[pdal-commits] [PDAL/PDAL] 8d4924: Projfix (#2548)
Andrew Bell
noreply at github.com
Mon Jun 3 12:14:24 PDT 2019
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 8d492460b483f0b5f3a00318f0793d3d254ab4d0
https://github.com/PDAL/PDAL/commit/8d492460b483f0b5f3a00318f0793d3d254ab4d0
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2019-06-03 (Mon, 03 Jun 2019)
Changed paths:
M apps/pdal.cpp
M cmake/policies.cmake
M dimbuilder/DimBuilder.cpp
M filters/ReprojectionFilter.cpp
M filters/ReprojectionFilter.hpp
M filters/private/Point.hpp
M filters/private/hexer/Path.cpp
M io/EptReader.cpp
M pdal/GDALUtils.cpp
M pdal/GDALUtils.hpp
M pdal/Geometry.cpp
M pdal/SpatialReference.cpp
M pdal/Stage.hpp
A pdal/private/SrsTransform.cpp
A pdal/private/SrsTransform.hpp
M plugins/e57/io/E57Reader.cpp
M plugins/e57/libE57Format/src/E57Exception.cpp
M plugins/i3s/io/EsriReader.cpp
M plugins/i3s/io/EsriReader.hpp
M plugins/i3s/test/SlpkReaderTest.cpp
M plugins/i3s/test/i3sReaderTest.cpp
M plugins/icebridge/io/Hdf5Handler.hpp
M plugins/icebridge/test/IcebridgeReaderTest.cpp
M test/data/ept/ept-star/ept.json
M test/data/filters/ferry.json.in
M test/unit/ProgramArgsTest.cpp
M test/unit/SpatialReferenceTest.cpp
M test/unit/io/EptReaderTest.cpp
M test/unit/io/LasReaderTest.cpp
M test/unit/io/LasWriterTest.cpp
Log Message:
Projfix (#2548)
* Fix WKT generation for polygons with islands.
* Add test.
* Add link to photo of data.
* Export functions for test.
* Add another test function.
* Compiler warning fixes.
* Test fixes.
* Compiler error.
* Warning fix.
* SRS fix.
* Add reference.
* Explicit SRS.
* Use nullptr to SRS ctor.
* Test meter spelling.
* Use X, Y and Z in geocentric transform.
Remove dead code.
* More test.
* Lat/Lon for EPSG:4326 with GDAL 3+
* More test.
* Add SrsTransform and eliminate a ton of overly complex code.
Also make tests pass in the process.
* Fix capitalization.
* Spatial ref precision.
* Read data from the metadata child "data" rather than the VLR node's data
for forwarded VLRs.
* Add test LAS file with valid WKT.
* More PROJ 3 fixes.
* Updates for PROJ 6.
* Make SrsTransform private.
* Moved SrsTransform.
* Add doc.
More information about the pdal-commits
