[pdal-commits] [PDAL/PDAL] 328368: Defaulted CMake install directory to PDAL_LIB_INST...
Andrew Bell
noreply at github.com
Wed Feb 13 10:57:53 PST 2019
Branch: refs/heads/issue-2342
Home: https://github.com/PDAL/PDAL
Commit: 3283681088865b2925bf1a58e4f1e1d80e047920
https://github.com/PDAL/PDAL/commit/3283681088865b2925bf1a58e4f1e1d80e047920
Author: psalvaggio <salvaggio.philip at gmail.com>
Date: 2019-01-10 (Thu, 10 Jan 2019)
Changed paths:
M cmake/config.cmake
Log Message:
Defaulted CMake install directory to PDAL_LIB_INSTALL_DIR (#2345)
Commit: a4d90f3eb0d5203adc9bf478ad7aaac0f532cb83
https://github.com/PDAL/PDAL/commit/a4d90f3eb0d5203adc9bf478ad7aaac0f532cb83
Author: Connor Manning <connor at hobu.co>
Date: 2019-01-15 (Tue, 15 Jan 2019)
Changed paths:
M pdal/Reader.cpp
M test/unit/SpatialReferenceTest.cpp
Log Message:
Avoid overwriting a default SRS with an empty SRS. (#2346)
* Avoid overwriting a default SRS with an empty SRS.
* Handle potential setting of the SRS multiple times when a default is present.
Commit: 0e48210b53c3971d26ef1496f914d6397a804bfd
https://github.com/PDAL/PDAL/commit/0e48210b53c3971d26ef1496f914d6397a804bfd
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2019-01-17 (Thu, 17 Jan 2019)
Changed paths:
M doc/stages/writers.ply.rst
Log Message:
writer.ply is not streamable
Commit: 83bf2dccaf1535d935469f65a0f3c1fd8c3a3d9d
https://github.com/PDAL/PDAL/commit/83bf2dccaf1535d935469f65a0f3c1fd8c3a3d9d
Date: 2019-01-23 (Wed, 23 Jan 2019)
Changed paths:
M cmake/macros.cmake
M plugins/cpd/CMakeLists.txt
M plugins/fbx/CMakeLists.txt
M plugins/greyhound/CMakeLists.txt
M plugins/i3s/CMakeLists.txt
M plugins/icebridge/CMakeLists.txt
M plugins/matlab/CMakeLists.txt
M plugins/mbio/CMakeLists.txt
M plugins/mrsid/CMakeLists.txt
M plugins/nitf/CMakeLists.txt
M plugins/oci/CMakeLists.txt
M plugins/openscenegraph/CMakeLists.txt
M plugins/pcl/CMakeLists.txt
M plugins/pgpointcloud/CMakeLists.txt
M plugins/python/filters/CMakeLists.txt
M plugins/python/io/CMakeLists.txt
M plugins/rdb/CMakeLists.txt
M plugins/rxp/CMakeLists.txt
M plugins/sqlite/CMakeLists.txt
M test/unit/CMakeLists.txt
Log Message:
Add INCLUDES to some macros (#2352)
* Add INCLUDES option to PDAL_ADD_TEST and PDAL_ADD_PLUGIN
Close #1988
* Missed JSONCPP include.
Commit: 755ac1a62d9c5afccf20d468de9f65649bb1eb24
https://github.com/PDAL/PDAL/commit/755ac1a62d9c5afccf20d468de9f65649bb1eb24
Author: Nicolas Chaulet <nicolas.chaulet at gmail.com>
Date: 2019-01-25 (Fri, 25 Jan 2019)
Changed paths:
M CMakeLists.txt
A cmake/openssl.cmake
M vendor/arbiter/CMakeLists.txt
M vendor/arbiter/arbiter.cpp
M vendor/arbiter/arbiter.hpp
Log Message:
Adding openssl support in order to activate GCS storage (#2353)
Commit: 333f6e268534bb9a77360a3097404c30b5934ad2
https://github.com/PDAL/PDAL/commit/333f6e268534bb9a77360a3097404c30b5934ad2
Author: Pete Gadomski <pete.gadomski at gmail.com>
Date: 2019-02-01 (Fri, 01 Feb 2019)
Changed paths:
M doc/stages/readers.rxp.rst
M plugins/rxp/io/RxpPointcloud.cpp
M plugins/rxp/io/RxpPointcloud.hpp
M plugins/rxp/io/RxpReader.cpp
M plugins/rxp/io/RxpReader.hpp
Log Message:
Implement `Streamable` for `RxpReader` (#2338)
As discussed in #2229, this permits removal of the hackey `minimal`
option on the RxpReader.
Commit: f05523e2ab16c0478f7c412c829498f90a62cae3
https://github.com/PDAL/PDAL/commit/f05523e2ab16c0478f7c412c829498f90a62cae3
Author: Peter Limkilde Svendsen <34237736+plimkilde at users.noreply.github.com>
Changed paths:
M cmake/options.cmake
M doc/stages/filters.delaunay.rst
A filters/DelaunayFilter.cpp
A filters/DelaunayFilter.hpp
A filters/private/delaunator.hpp
M plugins/CMakeLists.txt
R plugins/delaunay/CMakeLists.txt
R plugins/delaunay/filters/DelaunayFilter.cpp
R plugins/delaunay/filters/DelaunayFilter.hpp
R plugins/delaunay/filters/Delaunay_psm.cpp
R plugins/delaunay/filters/Delaunay_psm.h
A test/data/filters/delaunaytest.txt
A test/unit/filters/DelaunayFilterTest.cpp
Log Message:
Switch Delaunay filter to use delaunator-cpp and move to core stages (#2237)
* Switch Delaunay filter to delaunator-cpp and move it from plugins to filters
* Properly use indices from triangulation
* Add unit test from PR #1985
* Delaunator capitalization
* Add copyright notice to delaunator header
* Work around min/max macros on Windows
* Unit test for specific triangulation
* Make Delaunay filter output counterclockwise order
* Also check mesh size
Commit: 4dc60f9cce788be88100166f2153f285d91b3f64
https://github.com/PDAL/PDAL/commit/4dc60f9cce788be88100166f2153f285d91b3f64
Author: chambbj <brad.chambers at gmail.com>
Date: 2019-02-05 (Tue, 05 Feb 2019)
Changed paths:
M HOWTORELEASE.txt
M README.md
M doc/references.rst
Log Message:
Update docs to reflect the Zenodo DOI for citing PDAL releases (#2358)
Commit: 826cdaf5b2ed6fc36661f4c5f8c698de94348085
https://github.com/PDAL/PDAL/commit/826cdaf5b2ed6fc36661f4c5f8c698de94348085
Date: 2019-02-06 (Wed, 06 Feb 2019)
Changed paths:
M io/LasWriter.cpp
M io/LasWriter.hpp
Log Message:
Remove JsonCpp include from LasWriter.hpp.
Commit: 4d56884e7f7eaabfbc9454431e684b311013abb3
https://github.com/PDAL/PDAL/commit/4d56884e7f7eaabfbc9454431e684b311013abb3
Date: 2019-02-07 (Thu, 07 Feb 2019)
Changed paths:
Log Message:
Adds `RiVLib_INCLUDE_DIRS` to rivlib test includes (#2360)
The `${libname}`'s target include directories are private, so they
aren't passed on to the test executable -- we need to explicitly add the
RiVLib include directories again.
Fixes #2359.
Commit: f872c6504621ec17bf434a412774dbf99f63c75e
https://github.com/PDAL/PDAL/commit/f872c6504621ec17bf434a412774dbf99f63c75e
Changed paths:
M CMakeLists.txt
R cmake/openssl.cmake
Log Message:
Revert "Adding openssl support in order to activate GCS storage (#2353)"
This reverts commit 755ac1a62d9c5afccf20d468de9f65649bb1eb24.
Commit: 49eb7dceb87767e804fb9bcf733604f87da778af
https://github.com/PDAL/PDAL/commit/49eb7dceb87767e804fb9bcf733604f87da778af
Date: 2019-02-11 (Mon, 11 Feb 2019)
Changed paths:
M scripts/docker/ubuntu/Dockerfile
Log Message:
Use head of libharu.
Commit: f84daa065b0f764a4993b82b38544aac00bb7b1f
https://github.com/PDAL/PDAL/commit/f84daa065b0f764a4993b82b38544aac00bb7b1f
Changed paths:
M CMakeLists.txt
M HOWTORELEASE.txt
M README.md
M io/LasWriter.cpp
M io/LasWriter.hpp
Log Message:
Merge remote-tracking branch 'origin/master'
Commit: 0b22b64cadbf8f55581679b3ff941d8067e60d58
https://github.com/PDAL/PDAL/commit/0b22b64cadbf8f55581679b3ff941d8067e60d58
Date: 2019-02-12 (Tue, 12 Feb 2019)
Changed paths:
M scripts/docker/alpine/Dockerfile
Log Message:
Set dockerfile to run with test base.
Commit: ebc33ba3e723354c05f80818785cc6bc6eed3a6a
https://github.com/PDAL/PDAL/commit/ebc33ba3e723354c05f80818785cc6bc6eed3a6a
Date: 2019-02-13 (Wed, 13 Feb 2019)
Changed paths:
Log Message:
Set Dockerfile back to latest.
Commit: 3a934ca35bd0f7e8754706eb34f0b2022199bf80
https://github.com/PDAL/PDAL/commit/3a934ca35bd0f7e8754706eb34f0b2022199bf80
Changed paths:
M cmake/python.cmake
Log Message:
Update python.cmake (#2369)
* Test python module.
* Set python min version to 2.4.
* Require version 2.7 of Python.
Commit: 3bc0fb99f146063e16a882d00e90efbd6063c352
https://github.com/PDAL/PDAL/commit/3bc0fb99f146063e16a882d00e90efbd6063c352
Changed paths:
M HOWTORELEASE.txt
M README.md
M io/LasWriter.cpp
M io/LasWriter.hpp
M pdal/Reader.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into issue-2342
Compare: https://github.com/PDAL/PDAL/compare/4e6a0efc3649...3bc0fb99f146
More information about the pdal-commits
