[pdal-commits] [PDAL/PDAL] 767b2d: Clean up CMake configuration (#2693)
chambbj noreply at github.com
Fri Aug 23 09:38:21 PDT 2019
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 767b2d0c62f00e8c2f67bf3677862e61fd00b9e2
      https://github.com/PDAL/PDAL/commit/767b2d0c62f00e8c2f67bf3677862e61fd00b9e2
  Author: chambbj <brad.chambers at gmail.com>
  Date:   2019-08-23 (Fri, 23 Aug 2019)
  Changed paths:
    M CMakeLists.txt
    M HOWTORELEASE.txt
    M apps/pdal-config-bat.in
    M apps/pdal-config.in
    M apps/pdal.pc.in
    M cmake/common.cmake
    M cmake/cpack.cmake
    A cmake/install_dirs.cmake
    M cmake/macros.cmake
    M doc/conf.py
    M pdal/pdal_config.cpp
    M pdal_features.hpp.in
  Log Message:
* Remove unused CMake macros
* Convert one off macros to CMake include files
* Specify C++11 for all targets, disabling extensions
* Modern CMake will now parse version numbers automatically
* osinfo.cmake no longer needed, set C++11 per target instead of globally
* Avoid setting any CXX properties globally
More information about the pdal-commits mailing list
