[pdal-commits] [PDAL/PDAL] 829258: tiledb and e57 config
Howard Butler
noreply at github.com
Sat Aug 31 16:44:32 PDT 2019
Branch: refs/heads/hobu-win64-buildstuff
Home: https://github.com/PDAL/PDAL
Commit: 8292582be9e9813151e36c02704ec363d8e3770a
https://github.com/PDAL/PDAL/commit/8292582be9e9813151e36c02704ec363d8e3770a
Author: Howard Butler <howard at hobu.co>
Date: 2019-08-31 (Sat, 31 Aug 2019)
Changed paths:
M scripts/conda/win64-setup.bat
M scripts/conda/win64.bat
Log Message:
Commit: 58bfe40e482b1e28b69b6e26369ccd50cda97cb9
https://github.com/PDAL/PDAL/commit/58bfe40e482b1e28b69b6e26369ccd50cda97cb9
Changed paths:
M .travis.yml
M CMakeLists.txt
M HOWTORELEASE.txt
M RELEASENOTES.txt
M apps/pdal-config-bat.in
M apps/pdal-config.in
M apps/pdal.pc.in
M cmake/common.cmake
M cmake/config.cmake
M cmake/cpack.cmake
M cmake/gdal.cmake
A cmake/install_dirs.cmake
M cmake/macros.cmake
A cmake/modules/FindFbx.cmake
M cmake/python.cmake
M cmake/unix_compiler_options.cmake
M dimbuilder/DimBuilder.cpp
M doc/apps/pipeline.rst
M doc/apps/translate.rst
M doc/conf.py
A doc/development/release-notes/2.0.0.md
M doc/download.rst
M doc/index.rst
M doc/stages/filters.assign.rst
M doc/stages/filters.eigenvalues.rst
M doc/stages/readers.ept.rst
A doc/stages/writers.fbx.rst
M doc/workshop/agenda.rst
M doc/workshop/capstone.rst
A doc/workshop/conda.rst
M doc/workshop/conf.py
M doc/workshop/exercises/analysis/boundary/boundary-command-boundary.txt
A doc/workshop/exercises/analysis/boundary/boundary-command-tindex-win.txt
M doc/workshop/exercises/analysis/boundary/boundary-command-tindex.txt
M doc/workshop/exercises/analysis/boundary/boundary.rst
M doc/workshop/exercises/analysis/clipping/attributes.vrt
M doc/workshop/exercises/analysis/clipping/clipping-run-command.txt
M doc/workshop/exercises/analysis/clipping/clipping.json
M doc/workshop/exercises/analysis/clipping/clipping.rst
M doc/workshop/exercises/analysis/colorization/colorization-run-command.txt
M doc/workshop/exercises/analysis/colorization/colorization.rst
M doc/workshop/exercises/analysis/colorization/colorize.json
M doc/workshop/exercises/analysis/denoising/denoise.json
R doc/workshop/exercises/analysis/denoising/denoising-docker-machine-create.txt
R doc/workshop/exercises/analysis/denoising/denoising-docker-machine-delete.txt
M doc/workshop/exercises/analysis/denoising/denoising-run-command.txt
M doc/workshop/exercises/analysis/denoising/denoising.rst
A doc/workshop/exercises/analysis/density/density-command-win.txt
M doc/workshop/exercises/analysis/density/density-command.txt
M doc/workshop/exercises/analysis/density/density.rst
A doc/workshop/exercises/analysis/dtm/dtm-hillshade-command-win.txt
M doc/workshop/exercises/analysis/dtm/dtm-hillshade-command.txt
M doc/workshop/exercises/analysis/dtm/dtm-run-command.txt
M doc/workshop/exercises/analysis/dtm/dtm.rst
M doc/workshop/exercises/analysis/dtm/gdal.json
A doc/workshop/exercises/analysis/ground/ground-run-ground-only-win.txt
M doc/workshop/exercises/analysis/ground/ground-run-ground-only.txt
A doc/workshop/exercises/analysis/ground/ground-run-no-filter-win.txt
M doc/workshop/exercises/analysis/ground/ground-run-no-filter.txt
M doc/workshop/exercises/analysis/ground/ground.rst
A doc/workshop/exercises/analysis/ground/translate-run-ground-only-win.txt
M doc/workshop/exercises/analysis/ground/translate-run-ground-only.txt
A doc/workshop/exercises/analysis/meshing/meshing-buildings-win.txt
A doc/workshop/exercises/analysis/meshing/meshing-buildings.txt
A doc/workshop/exercises/analysis/meshing/meshing-terrain.txt
A doc/workshop/exercises/analysis/meshing/meshing-win.txt
A doc/workshop/exercises/analysis/meshing/meshing.rst
A doc/workshop/exercises/analysis/meshing/meshing.txt
M doc/workshop/exercises/analysis/rasterize/classification.json
M doc/workshop/exercises/analysis/rasterize/classify-command.txt
M doc/workshop/exercises/analysis/rasterize/gdaldem-run-command.txt
A doc/workshop/exercises/analysis/rasterize/intensity-run-command-win.txt
M doc/workshop/exercises/analysis/rasterize/intensity-run-command.txt
M doc/workshop/exercises/analysis/rasterize/ramp.txt
M doc/workshop/exercises/analysis/rasterize/rasterize-run-command.txt
M doc/workshop/exercises/analysis/rasterize/rasterize.rst
A doc/workshop/exercises/analysis/thinning/thinning-run-dartsample-win.txt
M doc/workshop/exercises/analysis/thinning/thinning-run-dartsample.txt
M doc/workshop/exercises/analysis/thinning/thinning.rst
A doc/workshop/exercises/batch_processing/batch-dtm-bash.txt
A doc/workshop/exercises/batch_processing/batch-dtm-powershell.txt
A doc/workshop/exercises/batch_processing/batch-processing.rst
R doc/workshop/exercises/batch_processing/batch-processing.rst.save
R doc/workshop/exercises/batch_processing/batch_dtm-powershell.txt
M doc/workshop/exercises/batch_processing/batch_srs_gdal.json
A doc/workshop/exercises/georeferencing/georeferencing-command-win.txt
M doc/workshop/exercises/georeferencing/georeferencing-command.txt
M doc/workshop/exercises/georeferencing/index.rst
M doc/workshop/exercises/index.rst
A doc/workshop/exercises/info/metadata-command-jq-win.txt
M doc/workshop/exercises/info/metadata-command-jq.txt
M doc/workshop/exercises/info/metadata-command.txt
M doc/workshop/exercises/info/metadata.rst
M doc/workshop/exercises/info/near-command-1.txt
M doc/workshop/exercises/info/near-command-2.txt
M doc/workshop/exercises/info/single-point-command.txt
M doc/workshop/exercises/info/single-point.rst
M doc/workshop/exercises/python/histogram-command.txt
M doc/workshop/exercises/python/histogram.json
M doc/workshop/exercises/python/histogram.py
M doc/workshop/exercises/python/histogram.rst
A doc/workshop/exercises/translation/compression-command-verify-win.txt
M doc/workshop/exercises/translation/compression-command-verify.txt
A doc/workshop/exercises/translation/compression-command-win.txt
M doc/workshop/exercises/translation/compression-command.txt
M doc/workshop/exercises/translation/compression.rst
A doc/workshop/exercises/translation/entwine-build-command.txt
A doc/workshop/exercises/translation/entwine-cd-command.txt
A doc/workshop/exercises/translation/entwine-command.txt
A doc/workshop/exercises/translation/entwine-info-command.txt
A doc/workshop/exercises/translation/entwine.json
A doc/workshop/exercises/translation/entwine.rst
R doc/workshop/exercises/translation/greyhound-cd-command.txt
R doc/workshop/exercises/translation/greyhound-command.txt
R doc/workshop/exercises/translation/greyhound-info-command.txt
R doc/workshop/exercises/translation/greyhound.json
R doc/workshop/exercises/translation/greyhound.rst
A doc/workshop/exercises/translation/reprojection-command-1-win.txt
M doc/workshop/exercises/translation/reprojection-command-1.txt
A doc/workshop/exercises/translation/reprojection-command-2-win.txt
M doc/workshop/exercises/translation/reprojection-command-2.txt
M doc/workshop/exercises/translation/reprojection.rst
A doc/workshop/images/batch-processing-dtm-qgis.png
M doc/workshop/images/boundary-text-output.png
M doc/workshop/images/boundary-tindex-run.png
M doc/workshop/images/clipping-run-command.png
M doc/workshop/images/colorize-run-command.png
M doc/workshop/images/compression-verify.png
M doc/workshop/images/denoise-run-command.png
M doc/workshop/images/density-command-run.png
M doc/workshop/images/dtm-run-command.png
A doc/workshop/images/entwine-command.png
A doc/workshop/images/entwine-info-verify.png
A doc/workshop/images/entwine-view.png
A doc/workshop/images/first-mesh.png
M doc/workshop/images/georeferencing-run-command.png
M doc/workshop/images/ground-run-command.png
M doc/workshop/images/info-interesting-metadata-jq.png
M doc/workshop/images/info-interesting-metadata.png
M doc/workshop/images/info-interesting-single-point.png
M doc/workshop/images/info-near-bbox.png
M doc/workshop/images/info-near-point.png
A doc/workshop/images/meshing-building-result.png
A doc/workshop/images/meshing-buildings.png
A doc/workshop/images/meshing.png
M doc/workshop/images/python-histogram-command.png
M doc/workshop/images/python-histogram.png
M doc/workshop/images/rasterization-classification-run-command.png
M doc/workshop/images/rasterization-colored-classification.png
M doc/workshop/images/rasterization-colored-intensity.png
M doc/workshop/images/rasterization-denmark-no-ramp.png
A doc/workshop/images/rasterization-qgis-load-color-palette.png
M doc/workshop/images/reprojection-first-point.png
M doc/workshop/images/reprojection-proper-scale.png
M doc/workshop/images/reprojection-run-command.png
M doc/workshop/images/reprojection-run-with-scale.png
M doc/workshop/images/reprojection-wrong-scale.png
M doc/workshop/images/thinning-command-run.png
M doc/workshop/includes/substitutions.rst
M doc/workshop/index.rst
M doc/workshop/slides/source/analysis.rst
M doc/workshop/slides/source/basic_info.rst
M doc/workshop/slides/source/boundary.rst
M doc/workshop/slides/source/clipping.rst
M doc/workshop/slides/source/colorization.rst
M doc/workshop/slides/source/conf.py
M doc/workshop/slides/source/denoising.rst
M doc/workshop/slides/source/density.rst
M doc/workshop/slides/source/dtm.rst
M doc/workshop/slides/source/ground.rst
A doc/workshop/slides/source/img/terminal.png
M doc/workshop/slides/source/index.rst
M doc/workshop/slides/source/introduction.rst
A doc/workshop/slides/source/meshing.rst
M doc/workshop/slides/source/rasterization.rst
M doc/workshop/slides/source/software.rst
M doc/workshop/slides/source/thinning.rst
M doc/workshop/slides/source/translation.rst
M doc/workshop/software.rst
M examples/CMakeLists.txt
M examples/writing-kernel/CMakeLists.txt
M examples/writing-reader/CMakeLists.txt
M examples/writing-writer/CMakeLists.txt
M examples/writing/CMakeLists.txt
M filters/ColorinterpFilter.cpp
M filters/ColorinterpFilter.hpp
M filters/ColorizationFilter.cpp
M filters/ColorizationFilter.hpp
M filters/CropFilter.cpp
M filters/DEMFilter.cpp
M filters/DEMFilter.hpp
M filters/EigenvaluesFilter.cpp
M filters/EigenvaluesFilter.hpp
M filters/OverlayFilter.cpp
M filters/StatsFilter.cpp
M io/BpfWriter.cpp
M io/EptReader.cpp
M io/EptReader.hpp
M io/GDALReader.cpp
M io/GDALReader.hpp
M io/Ilvis2MetadataReader.cpp
M io/LasReader.cpp
M io/LasUtils.hpp
M io/LasWriter.cpp
M io/OGRWriter.cpp
M io/OGRWriter.hpp
R io/OGRWriterV1.cpp
M io/PcdHeader.hpp
M io/TIndexReader.hpp
M io/private/GDALGrid.cpp
M kernels/DensityKernel.cpp
M kernels/InfoKernel.cpp
M kernels/PipelineKernel.cpp
M kernels/PipelineKernel.hpp
M kernels/TIndexKernel.cpp
M kernels/TIndexKernel.hpp
M kernels/TranslateKernel.cpp
M kernels/TranslateKernel.hpp
M kernels/private/density/OGR.cpp
M pdal/Dimension.json
M pdal/EigenUtils.cpp
M pdal/EigenUtils.hpp
M pdal/GDALUtils.cpp
M pdal/GDALUtils.hpp
M pdal/Geometry.cpp
M pdal/Geometry.hpp
M pdal/Metadata.hpp
M pdal/PipelineManager.cpp
M pdal/PipelineManager.hpp
M pdal/Polygon.cpp
M pdal/Polygon.hpp
M pdal/Stage.hpp
M pdal/StageExtensions.cpp
M pdal/StageFactory.cpp
M pdal/pdal_config.cpp
M pdal/pdal_export.hpp
M pdal/pdal_types.hpp
M pdal/util/Bounds.hpp
M pdal/util/IStream.hpp
M pdal/util/pdal_util_export.hpp
M pdal_features.hpp.in
M plugins/e57/CMakeLists.txt
M plugins/e57/io/E57Reader.cpp
M plugins/e57/io/E57Reader.hpp
M plugins/e57/io/E57Writer.cpp
M plugins/e57/io/E57Writer.hpp
M plugins/e57/io/Scan.cpp
M plugins/e57/io/Scan.hpp
M plugins/e57/io/Utils.cpp
M plugins/e57/io/Utils.hpp
M plugins/e57/io/Uuid.hpp
M plugins/e57/libE57Format/CMakeLists.txt
M plugins/e57/libE57Format/src/CheckedFile.h
M plugins/e57/libE57Format/src/ImageFileImpl.cpp
M plugins/e57/test/E57ReaderTest.cpp
M plugins/e57/test/E57UtilsTest.cpp
M plugins/e57/test/E57WriterTest.cpp
M plugins/e57/test/ScanTest.cpp
M plugins/fbx/CMakeLists.txt
M plugins/fbx/io/FbxWriter.cpp
M plugins/oci/io/OciWriter.cpp
M plugins/oci/io/OciWriter.hpp
M plugins/pgpointcloud/io/PgWriter.cpp
M plugins/pgpointcloud/test/PgpointcloudWriterTest.cpp
M plugins/python/filters/PythonFilter.cpp
M plugins/python/filters/PythonFilter.hpp
M plugins/rdb/io/RdbReader.cpp
M plugins/sqlite/CMakeLists.txt
M plugins/sqlite/io/SQLiteCommon.hpp
M scripts/appveyor/test/build.cmd
M scripts/docker/alpine/Dockerfile
A scripts/proj-datumshift
M test/data/autzen/autzen-selection.json
A test/data/ept/1.2-with-color/ept-build.json
A test/data/ept/1.2-with-color/ept-data/0-0-0-0.laz
A test/data/ept/1.2-with-color/ept-hierarchy/0-0-0-0.json
A test/data/ept/1.2-with-color/ept-sources/0.json
A test/data/ept/1.2-with-color/ept-sources/list.json
A test/data/ept/1.2-with-color/ept.json
M test/data/filters/ferry.json.in
A test/data/las/prec3.las
A test/data/pipeline/colorinterp.json.in
M test/unit/CMakeLists.txt
M test/unit/PolygonTest.cpp
M test/unit/apps/pcpipelineTestJSON.cpp
M test/unit/filters/ReciprocityFilterTest.cpp
M test/unit/io/EptReaderTest.cpp
M test/unit/io/LasWriterTest.cpp
M test/unit/io/PcdReaderTest.cpp
M test/unit/io/PcdWriterTest.cpp
M vendor/arbiter/arbiter.cpp
M vendor/arbiter/arbiter.hpp
M vendor/eigen/Eigen/src/Core/Block.h
M vendor/eigen/Eigen/src/Core/Map.h
M vendor/eigen/Eigen/src/Core/MapBase.h
M vendor/eigen/Eigen/src/Core/MatrixBase.h
M vendor/eigen/Eigen/src/Core/Transpose.h
M vendor/eigen/Eigen/src/Core/TriangularMatrix.h
M vendor/kazhdan/PoissonRecon.h
Log Message:
Merge branch 'master' into hobu-win64-buildstuff
Commit: 06e30ec28d6024c12e3c48d23032de7705b4334c
https://github.com/PDAL/PDAL/commit/06e30ec28d6024c12e3c48d23032de7705b4334c
Changed paths:
M plugins/rdb/CMakeLists.txt
Log Message:
rdb building on windows
Commit: 6cbe2dd41ac221133afd3d35254dc6c875e3821c
https://github.com/PDAL/PDAL/commit/6cbe2dd41ac221133afd3d35254dc6c875e3821c
Changed paths:
Log Message:
rdb win64.bat
Compare: https://github.com/PDAL/PDAL/compare/8292582be9e9%5E...6cbe2dd41ac2
More information about the pdal-commits
