[pdal-commits] [PDAL/PDAL] 66a6ca: Fix Windows tests.
Howard Butler noreply at github.com
Thu Aug 29 12:46:05 PDT 2019
  Branch: refs/heads/azure-pipelines
  Home:   https://github.com/PDAL/PDAL
  Commit: 66a6ca88f169a5cdec8e3dd5b54e188f692f2fc1
      https://github.com/PDAL/PDAL/commit/66a6ca88f169a5cdec8e3dd5b54e188f692f2fc1
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2019-08-29 (Thu, 29 Aug 2019)
  Changed paths:
    M apps/pdal.cpp
    M cmake/curl.cmake
    M cmake/win32_compiler_options.cmake
    M io/Ilvis2Reader.cpp
    M io/Ilvis2Reader.hpp
    M pdal/GDALUtils.cpp
    M pdal/GDALUtils.hpp
    M pdal/Log.cpp
    M pdal/Log.hpp
    M pdal/PipelineExecutor.cpp
    M pdal/PipelineManager.cpp
    M pdal/PipelineManager.hpp
    M pdal/PluginManager.cpp
    M pdal/Stage.cpp
    M pdal/Stage.hpp
    M test/unit/LogTest.cpp
    M test/unit/filters/MergeTest.cpp
    M test/unit/filters/OverlayFilterTest.cpp
  Log Message:
  Fix Windows tests.
  Commit: 8d67b8e7bd034c731b06b9d91d7b06d332d93c4a
      https://github.com/PDAL/PDAL/commit/8d67b8e7bd034c731b06b9d91d7b06d332d93c4a
  Changed paths:
    M .travis.yml
    M CMakeLists.txt
    M HOWTORELEASE.txt
    M RELEASENOTES.txt
    M apps/pdal-config-bat.in
    M apps/pdal-config.in
    M apps/pdal.pc.in
    M cmake/common.cmake
    M cmake/config.cmake
    M cmake/cpack.cmake
    M cmake/gdal.cmake
    A cmake/install_dirs.cmake
    M cmake/macros.cmake
    A cmake/modules/FindFbx.cmake
    M cmake/python.cmake
    M cmake/unix_compiler_options.cmake
    M dimbuilder/DimBuilder.cpp
    M doc/apps/pipeline.rst
    M doc/apps/translate.rst
    M doc/conf.py
    A doc/development/release-notes/2.0.0.md
    M doc/download.rst
    M doc/index.rst
    M doc/stages/filters.assign.rst
    M doc/stages/filters.eigenvalues.rst
    M doc/stages/readers.ept.rst
    A doc/stages/writers.fbx.rst
    M doc/workshop/agenda.rst
    M doc/workshop/capstone.rst
    A doc/workshop/conda.rst
    M doc/workshop/conf.py
    M doc/workshop/exercises/analysis/boundary/boundary-command-boundary.txt
    A doc/workshop/exercises/analysis/boundary/boundary-command-tindex-win.txt
    M doc/workshop/exercises/analysis/boundary/boundary-command-tindex.txt
    M doc/workshop/exercises/analysis/boundary/boundary.rst
    M doc/workshop/exercises/analysis/clipping/attributes.vrt
    M doc/workshop/exercises/analysis/clipping/clipping-run-command.txt
    M doc/workshop/exercises/analysis/clipping/clipping.json
    M doc/workshop/exercises/analysis/clipping/clipping.rst
    M doc/workshop/exercises/analysis/colorization/colorization-run-command.txt
    M doc/workshop/exercises/analysis/colorization/colorization.rst
    M doc/workshop/exercises/analysis/colorization/colorize.json
    M doc/workshop/exercises/analysis/denoising/denoise.json
    R doc/workshop/exercises/analysis/denoising/denoising-docker-machine-create.txt
    R doc/workshop/exercises/analysis/denoising/denoising-docker-machine-delete.txt
    M doc/workshop/exercises/analysis/denoising/denoising-run-command.txt
    M doc/workshop/exercises/analysis/denoising/denoising.rst
    A doc/workshop/exercises/analysis/density/density-command-win.txt
    M doc/workshop/exercises/analysis/density/density-command.txt
    M doc/workshop/exercises/analysis/density/density.rst
    A doc/workshop/exercises/analysis/dtm/dtm-hillshade-command-win.txt
    M doc/workshop/exercises/analysis/dtm/dtm-hillshade-command.txt
    M doc/workshop/exercises/analysis/dtm/dtm-run-command.txt
    M doc/workshop/exercises/analysis/dtm/dtm.rst
    M doc/workshop/exercises/analysis/dtm/gdal.json
    A doc/workshop/exercises/analysis/ground/ground-run-ground-only-win.txt
    M doc/workshop/exercises/analysis/ground/ground-run-ground-only.txt
    A doc/workshop/exercises/analysis/ground/ground-run-no-filter-win.txt
    M doc/workshop/exercises/analysis/ground/ground-run-no-filter.txt
    M doc/workshop/exercises/analysis/ground/ground.rst
    A doc/workshop/exercises/analysis/ground/translate-run-ground-only-win.txt
    M doc/workshop/exercises/analysis/ground/translate-run-ground-only.txt
    A doc/workshop/exercises/analysis/meshing/meshing-buildings-win.txt
    A doc/workshop/exercises/analysis/meshing/meshing-buildings.txt
    A doc/workshop/exercises/analysis/meshing/meshing-terrain.txt
    A doc/workshop/exercises/analysis/meshing/meshing-win.txt
    A doc/workshop/exercises/analysis/meshing/meshing.rst
    A doc/workshop/exercises/analysis/meshing/meshing.txt
    M doc/workshop/exercises/analysis/rasterize/classification.json
    M doc/workshop/exercises/analysis/rasterize/classify-command.txt
    M doc/workshop/exercises/analysis/rasterize/gdaldem-run-command.txt
    A doc/workshop/exercises/analysis/rasterize/intensity-run-command-win.txt
    M doc/workshop/exercises/analysis/rasterize/intensity-run-command.txt
    M doc/workshop/exercises/analysis/rasterize/ramp.txt
    M doc/workshop/exercises/analysis/rasterize/rasterize-run-command.txt
    M doc/workshop/exercises/analysis/rasterize/rasterize.rst
    A doc/workshop/exercises/analysis/thinning/thinning-run-dartsample-win.txt
    M doc/workshop/exercises/analysis/thinning/thinning-run-dartsample.txt
    M doc/workshop/exercises/analysis/thinning/thinning.rst
    A doc/workshop/exercises/batch_processing/batch-dtm-bash.txt
    A doc/workshop/exercises/batch_processing/batch-dtm-powershell.txt
    A doc/workshop/exercises/batch_processing/batch-processing.rst
    R doc/workshop/exercises/batch_processing/batch-processing.rst.save
    R doc/workshop/exercises/batch_processing/batch_dtm-powershell.txt
    M doc/workshop/exercises/batch_processing/batch_srs_gdal.json
    A doc/workshop/exercises/georeferencing/georeferencing-command-win.txt
    M doc/workshop/exercises/georeferencing/georeferencing-command.txt
    M doc/workshop/exercises/georeferencing/index.rst
    M doc/workshop/exercises/index.rst
    A doc/workshop/exercises/info/metadata-command-jq-win.txt
    M doc/workshop/exercises/info/metadata-command-jq.txt
    M doc/workshop/exercises/info/metadata-command.txt
    M doc/workshop/exercises/info/metadata.rst
    M doc/workshop/exercises/info/near-command-1.txt
    M doc/workshop/exercises/info/near-command-2.txt
    M doc/workshop/exercises/info/single-point-command.txt
    M doc/workshop/exercises/info/single-point.rst
    M doc/workshop/exercises/python/histogram-command.txt
    M doc/workshop/exercises/python/histogram.json
    M doc/workshop/exercises/python/histogram.py
    M doc/workshop/exercises/python/histogram.rst
    A doc/workshop/exercises/translation/compression-command-verify-win.txt
    M doc/workshop/exercises/translation/compression-command-verify.txt
    A doc/workshop/exercises/translation/compression-command-win.txt
    M doc/workshop/exercises/translation/compression-command.txt
    M doc/workshop/exercises/translation/compression.rst
    A doc/workshop/exercises/translation/entwine-build-command.txt
    A doc/workshop/exercises/translation/entwine-cd-command.txt
    A doc/workshop/exercises/translation/entwine-command.txt
    A doc/workshop/exercises/translation/entwine-info-command.txt
    A doc/workshop/exercises/translation/entwine.json
    A doc/workshop/exercises/translation/entwine.rst
    R doc/workshop/exercises/translation/greyhound-cd-command.txt
    R doc/workshop/exercises/translation/greyhound-command.txt
    R doc/workshop/exercises/translation/greyhound-info-command.txt
    R doc/workshop/exercises/translation/greyhound.json
    R doc/workshop/exercises/translation/greyhound.rst
    A doc/workshop/exercises/translation/reprojection-command-1-win.txt
    M doc/workshop/exercises/translation/reprojection-command-1.txt
    A doc/workshop/exercises/translation/reprojection-command-2-win.txt
    M doc/workshop/exercises/translation/reprojection-command-2.txt
    M doc/workshop/exercises/translation/reprojection.rst
    A doc/workshop/images/batch-processing-dtm-qgis.png
    M doc/workshop/images/boundary-text-output.png
    M doc/workshop/images/boundary-tindex-run.png
    M doc/workshop/images/clipping-run-command.png
    M doc/workshop/images/colorize-run-command.png
    M doc/workshop/images/compression-verify.png
    M doc/workshop/images/denoise-run-command.png
    M doc/workshop/images/density-command-run.png
    M doc/workshop/images/dtm-run-command.png
    A doc/workshop/images/entwine-command.png
    A doc/workshop/images/entwine-info-verify.png
    A doc/workshop/images/entwine-view.png
    A doc/workshop/images/first-mesh.png
    M doc/workshop/images/georeferencing-run-command.png
    M doc/workshop/images/ground-run-command.png
    M doc/workshop/images/info-interesting-metadata-jq.png
    M doc/workshop/images/info-interesting-metadata.png
    M doc/workshop/images/info-interesting-single-point.png
    M doc/workshop/images/info-near-bbox.png
    M doc/workshop/images/info-near-point.png
    A doc/workshop/images/meshing-building-result.png
    A doc/workshop/images/meshing-buildings.png
    A doc/workshop/images/meshing.png
    M doc/workshop/images/python-histogram-command.png
    M doc/workshop/images/python-histogram.png
    M doc/workshop/images/rasterization-classification-run-command.png
    M doc/workshop/images/rasterization-colored-classification.png
    M doc/workshop/images/rasterization-colored-intensity.png
    M doc/workshop/images/rasterization-denmark-no-ramp.png
    A doc/workshop/images/rasterization-qgis-load-color-palette.png
    M doc/workshop/images/reprojection-first-point.png
    M doc/workshop/images/reprojection-proper-scale.png
    M doc/workshop/images/reprojection-run-command.png
    M doc/workshop/images/reprojection-run-with-scale.png
    M doc/workshop/images/reprojection-wrong-scale.png
    M doc/workshop/images/thinning-command-run.png
    M doc/workshop/includes/substitutions.rst
    M doc/workshop/index.rst
    M doc/workshop/slides/source/analysis.rst
    M doc/workshop/slides/source/basic_info.rst
    M doc/workshop/slides/source/boundary.rst
    M doc/workshop/slides/source/clipping.rst
    M doc/workshop/slides/source/colorization.rst
    M doc/workshop/slides/source/conf.py
    M doc/workshop/slides/source/denoising.rst
    M doc/workshop/slides/source/density.rst
    M doc/workshop/slides/source/dtm.rst
    M doc/workshop/slides/source/ground.rst
    A doc/workshop/slides/source/img/terminal.png
    M doc/workshop/slides/source/index.rst
    M doc/workshop/slides/source/introduction.rst
    A doc/workshop/slides/source/meshing.rst
    M doc/workshop/slides/source/rasterization.rst
    M doc/workshop/slides/source/software.rst
    M doc/workshop/slides/source/thinning.rst
    M doc/workshop/slides/source/translation.rst
    M doc/workshop/software.rst
    M examples/writing-kernel/CMakeLists.txt
    M examples/writing-reader/CMakeLists.txt
    M examples/writing-writer/CMakeLists.txt
    M examples/writing/CMakeLists.txt
    M filters/ColorinterpFilter.cpp
    M filters/ColorinterpFilter.hpp
    M filters/ColorizationFilter.cpp
    M filters/ColorizationFilter.hpp
    M filters/CropFilter.cpp
    M filters/DEMFilter.cpp
    M filters/DEMFilter.hpp
    M filters/EigenvaluesFilter.cpp
    M filters/EigenvaluesFilter.hpp
    M filters/OverlayFilter.cpp
    M filters/StatsFilter.cpp
    M io/BpfWriter.cpp
    M io/EptReader.cpp
    M io/EptReader.hpp
    M io/GDALReader.cpp
    M io/GDALReader.hpp
    M io/Ilvis2MetadataReader.cpp
    M io/LasReader.cpp
    M io/LasUtils.hpp
    M io/LasWriter.cpp
    M io/OGRWriter.cpp
    M io/OGRWriter.hpp
    R io/OGRWriterV1.cpp
    M io/TIndexReader.hpp
    M io/private/GDALGrid.cpp
    M kernels/DensityKernel.cpp
    M kernels/InfoKernel.cpp
    M kernels/PipelineKernel.cpp
    M kernels/PipelineKernel.hpp
    M kernels/TIndexKernel.cpp
    M kernels/TIndexKernel.hpp
    M kernels/TranslateKernel.cpp
    M kernels/TranslateKernel.hpp
    M kernels/private/density/OGR.cpp
    M pdal/Dimension.json
    M pdal/EigenUtils.cpp
    M pdal/EigenUtils.hpp
    M pdal/Geometry.cpp
    M pdal/Geometry.hpp
    M pdal/Metadata.hpp
    M pdal/Polygon.cpp
    M pdal/Polygon.hpp
    M pdal/Stage.hpp
    M pdal/StageExtensions.cpp
    M pdal/pdal_config.cpp
    M pdal/pdal_export.hpp
    M pdal/pdal_types.hpp
    M pdal/util/Bounds.hpp
    M pdal/util/IStream.hpp
    M pdal/util/pdal_util_export.hpp
    M pdal_features.hpp.in
    M plugins/e57/CMakeLists.txt
    M plugins/e57/io/E57Reader.cpp
    M plugins/e57/io/E57Reader.hpp
    M plugins/e57/io/E57Writer.hpp
    M plugins/e57/io/Scan.hpp
    M plugins/e57/io/Utils.hpp
    M plugins/e57/io/Uuid.hpp
    M plugins/e57/libE57Format/CMakeLists.txt
    M plugins/e57/libE57Format/src/CheckedFile.h
    M plugins/e57/libE57Format/src/ImageFileImpl.cpp
    M plugins/fbx/CMakeLists.txt
    M plugins/fbx/io/FbxWriter.cpp
    M plugins/oci/io/OciWriter.cpp
    M plugins/oci/io/OciWriter.hpp
    M plugins/python/filters/PythonFilter.cpp
    M plugins/python/filters/PythonFilter.hpp
    M plugins/sqlite/CMakeLists.txt
    M plugins/sqlite/io/SQLiteCommon.hpp
    M scripts/appveyor/test/build.cmd
    M scripts/conda/win64-setup.bat
    M scripts/conda/win64.bat
    A scripts/proj-datumshift
    M test/data/autzen/autzen-selection.json
    A test/data/ept/1.2-with-color/ept-build.json
    A test/data/ept/1.2-with-color/ept-data/0-0-0-0.laz
    A test/data/ept/1.2-with-color/ept-hierarchy/0-0-0-0.json
    A test/data/ept/1.2-with-color/ept-sources/0.json
    A test/data/ept/1.2-with-color/ept-sources/list.json
    A test/data/ept/1.2-with-color/ept.json
    M test/data/filters/ferry.json.in
    A test/data/las/prec3.las
    A test/data/pipeline/colorinterp.json.in
    M test/unit/CMakeLists.txt
    M test/unit/PolygonTest.cpp
    M test/unit/apps/pcpipelineTestJSON.cpp
    M test/unit/io/EptReaderTest.cpp
    M test/unit/io/LasWriterTest.cpp
    M test/unit/io/PcdReaderTest.cpp
    M test/unit/io/PcdWriterTest.cpp
    M vendor/eigen/Eigen/src/Core/Block.h
    M vendor/eigen/Eigen/src/Core/Map.h
    M vendor/eigen/Eigen/src/Core/MapBase.h
    M vendor/eigen/Eigen/src/Core/MatrixBase.h
    M vendor/eigen/Eigen/src/Core/Transpose.h
    M vendor/eigen/Eigen/src/Core/TriangularMatrix.h
    M vendor/kazhdan/PoissonRecon.h
  Log Message:
  Merge remote-tracking branch 'origin/master' into issue-2702
  Commit: adaa447efac73e07b42401f6e87e4370d557dfc9
      https://github.com/PDAL/PDAL/commit/adaa447efac73e07b42401f6e87e4370d557dfc9
  Changed paths:
    M plugins/matlab/test/MatlabFilterTest.cpp
    M plugins/sqlite/test/SQLiteTest.cpp
  Log Message:
  Fix plugins with updated Log code.
  Commit: 79067ba21579e8012af0c8a30cce74226707f007
      https://github.com/PDAL/PDAL/commit/79067ba21579e8012af0c8a30cce74226707f007
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    M apps/pdal.cpp
    M cmake/curl.cmake
    M pdal/Log.cpp
    M pdal/Log.hpp
    M pdal/Stage.cpp
    M pdal/Stage.hpp
  Log Message:
  Merge remote-tracking branch 'origin/issue-2702' into azure-pipelines
Compare: https://github.com/PDAL/PDAL/compare/8825a4ada003...79067ba21579
More information about the pdal-commits mailing list
