[pdal-commits] [PDAL/PDAL] 96a293: Force script exit on error.
Howard Butler
noreply at github.com
Tue Jul 16 20:02:02 PDT 2019
Branch: refs/heads/azure-pipelines
Home: https://github.com/PDAL/PDAL
Commit: 96a293c8d871d75a074017ce62d35dc8d91c8bcd
https://github.com/PDAL/PDAL/commit/96a293c8d871d75a074017ce62d35dc8d91c8bcd
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2019-06-27 (Thu, 27 Jun 2019)
Changed paths:
M scripts/ci/script.sh
Log Message:
Commit: c53d332f7d8bf3db832f8c44ddac3292b1b0a568
https://github.com/PDAL/PDAL/commit/c53d332f7d8bf3db832f8c44ddac3292b1b0a568
Date: 2019-07-03 (Wed, 03 Jul 2019)
Changed paths:
M pdal/util/Utils.hpp
M plugins/python/filters/CMakeLists.txt
M plugins/python/io/CMakeLists.txt
M plugins/python/plang/Environment.cpp
Log Message:
Fix global symbol export for python (#2598)
* Changes for ubuntu python library loading.
* Remove test check.
* Clean-up.
Commit: 99efbab5d0bbfdbce56da6d537e67eddd69829e7
https://github.com/PDAL/PDAL/commit/99efbab5d0bbfdbce56da6d537e67eddd69829e7
Changed paths:
M plugins/tiledb/io/TileDBWriter.cpp
Log Message:
Fix index/coords issues. (#2599)
Close #2596
Commit: 959fbed9ede183ce4c1e269ccc91bb01dff5eae7
https://github.com/PDAL/PDAL/commit/959fbed9ede183ce4c1e269ccc91bb01dff5eae7
Changed paths:
M apps/pdal.cpp
Log Message:
Error on unexpected arguments for raw 'pdal' command. (#2589)
Commit: 3b8e72355bbaa00ca2e9ec94a73812925026f610
https://github.com/PDAL/PDAL/commit/3b8e72355bbaa00ca2e9ec94a73812925026f610
Author: Mathieu <mathieu1 at users.noreply.github.com>
Date: 2019-07-04 (Thu, 04 Jul 2019)
Changed paths:
Log Message:
Use c++ comments (#2601)
Commit: 82402cfd1aec436941571ce2beb535493a70b719
https://github.com/PDAL/PDAL/commit/82402cfd1aec436941571ce2beb535493a70b719
Date: 2019-07-08 (Mon, 08 Jul 2019)
Changed paths:
Log Message:
Use generic names for plugins.
Commit: 87d9384da84464526f35ee0a89634dfdfc6ead7b
https://github.com/PDAL/PDAL/commit/87d9384da84464526f35ee0a89634dfdfc6ead7b
Date: 2019-07-12 (Fri, 12 Jul 2019)
Changed paths:
M io/EptReader.cpp
Log Message:
Fix thread-safety issue when writing addon data. (#2611)
Fix point count for addon data initialization.
Close #2610
Commit: abecd56a177c4e37a791ee27d4f6e7d2c403367a
https://github.com/PDAL/PDAL/commit/abecd56a177c4e37a791ee27d4f6e7d2c403367a
Changed paths:
M plugins/e57/io/E57Reader.cpp
M plugins/e57/io/E57Reader.hpp
M plugins/e57/libE57Format/src/CheckedFile.cpp
M plugins/e57/libE57Format/src/CheckedFile.h
Log Message:
Rename open64 to portableOpen. (#2608)
* Rename open64 to portableOpen.
* Make sure off_t is defined.
Commit: 69282f876476f927b8a81de333647f2f7ed80f2f
https://github.com/PDAL/PDAL/commit/69282f876476f927b8a81de333647f2f7ed80f2f
Author: Pravin Shinde <pravin at helix.re>
Date: 2019-07-15 (Mon, 15 Jul 2019)
Changed paths:
M io/EptReader.cpp
M io/EptReader.hpp
M test/unit/io/EptReaderTest.cpp
Log Message:
Streamable EPT Reader (#2603)
Commit: 838ec608dd288369687f3e81d6c96446565c417e
https://github.com/PDAL/PDAL/commit/838ec608dd288369687f3e81d6c96446565c417e
Changed paths:
M vendor/arbiter/arbiter.cpp
Log Message:
Updated Arbiter with upstream (#2604)
Commit: 2be74ec122fbaa273e3a3993ab61db6814f0c3f8
https://github.com/PDAL/PDAL/commit/2be74ec122fbaa273e3a3993ab61db6814f0c3f8
Author: Nicolas Chaulet <nicolas.chaulet at gmail.com>
Changed paths:
M plugins/e57/io/E57Writer.cpp
M plugins/e57/io/E57Writer.hpp
M plugins/e57/io/Scan.cpp
M plugins/e57/io/Scan.hpp
M plugins/e57/io/Utils.cpp
M plugins/e57/test/E57ReaderTest.cpp
M plugins/e57/test/ScanTest.cpp
Log Message:
e57 - Save bounding box and implement Preview function (#2595)
* Preview function for e57
* Bounding box support for preview
* Address comments
* Return type fixed for transformPoint
Commit: 45a497ea5b615a0d56f86667b2491fcd80e23182
https://github.com/PDAL/PDAL/commit/45a497ea5b615a0d56f86667b2491fcd80e23182
Changed paths:
M io/PlyWriter.cpp
Log Message:
Fail if we can't open PLY output.
Commit: a642d6c23622d6e6004436565b9ee493dd297ac5
https://github.com/PDAL/PDAL/commit/a642d6c23622d6e6004436565b9ee493dd297ac5
Date: 2019-07-16 (Tue, 16 Jul 2019)
Changed paths:
M PDALConfig.cmake.in
Log Message:
Use the proper libraries for linking with downstream projects.
Commit: 4434368027fe5110c45b54a80a7cae98dab4ca1e
https://github.com/PDAL/PDAL/commit/4434368027fe5110c45b54a80a7cae98dab4ca1e
Author: Howard Butler <howard at hobu.co>
Changed paths:
M apps/pdal.cpp
M io/EptReader.cpp
M io/EptReader.hpp
M io/PlyWriter.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into azure-pipelines
Commit: 5472f17118feaac6f942e55a681ccfbef34d0a7a
https://github.com/PDAL/PDAL/commit/5472f17118feaac6f942e55a681ccfbef34d0a7a
Changed paths:
M scripts/azp/osx.yml
Log Message:
setup conda compiler for osx
Compare: https://github.com/PDAL/PDAL/compare/74e648e8f1d1...5472f17118fe
More information about the pdal-commits
