[pdal-commits] [PDAL/PDAL] 49eb7d: Use head of libharu.
Andrew Bell
noreply at github.com
Thu Feb 14 14:29:33 PST 2019
Branch: refs/heads/issue-2351
Home: https://github.com/PDAL/PDAL
Commit: 49eb7dceb87767e804fb9bcf733604f87da778af
https://github.com/PDAL/PDAL/commit/49eb7dceb87767e804fb9bcf733604f87da778af
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2019-02-11 (Mon, 11 Feb 2019)
Changed paths:
M scripts/docker/ubuntu/Dockerfile
Log Message:
Commit: f84daa065b0f764a4993b82b38544aac00bb7b1f
https://github.com/PDAL/PDAL/commit/f84daa065b0f764a4993b82b38544aac00bb7b1f
Changed paths:
M CMakeLists.txt
M HOWTORELEASE.txt
M README.md
R cmake/openssl.cmake
M cmake/options.cmake
M doc/references.rst
M doc/stages/filters.delaunay.rst
M doc/stages/readers.rxp.rst
A filters/DelaunayFilter.cpp
A filters/DelaunayFilter.hpp
A filters/private/delaunator.hpp
M io/LasWriter.cpp
M io/LasWriter.hpp
M plugins/CMakeLists.txt
R plugins/delaunay/CMakeLists.txt
R plugins/delaunay/filters/DelaunayFilter.cpp
R plugins/delaunay/filters/DelaunayFilter.hpp
R plugins/delaunay/filters/Delaunay_psm.cpp
R plugins/delaunay/filters/Delaunay_psm.h
M plugins/rxp/CMakeLists.txt
M plugins/rxp/io/RxpPointcloud.cpp
M plugins/rxp/io/RxpPointcloud.hpp
M plugins/rxp/io/RxpReader.cpp
M plugins/rxp/io/RxpReader.hpp
A test/data/filters/delaunaytest.txt
M test/unit/CMakeLists.txt
A test/unit/filters/DelaunayFilterTest.cpp
M vendor/arbiter/CMakeLists.txt
M vendor/arbiter/arbiter.cpp
M vendor/arbiter/arbiter.hpp
Log Message:
Merge remote-tracking branch 'origin/master'
Commit: 0b22b64cadbf8f55581679b3ff941d8067e60d58
https://github.com/PDAL/PDAL/commit/0b22b64cadbf8f55581679b3ff941d8067e60d58
Date: 2019-02-12 (Tue, 12 Feb 2019)
Changed paths:
M scripts/docker/alpine/Dockerfile
Log Message:
Set dockerfile to run with test base.
Commit: ebc33ba3e723354c05f80818785cc6bc6eed3a6a
https://github.com/PDAL/PDAL/commit/ebc33ba3e723354c05f80818785cc6bc6eed3a6a
Date: 2019-02-13 (Wed, 13 Feb 2019)
Changed paths:
Log Message:
Set Dockerfile back to latest.
Commit: 3a934ca35bd0f7e8754706eb34f0b2022199bf80
https://github.com/PDAL/PDAL/commit/3a934ca35bd0f7e8754706eb34f0b2022199bf80
Changed paths:
M cmake/python.cmake
Log Message:
Update python.cmake (#2369)
* Test python module.
* Set python min version to 2.4.
* Require version 2.7 of Python.
Commit: efa1d8e0e254a70214793e0cef48e8584006e79b
https://github.com/PDAL/PDAL/commit/efa1d8e0e254a70214793e0cef48e8584006e79b
Author: Norman Barker <norman at tiledb.io>
Changed paths:
M appveyor.yml
A cmake/modules/FindTileDB.cmake
A cmake/tiledb.cmake
M doc/development/compilation/dependencies.rst
M doc/quickstart.rst
A doc/stages/readers.tiledb.rst
A doc/stages/writers.tiledb.rst
A plugins/tiledb/CMakeLists.txt
A plugins/tiledb/io/TileDBReader.cpp
A plugins/tiledb/io/TileDBReader.hpp
A plugins/tiledb/io/TileDBWriter.cpp
A plugins/tiledb/io/TileDBWriter.hpp
A plugins/tiledb/test/TileDBReaderTest.cpp
A plugins/tiledb/test/TileDBWriterTest.cpp
M scripts/conda/osx.sh
M scripts/conda/win64.sh
M scripts/docker/master/ubuntu/Dockerfile
A test/data/tiledb/array/__7683a2d8dd0b48ae809dd3f1a9501da4_1549556043355/OffsetTime.tdb
A test/data/tiledb/array/__7683a2d8dd0b48ae809dd3f1a9501da4_1549556043355/__coords.tdb
A test/data/tiledb/array/__7683a2d8dd0b48ae809dd3f1a9501da4_1549556043355/__fragment_metadata.tdb
A test/data/tiledb/array/__array_schema.tdb
A test/data/tiledb/array/__lock.tdb
Log Message:
TileDB plugin (#2363)
* initial read and write for TileDB
* 2363:pr comments
* removed dependency on pdal-tiledb branch
Commit: 2b711cbd2dc465cfa261f810e3e2f10e9a5eed7f
https://github.com/PDAL/PDAL/commit/2b711cbd2dc465cfa261f810e3e2f10e9a5eed7f
Author: Howard Butler <howard at hobu.co>
Date: 2019-02-14 (Thu, 14 Feb 2019)
Changed paths:
M appveyor.yml
R scripts/appveyor/build.cmd
A scripts/appveyor/conda/build.cmd
A scripts/appveyor/conda/recipe/bld.bat
A scripts/appveyor/conda/recipe/build.sh
A scripts/appveyor/conda/recipe/meta.yaml
A scripts/appveyor/conda/recipe/scripts/activate.bat
A scripts/appveyor/conda/recipe/scripts/activate.sh
A scripts/appveyor/conda/recipe/scripts/deactivate.bat
A scripts/appveyor/conda/recipe/scripts/deactivate.sh
M scripts/appveyor/config.cmd
R scripts/appveyor/install.cmd
R scripts/appveyor/test.cmd
A scripts/appveyor/test/build.cmd
A scripts/appveyor/test/test.cmd
Log Message:
Add Testing and Conda targets for Appveyor (#2371)
* start building conda pdal package after success to push to s3
* split appveyor config
* typo
* typo
* put back original test config
* conda side build attempt
* config/build adjustment
* typo
* conda-build
* ls directory
* add conda recipe
* rename recipe file
* conda build and artifact
* positional argument at the end
* only install conda stuff for test build
* install conda-build
* lint
* remove dead command
* try calling conda
* start /wait
* try build mkdir
* another cycle
* conda clean
* -y
* ordering
* clobber boost conflicdts
* switch of OCI
* try copying artifacdt
* purge build
* call conda
* copy correct file
* debugging lint
Commit: 18e48a2aaab9b9ade86834f24276c2ff3a88e6dc
https://github.com/PDAL/PDAL/commit/18e48a2aaab9b9ade86834f24276c2ff3a88e6dc
Changed paths:
M CMakeLists.txt
M apps/CMakeLists.txt
R cmake/geos.cmake
R cmake/modules/FindGEOS.cmake
M doc/development/compilation/windows.rst
M doc/workshop/docker.rst.save
M doc/workshop/includes/substitutions.rst
M doc/workshop/osgeo4w.rst
M filters/CropFilter.cpp
M filters/HexBinFilter.cpp
M filters/NormalFilter.cpp
M filters/OverlayFilter.cpp
M filters/OverlayFilter.hpp
M filters/StatsFilter.cpp
M filters/private/Point.cpp
M filters/private/Point.hpp
M io/Ilvis2MetadataReader.cpp
M io/Ilvis2MetadataReader.hpp
M pdal/GDALUtils.cpp
M pdal/GDALUtils.hpp
R pdal/GEOSUtils.cpp
R pdal/GEOSUtils.hpp
M pdal/Geometry.cpp
M pdal/Geometry.hpp
M pdal/Polygon.cpp
M pdal/Polygon.hpp
M pdal/Stage.cpp
M pdal/pdal_config.cpp
M plugins/geowave/io/GeoWaveReader.hpp
M scripts/appveyor/conda/build.cmd
M scripts/appveyor/conda/recipe/meta.yaml
M scripts/appveyor/test/build.cmd
M scripts/docker/Dockerfile
R scripts/docker/Dockerfile.alpinedeps
M scripts/docker/alpine/Dockerfile.dependencies
R scripts/docker/master/alpine/Dockerfile
R scripts/docker/master/ubuntu/Dockerfile
M scripts/docker/ubuntu/dependencies/Dockerfile
M scripts/linux-install-scripts/packages.sh
M test/data/pipeline/crop_wkt.json.in
M test/unit/PolygonTest.cpp
M test/unit/SpatialReferenceTest.cpp
Log Message:
Remove GEOS from PDAL (#2370)
* Remove GEOS as a dependency.
* Cleanup.
* Move tiledb build from deleted Dockerfile.
Commit: 88b50d9f3b327f5cf1cb4122576a7e7e4d0570e1
https://github.com/PDAL/PDAL/commit/88b50d9f3b327f5cf1cb4122576a7e7e4d0570e1
Changed paths:
M CMakeLists.txt
M appveyor.yml
R cmake/geos.cmake
M pdal/Geometry.cpp
M pdal/Geometry.hpp
M pdal/Polygon.cpp
M pdal/Polygon.hpp
M pdal/Stage.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into issue-2351
Compare: https://github.com/PDAL/PDAL/compare/345567094dbe...88b50d9f3b32
More information about the pdal-commits
