[pdal-commits] [PDAL/PDAL] fbff38: Remove Greyhound driver from PDAL (#2594)
Andrew Bell
noreply at github.com
Fri Jul 26 13:42:29 PDT 2019
Branch: refs/heads/e57-check
Home: https://github.com/PDAL/PDAL
Commit: fbff38ee995d5c478e27978ba7eb65fd7b2016e1
https://github.com/PDAL/PDAL/commit/fbff38ee995d5c478e27978ba7eb65fd7b2016e1
Author: Howard Butler <howard at hobu.co>
Date: 2019-07-17 (Wed, 17 Jul 2019)
Changed paths:
M cmake/options.cmake
R doc/stages/readers.greyhound.rst
M doc/stages/readers.rst
R doc/stages/writers.greyhound.rst
M doc/stages/writers.rst
M pdal/StageExtensions.cpp
M pdal/StageFactory.cpp
M plugins/CMakeLists.txt
R plugins/greyhound/CMakeLists.txt
R plugins/greyhound/NOTE
R plugins/greyhound/io/CompressionStream.cpp
R plugins/greyhound/io/CompressionStream.hpp
R plugins/greyhound/io/GreyhoundCommon.cpp
R plugins/greyhound/io/GreyhoundCommon.hpp
R plugins/greyhound/io/GreyhoundReader.cpp
R plugins/greyhound/io/GreyhoundReader.hpp
R plugins/greyhound/io/GreyhoundWriter.cpp
R plugins/greyhound/io/GreyhoundWriter.hpp
R plugins/greyhound/io/bounds.cpp
R plugins/greyhound/io/bounds.hpp
R plugins/greyhound/io/dir.hpp
R plugins/greyhound/io/point.hpp
R plugins/greyhound/test/GreyhoundReaderTest.cpp
M test/unit/StageFactoryTest.cpp
Log Message:
* remove greyhound driver
* complete removal of greyhound support #2594
* greyhound:// in StageFactoryTest
Commit: 1a4584b8e0200fbe80b8c142fee0a3e93d9c1de3
https://github.com/PDAL/PDAL/commit/1a4584b8e0200fbe80b8c142fee0a3e93d9c1de3
Changed paths:
M scripts/docker/ubuntu/Dockerfile
Log Message:
update ubuntu dockerfile
Commit: e38130c113f40e8fe24a04a8ff3681cb1286c0be
https://github.com/PDAL/PDAL/commit/e38130c113f40e8fe24a04a8ff3681cb1286c0be
Date: 2019-07-18 (Thu, 18 Jul 2019)
Changed paths:
Log Message:
build at -j 2
Commit: 2547fe706b179087b6c31920ca9e160008d7cd55
https://github.com/PDAL/PDAL/commit/2547fe706b179087b6c31920ca9e160008d7cd55
Changed paths:
M scripts/docker/ubuntu/dependencies/Dockerfile
Log Message:
dockerfile for ubuntu
Commit: eb824868e69fc9800bf4bc1707683dd9e1e3c00c
https://github.com/PDAL/PDAL/commit/eb824868e69fc9800bf4bc1707683dd9e1e3c00c
Changed paths:
Log Message:
dockerfile typo
Commit: 29c580fbac76c6ac8a6edb8ee8833ac31c11fcb1
https://github.com/PDAL/PDAL/commit/29c580fbac76c6ac8a6edb8ee8833ac31c11fcb1
Author: chambbj <brad.chambers at gmail.com>
Date: 2019-07-19 (Fri, 19 Jul 2019)
Changed paths:
M filters/PlaneFitFilter.cpp
Log Message:
Eigenvalues are not used in the PlaneFit filter (#2623)
Commit: 100fe03d28c43be4ae147082cf06735b2ba8ea3c
https://github.com/PDAL/PDAL/commit/100fe03d28c43be4ae147082cf06735b2ba8ea3c
Changed paths:
Log Message:
go back to ubuntu gdal
Commit: 4890382b3a4e0ab23e2af7fd6d9b02281aa7a453
https://github.com/PDAL/PDAL/commit/4890382b3a4e0ab23e2af7fd6d9b02281aa7a453
Date: 2019-07-22 (Mon, 22 Jul 2019)
Changed paths:
Log Message:
ubuntu docker refresh
Commit: 28541f67430e5f3e4e96f7000b9cc9f6dd70e5b4
https://github.com/PDAL/PDAL/commit/28541f67430e5f3e4e96f7000b9cc9f6dd70e5b4
Author: Pravin Shinde <pravin at helix.re>
Date: 2019-07-23 (Tue, 23 Jul 2019)
Changed paths:
M vendor/arbiter/arbiter.cpp
M vendor/arbiter/arbiter.hpp
Log Message:
Update arbiter with upstream (#2628)
* Updated arbiter with upstream
* Fixed build error on windows.
Commit: 4f1cb34a59120feb09a1801e3c71e5a88367769c
https://github.com/PDAL/PDAL/commit/4f1cb34a59120feb09a1801e3c71e5a88367769c
Date: 2019-07-24 (Wed, 24 Jul 2019)
Changed paths:
M cmake/python.cmake
M plugins/python/plang/Environment.cpp
M plugins/python/plang/Invocation.cpp
M plugins/python/plang/Redirector.cpp
Log Message:
Remove Python2 support (#2630)
* Remove Python2 support
* remove QUIET
Commit: e4dfe08bdebd954b2917204a7d1a63d3c9d7fd69
https://github.com/PDAL/PDAL/commit/e4dfe08bdebd954b2917204a7d1a63d3c9d7fd69
Date: 2019-07-25 (Thu, 25 Jul 2019)
Changed paths:
Log Message:
bump minimum numpy version to 1.13, which should cover Ubuntu 18.04 (#2632)
Commit: 66330967c1cd460e8f96cd40a57807f166b92f40
https://github.com/PDAL/PDAL/commit/66330967c1cd460e8f96cd40a57807f166b92f40
Author: Connor Manning <connor at hobu.co>
Changed paths:
M io/EptReader.cpp
Log Message:
Use vector to avoid leaking streaming EPT buffers in case of exception. (#2612)
Commit: 962040136f9472b8b4ad210207c575cd37af9652
https://github.com/PDAL/PDAL/commit/962040136f9472b8b4ad210207c575cd37af9652
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2019-07-26 (Fri, 26 Jul 2019)
Changed paths:
M io/EptReader.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into e57-check
Commit: ef1f21b67654a149536f394a9dae4be8bd0b6787
https://github.com/PDAL/PDAL/commit/ef1f21b67654a149536f394a9dae4be8bd0b6787
Changed paths:
M plugins/e57/io/E57Writer.cpp
Log Message:
Fix some small issues.
Compare: https://github.com/PDAL/PDAL/compare/1b3f2889e492...ef1f21b67654
More information about the pdal-commits
