137fbd6ec66698b503f2f884f68900dcd9
      https://github.com/PDAL/PDAL/commit/4b21da137fbd6ec66698b503f2f884f68900dcd9
  Author: Adam Steer <adamsteer at users.noreply.github.com>
  Date:   2019-08-21 (Wed, 21 Aug 2019)
  Changed paths:
    M doc/development/compilation/dependencies.rst
    M doc/workshop/agenda.rst
    M doc/workshop/capstone.rst
    A doc/workshop/conda.rst
    M doc/workshop/conf.py
    M doc/workshop/exercises/analysis/boundary/boundary-command-boundary.txt
    A doc/workshop/exercises/analysis/boundary/boundary-command-tindex-win.txt
    M doc/workshop/exercises/analysis/boundary/boundary-command-tindex.txt
    M doc/workshop/exercises/analysis/boundary/boundary.rst
    M doc/workshop/exercises/analysis/clipping/attributes.vrt
    M doc/workshop/exercises/analysis/clipping/clipping-run-command.txt
    M doc/workshop/exercises/analysis/clipping/clipping.json
    M doc/workshop/exercises/analysis/clipping/clipping.rst
    M doc/workshop/exercises/analysis/colorization/colorization-run-command.txt
    M doc/workshop/exercises/analysis/colorization/colorization.rst
    M doc/workshop/exercises/analysis/colorization/colorize.json
    M doc/workshop/exercises/analysis/denoising/denoise.json
    R doc/workshop/exercises/analysis/denoising/denoising-docker-machine-create.txt
    R doc/workshop/exercises/analysis/denoising/denoising-docker-machine-delete.txt
    M doc/workshop/exercises/analysis/denoising/denoising-run-command.txt
    M doc/workshop/exercises/analysis/denoising/denoising.rst
    A doc/workshop/exercises/analysis/density/density-command-win.txt
    M doc/workshop/exercises/analysis/density/density-command.txt
    M doc/workshop/exercises/analysis/density/density.rst
    A doc/workshop/exercises/analysis/dtm/dtm-hillshade-command-win.txt
    M doc/workshop/exercises/analysis/dtm/dtm-hillshade-command.txt
    M doc/workshop/exercises/analysis/dtm/dtm-run-command.txt
    M doc/workshop/exercises/analysis/dtm/dtm.rst
    M doc/workshop/exercises/analysis/dtm/gdal.json
    A doc/workshop/exercises/analysis/ground/ground-run-ground-only-win.txt
    M doc/workshop/exercises/analysis/ground/ground-run-ground-only.txt
    A doc/workshop/exercises/analysis/ground/ground-run-no-filter-win.txt
    M doc/workshop/exercises/analysis/ground/ground-run-no-filter.txt
    M doc/workshop/exercises/analysis/ground/ground.rst
    A doc/workshop/exercises/analysis/ground/translate-run-ground-only-win.txt
    M doc/workshop/exercises/analysis/ground/translate-run-ground-only.txt
    A doc/workshop/exercises/analysis/meshing/meshing-buildings-win.txt
    A doc/workshop/exercises/analysis/meshing/meshing-buildings.txt
    A doc/workshop/exercises/analysis/meshing/meshing-terrain.txt
    A doc/workshop/exercises/analysis/meshing/meshing-win.txt
    A doc/workshop/exercises/analysis/meshing/meshing.rst
    A doc/workshop/exercises/analysis/meshing/meshing.txt
    M doc/workshop/exercises/analysis/rasterize/classification.json
    M doc/workshop/exercises/analysis/rasterize/classify-command.txt
    M doc/workshop/exercises/analysis/rasterize/gdaldem-run-command.txt
    A doc/workshop/exercises/analysis/rasterize/intensity-run-command-win.txt
    M doc/workshop/exercises/analysis/rasterize/intensity-run-command.txt
    M doc/workshop/exercises/analysis/rasterize/ramp.txt
    M doc/workshop/exercises/analysis/rasterize/rasterize-run-command.txt
    M doc/workshop/exercises/analysis/rasterize/rasterize.rst
    A doc/workshop/exercises/analysis/thinning/thinning-run-dartsample-win.txt
    M doc/workshop/exercises/analysis/thinning/thinning-run-dartsample.txt
    M doc/workshop/exercises/analysis/thinning/thinning.rst
    A doc/workshop/exercises/batch_processing/batch-dtm-bash.txt
    A doc/workshop/exercises/batch_processing/batch-dtm-powershell.txt
    A doc/workshop/exercises/batch_processing/batch-processing.rst
    R doc/workshop/exercises/batch_processing/batch-processing.rst.save
    R doc/workshop/exercises/batch_processing/batch_dtm-powershell.txt
    M doc/workshop/exercises/batch_processing/batch_srs_gdal.json
    A doc/workshop/exercises/georeferencing/georeferencing-command-win.txt
    M doc/workshop/exercises/georeferencing/georeferencing-command.txt
    M doc/workshop/exercises/georeferencing/index.rst
    M doc/workshop/exercises/index.rst
    A doc/workshop/exercises/info/metadata-command-jq-win.txt
    M doc/workshop/exercises/info/metadata-command-jq.txt
    M doc/workshop/exercises/info/metadata-command.txt
    M doc/workshop/exercises/info/metadata.rst
    M doc/workshop/exercises/info/near-command-1.txt
    M doc/workshop/exercises/info/near-command-2.txt
    M doc/workshop/exercises/info/single-point-command.txt
    M doc/workshop/exercises/info/single-point.rst
    M doc/workshop/exercises/python/histogram-command.txt
    M doc/workshop/exercises/python/histogram.json
    M doc/workshop/exercises/python/histogram.py
    M doc/workshop/exercises/python/histogram.rst
    A doc/workshop/exercises/translation/compression-command-verify-win.txt
    M doc/workshop/exercises/translation/compression-command-verify.txt
    A doc/workshop/exercises/translation/compression-command-win.txt
    M doc/workshop/exercises/translation/compression-command.txt
    M doc/workshop/exercises/translation/compression.rst
    A doc/workshop/exercises/translation/entwine-build-command.txt
    A doc/workshop/exercises/translation/entwine-cd-command.txt
    A doc/workshop/exercises/translation/entwine-command.txt
    A doc/workshop/exercises/translation/entwine-info-command.txt
    A doc/workshop/exercises/translation/entwine.json
    A doc/workshop/exercises/translation/entwine.rst
    R doc/workshop/exercises/translation/greyhound-cd-command.txt
    R doc/workshop/exercises/translation/greyhound-command.txt
    R doc/workshop/exercises/translation/greyhound-info-command.txt
    R doc/workshop/exercises/translation/greyhound.json
    R doc/workshop/exercises/translation/greyhound.rst
    A doc/workshop/exercises/translation/reprojection-command-1-win.txt
    M doc/workshop/exercises/translation/reprojection-command-1.txt
    A doc/workshop/exercises/translation/reprojection-command-2-win.txt
    M doc/workshop/exercises/translation/reprojection-command-2.txt
    M doc/workshop/exercises/translation/reprojection.rst
    A doc/workshop/images/batch-processing-dtm-qgis.png
    M doc/workshop/images/boundary-text-output.png
    M doc/workshop/images/boundary-tindex-run.png
    M doc/workshop/images/clipping-run-command.png
    M doc/workshop/images/colorize-run-command.png
    M doc/workshop/images/compression-verify.png
    M doc/workshop/images/denoise-run-command.png
    M doc/workshop/images/density-command-run.png
    M doc/workshop/images/dtm-run-command.png
    A doc/workshop/images/entwine-command.png
    A doc/workshop/images/entwine-info-verify.png
    A doc/workshop/images/entwine-view.png
    A doc/workshop/images/first-mesh.png
    M doc/workshop/images/georeferencing-run-command.png
    M doc/workshop/images/ground-run-command.png
    M doc/workshop/images/info-interesting-metadata-jq.png
    M doc/workshop/images/info-interesting-metadata.png
    M doc/workshop/images/info-interesting-single-point.png
    M doc/workshop/images/info-near-bbox.png
    M doc/workshop/images/info-near-point.png
    A doc/workshop/images/meshing-building-result.png
    A doc/workshop/images/meshing-buildings.png
    A doc/workshop/images/meshing.png
    M doc/workshop/images/python-histogram-command.png
    M doc/workshop/images/python-histogram.png
    M doc/workshop/images/rasterization-classification-run-command.png
    M doc/workshop/images/rasterization-colored-classification.png
    M doc/workshop/images/rasterization-colored-intensity.png
    M doc/workshop/images/rasterization-denmark-no-ramp.png
    A doc/workshop/images/rasterization-qgis-load-color-palette.png
    M doc/workshop/images/reprojection-first-point.png
    M doc/workshop/images/reprojection-proper-scale.png
    M doc/workshop/images/reprojection-run-command.png
    M doc/workshop/images/reprojection-run-with-scale.png
    M doc/workshop/images/reprojection-wrong-scale.png
    M doc/workshop/images/thinning-command-run.png
    M doc/workshop/includes/substitutions.rst
    M doc/workshop/index.rst
    M doc/workshop/slides/source/analysis.rst
    M doc/workshop/slides/source/basic_info.rst
    M doc/workshop/slides/source/boundary.rst
    M doc/workshop/slides/source/clipping.rst
    M doc/workshop/slides/source/colorization.rst
    M doc/workshop/slides/source/conf.py
    M doc/workshop/slides/source/denoising.rst
    M doc/workshop/slides/source/density.rst
    M doc/workshop/slides/source/dtm.rst
    M doc/workshop/slides/source/ground.rst
    A doc/workshop/slides/source/img/terminal.png
    M doc/workshop/slides/source/index.rst
    M doc/workshop/slides/source/introduction.rst
    A doc/workshop/slides/source/meshing.rst
    M doc/workshop/slides/source/rasterization.rst
    M doc/workshop/slides/source/software.rst
    M doc/workshop/slides/source/thinning.rst
    M doc/workshop/slides/source/translation.rst
    M doc/workshop/software.rst
  Log Message:
  Workshop updates (#2683)
* Add windows powershell batch processing exercise to workshop
* Update batch exercise, correct references, move include file to inside
* adding workshop branch
* more entwine replacing
* mds updates based on adam steer fork
* add conda and correct toc
* more workshop updates
* remove data
* de-windows path
* added meshing skeleton
* workshop updates
* add windows style commands, p1
* more updates
* more updates, complete except for meshing
* working on meshing instructions
* removing greyhound references
* added Mike Smith and Adam Steer as authors, date to FOSS4G workshop date
* tidied ept resource URL
* using entwine now
* command for building meshing works
* meshing page update
* tidying up meshing commands
* meshing updates
* updates for pdf
* update agenda urls and links
* update slides
* fix sphinx conf files
* adding Python module to conda setup line
  Commit: aefeea8403bed94c539871bcb91841bd9af8b9cc
      https://github.com/PDAL/PDAL/commit/aefeea8403bed94c539871bcb91841bd9af8b9cc
  Changed paths:
    M cmake/gdal.cmake
  Log Message:
  Use our own version checking for GDAL. (#2681)
  Commit: f1c56e0d522c9088a0a8ff3d6b7b57bed20ee2d6
      https://github.com/PDAL/PDAL/commit/f1c56e0d522c9088a0a8ff3d6b7b57bed20ee2d6
  Author: chambbj <brad.chambers at gmail.com>
  Changed paths:
    M doc/stages/filters.eigenvalues.rst
    M filters/EigenvaluesFilter.cpp
    M filters/EigenvaluesFilter.hpp
  Log Message:
  Add option to normalize eigenvalues (#2679)
* Add option to normalize eigenvalues
* Document normalize argument for eigenvalues filter
  Commit: 9b8afcc545dcb2a4db88230e979b54eb06331099
      https://github.com/PDAL/PDAL/commit/9b8afcc545dcb2a4db88230e979b54eb06331099
  Changed paths:
    M cmake/macros.cmake
    M pdal/Stage.hpp
    M pdal/pdal_export.hpp
    M pdal/util/pdal_util_export.hpp
    M plugins/sqlite/CMakeLists.txt
    M plugins/sqlite/io/SQLiteCommon.hpp
  Log Message:
  Isolate SQLite symbols in shared library (#2686)
* Isolate SQLite in SQLiteCommon to specific shared libraries.
* Define PDAL_LOCAL to nothing on Windows since everything is local by default.
  Commit: a7d7930335958fbf91432916bef822c7b6f4fc71
      https://github.com/PDAL/PDAL/commit/a7d7930335958fbf91432916bef822c7b6f4fc71
  Changed paths:
    M io/LasReader.cpp
    M pdal/Metadata.hpp
    A test/data/las/prec3.las
    M test/unit/io/LasWriterTest.cpp
  Log Message:
  Don't write metadata with more precision than exists. (#2677)
* Don't write scale/offset with more precision than exists.
Update doubles specified with precision the same way
they're added to metadata.
* Add missed test file.
  Commit: 09dde9563875be950352dce6f6027a4fd2775369
      https://github.com/PDAL/PDAL/commit/09dde9563875be950352dce6f6027a4fd2775369
  Changed paths:
    M cmake/gdal.cmake
    M io/LasReader.cpp
    M pdal/Metadata.hpp
    M pdal/Stage.hpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into azure-pipelines
Compare: https://github.com/PDAL/PDAL/compare/fab4a558aecb...09dde9563875
More information about the pdal-commits mailing list
