[pdal-commits] [PDAL/PDAL] 2eb274: Merge branch 'master' into ept-zstandard
Connor Manning noreply at github.com
Wed Jun 26 08:45:49 PDT 2019
  Branch: refs/heads/ept-zstandard-ifdefs
  Home:   https://github.com/PDAL/PDAL
  Commit: 2eb274f66721cc1e95df784eb8b9501d339cffdd
      https://github.com/PDAL/PDAL/commit/2eb274f66721cc1e95df784eb8b9501d339cffdd
  Author: Nicolas Chaulet <nicolas.chaulet at gmail.com>
  Date:   2019-06-24 (Mon, 24 Jun 2019)
  Changed paths:
    M io/EptReader.cpp
    M pdal/PDALUtils.hpp
    M pdal/util/FileUtils.cpp
    M pdal/util/Utils.cpp
    M scripts/docker/alpine/Dockerfile.dependencies
    M test/unit/apps/TIndexTest.cpp
    M test/unit/apps/TranslateTest.cpp
    M vendor/gtest/CMakeLists.txt
    M vendor/gtest/Makefile.am
    R vendor/gtest/Makefile.in
    R vendor/gtest/README
    A vendor/gtest/README.md
    R vendor/gtest/aclocal.m4
    R vendor/gtest/build-aux/config.guess
    R vendor/gtest/build-aux/config.h.in
    R vendor/gtest/build-aux/config.sub
    R vendor/gtest/build-aux/depcomp
    R vendor/gtest/build-aux/install-sh
    R vendor/gtest/build-aux/ltmain.sh
    R vendor/gtest/build-aux/missing
    A vendor/gtest/cmake/Config.cmake.in
    A vendor/gtest/cmake/gtest.pc.in
    A vendor/gtest/cmake/gtest_main.pc.in
    M vendor/gtest/cmake/internal_utils.cmake
    R vendor/gtest/configure
    M vendor/gtest/configure.ac
    A vendor/gtest/docs/Pkgconfig.md
    A vendor/gtest/docs/PumpManual.md
    A vendor/gtest/docs/XcodeGuide.md
    A vendor/gtest/docs/advanced.md
    A vendor/gtest/docs/faq.md
    A vendor/gtest/docs/primer.md
    A vendor/gtest/docs/samples.md
    R vendor/gtest/fused-src/gtest/gtest-all.cc
    R vendor/gtest/fused-src/gtest/gtest.h
    R vendor/gtest/fused-src/gtest/gtest_main.cc
    M vendor/gtest/include/gtest/gtest-death-test.h
    M vendor/gtest/include/gtest/gtest-message.h
    M vendor/gtest/include/gtest/gtest-param-test.h
    M vendor/gtest/include/gtest/gtest-param-test.h.pump
    M vendor/gtest/include/gtest/gtest-printers.h
    M vendor/gtest/include/gtest/gtest-spi.h
    M vendor/gtest/include/gtest/gtest-test-part.h
    M vendor/gtest/include/gtest/gtest-typed-test.h
    M vendor/gtest/include/gtest/gtest.h
    M vendor/gtest/include/gtest/gtest_pred_impl.h
    M vendor/gtest/include/gtest/gtest_prod.h
    A vendor/gtest/include/gtest/internal/custom/README.md
    A vendor/gtest/include/gtest/internal/custom/gtest-port.h
    A vendor/gtest/include/gtest/internal/custom/gtest-printers.h
    A vendor/gtest/include/gtest/internal/custom/gtest.h
    M vendor/gtest/include/gtest/internal/gtest-death-test-internal.h
    M vendor/gtest/include/gtest/internal/gtest-filepath.h
    M vendor/gtest/include/gtest/internal/gtest-internal.h
    M vendor/gtest/include/gtest/internal/gtest-linked_ptr.h
    M vendor/gtest/include/gtest/internal/gtest-param-util-generated.h
    M vendor/gtest/include/gtest/internal/gtest-param-util-generated.h.pump
    M vendor/gtest/include/gtest/internal/gtest-param-util.h
    A vendor/gtest/include/gtest/internal/gtest-port-arch.h
    M vendor/gtest/include/gtest/internal/gtest-port.h
    M vendor/gtest/include/gtest/internal/gtest-string.h
    M vendor/gtest/include/gtest/internal/gtest-tuple.h
    M vendor/gtest/include/gtest/internal/gtest-tuple.h.pump
    M vendor/gtest/include/gtest/internal/gtest-type-util.h
    M vendor/gtest/include/gtest/internal/gtest-type-util.h.pump
    R vendor/gtest/m4/libtool.m4
    R vendor/gtest/m4/ltoptions.m4
    R vendor/gtest/m4/ltsugar.m4
    R vendor/gtest/m4/ltversion.m4
    R vendor/gtest/m4/lt~obsolete.m4
    R vendor/gtest/msvc/gtest-md.vcproj
    R vendor/gtest/msvc/gtest.vcproj
    R vendor/gtest/msvc/gtest_main-md.vcproj
    R vendor/gtest/msvc/gtest_main.vcproj
    R vendor/gtest/msvc/gtest_prod_test-md.vcproj
    R vendor/gtest/msvc/gtest_prod_test.vcproj
    R vendor/gtest/msvc/gtest_unittest-md.vcproj
    R vendor/gtest/msvc/gtest_unittest.vcproj
    M vendor/gtest/samples/prime_tables.h
    M vendor/gtest/samples/sample1.cc
    M vendor/gtest/samples/sample1.h
    M vendor/gtest/samples/sample10_unittest.cc
    M vendor/gtest/samples/sample1_unittest.cc
    M vendor/gtest/samples/sample2.cc
    M vendor/gtest/samples/sample2.h
    M vendor/gtest/samples/sample2_unittest.cc
    M vendor/gtest/samples/sample3-inl.h
    M vendor/gtest/samples/sample3_unittest.cc
    M vendor/gtest/samples/sample4.cc
    M vendor/gtest/samples/sample4.h
    M vendor/gtest/samples/sample4_unittest.cc
    M vendor/gtest/samples/sample5_unittest.cc
    M vendor/gtest/samples/sample6_unittest.cc
    M vendor/gtest/samples/sample7_unittest.cc
    M vendor/gtest/samples/sample8_unittest.cc
    M vendor/gtest/samples/sample9_unittest.cc
    A vendor/gtest/scripts/common.py
    M vendor/gtest/scripts/fuse_gtest_files.py
    M vendor/gtest/scripts/gen_gtest_pred_impl.py
    A vendor/gtest/scripts/release_docs.py
    A vendor/gtest/scripts/upload.py
    A vendor/gtest/scripts/upload_gtest.py
    M vendor/gtest/src/gtest-all.cc
    M vendor/gtest/src/gtest-death-test.cc
    M vendor/gtest/src/gtest-filepath.cc
    M vendor/gtest/src/gtest-internal-inl.h
    M vendor/gtest/src/gtest-port.cc
    M vendor/gtest/src/gtest-printers.cc
    M vendor/gtest/src/gtest-test-part.cc
    M vendor/gtest/src/gtest-typed-test.cc
    M vendor/gtest/src/gtest.cc
    M vendor/gtest/src/gtest_main.cc
    A vendor/gtest/test/BUILD.bazel
    A vendor/gtest/test/googletest-break-on-failure-unittest.py
    A vendor/gtest/test/googletest-break-on-failure-unittest_.cc
    A vendor/gtest/test/googletest-catch-exceptions-test.py
    A vendor/gtest/test/googletest-catch-exceptions-test_.cc
    A vendor/gtest/test/googletest-color-test.py
    A vendor/gtest/test/googletest-color-test_.cc
    A vendor/gtest/test/googletest-death-test-test.cc
    A vendor/gtest/test/googletest-death-test_ex_test.cc
    A vendor/gtest/test/googletest-env-var-test.py
    A vendor/gtest/test/googletest-env-var-test_.cc
    A vendor/gtest/test/googletest-filepath-test.cc
    A vendor/gtest/test/googletest-filter-unittest.py
    A vendor/gtest/test/googletest-filter-unittest_.cc
    A vendor/gtest/test/googletest-json-outfiles-test.py
    A vendor/gtest/test/googletest-json-output-unittest.py
    A vendor/gtest/test/googletest-linked-ptr-test.cc
    A vendor/gtest/test/googletest-list-tests-unittest.py
    A vendor/gtest/test/googletest-list-tests-unittest_.cc
    A vendor/gtest/test/googletest-listener-test.cc
    A vendor/gtest/test/googletest-message-test.cc
    A vendor/gtest/test/googletest-options-test.cc
    A vendor/gtest/test/googletest-output-test-golden-lin.txt
    A vendor/gtest/test/googletest-output-test.py
    A vendor/gtest/test/googletest-output-test_.cc
    A vendor/gtest/test/googletest-param-test-invalid-name1-test.py
    A vendor/gtest/test/googletest-param-test-invalid-name1-test_.cc
    A vendor/gtest/test/googletest-param-test-invalid-name2-test.py
    A vendor/gtest/test/googletest-param-test-invalid-name2-test_.cc
    A vendor/gtest/test/googletest-param-test-test.cc
    A vendor/gtest/test/googletest-param-test-test.h
    A vendor/gtest/test/googletest-param-test2-test.cc
    A vendor/gtest/test/googletest-port-test.cc
    A vendor/gtest/test/googletest-printers-test.cc
    A vendor/gtest/test/googletest-shuffle-test.py
    A vendor/gtest/test/googletest-shuffle-test_.cc
    A vendor/gtest/test/googletest-test-part-test.cc
    A vendor/gtest/test/googletest-test2_test.cc
    A vendor/gtest/test/googletest-throw-on-failure-test.py
    A vendor/gtest/test/googletest-throw-on-failure-test_.cc
    A vendor/gtest/test/googletest-tuple-test.cc
    A vendor/gtest/test/googletest-uninitialized-test.py
    A vendor/gtest/test/googletest-uninitialized-test_.cc
    R vendor/gtest/test/gtest-death-test_ex_test.cc
    R vendor/gtest/test/gtest-death-test_test.cc
    R vendor/gtest/test/gtest-filepath_test.cc
    R vendor/gtest/test/gtest-linked_ptr_test.cc
    R vendor/gtest/test/gtest-listener_test.cc
    R vendor/gtest/test/gtest-message_test.cc
    R vendor/gtest/test/gtest-options_test.cc
    R vendor/gtest/test/gtest-param-test2_test.cc
    R vendor/gtest/test/gtest-param-test_test.cc
    R vendor/gtest/test/gtest-param-test_test.h
    R vendor/gtest/test/gtest-port_test.cc
    R vendor/gtest/test/gtest-printers_test.cc
    R vendor/gtest/test/gtest-test-part_test.cc
    R vendor/gtest/test/gtest-tuple_test.cc
    M vendor/gtest/test/gtest-typed-test2_test.cc
    M vendor/gtest/test/gtest-typed-test_test.cc
    M vendor/gtest/test/gtest-typed-test_test.h
    M vendor/gtest/test/gtest-unittest-api_test.cc
    M vendor/gtest/test/gtest_all_test.cc
    A vendor/gtest/test/gtest_assert_by_exception_test.cc
    R vendor/gtest/test/gtest_break_on_failure_unittest.py
    R vendor/gtest/test/gtest_break_on_failure_unittest_.cc
    R vendor/gtest/test/gtest_catch_exceptions_test.py
    R vendor/gtest/test/gtest_catch_exceptions_test_.cc
    R vendor/gtest/test/gtest_color_test.py
    R vendor/gtest/test/gtest_color_test_.cc
    R vendor/gtest/test/gtest_env_var_test.py
    R vendor/gtest/test/gtest_env_var_test_.cc
    M vendor/gtest/test/gtest_environment_test.cc
    R vendor/gtest/test/gtest_filter_unittest.py
    R vendor/gtest/test/gtest_filter_unittest_.cc
    M vendor/gtest/test/gtest_help_test.py
    M vendor/gtest/test/gtest_help_test_.cc
    A vendor/gtest/test/gtest_json_test_utils.py
    A vendor/gtest/test/gtest_list_output_unittest.py
    A vendor/gtest/test/gtest_list_output_unittest_.cc
    R vendor/gtest/test/gtest_list_tests_unittest.py
    R vendor/gtest/test/gtest_list_tests_unittest_.cc
    M vendor/gtest/test/gtest_main_unittest.cc
    M vendor/gtest/test/gtest_no_test_unittest.cc
    R vendor/gtest/test/gtest_output_test.py
    R vendor/gtest/test/gtest_output_test_.cc
    R vendor/gtest/test/gtest_output_test_golden_lin.txt
    M vendor/gtest/test/gtest_pred_impl_unittest.cc
    M vendor/gtest/test/gtest_premature_exit_test.cc
    M vendor/gtest/test/gtest_prod_test.cc
    M vendor/gtest/test/gtest_repeat_test.cc
    R vendor/gtest/test/gtest_shuffle_test.py
    R vendor/gtest/test/gtest_shuffle_test_.cc
    M vendor/gtest/test/gtest_sole_header_test.cc
    M vendor/gtest/test/gtest_stress_test.cc
    A vendor/gtest/test/gtest_test_macro_stack_footprint_test.cc
    M vendor/gtest/test/gtest_test_utils.py
    A vendor/gtest/test/gtest_testbridge_test.py
    A vendor/gtest/test/gtest_testbridge_test_.cc
    M vendor/gtest/test/gtest_throw_on_failure_ex_test.cc
    R vendor/gtest/test/gtest_throw_on_failure_test.py
    R vendor/gtest/test/gtest_throw_on_failure_test_.cc
    R vendor/gtest/test/gtest_uninitialized_test.py
    R vendor/gtest/test/gtest_uninitialized_test_.cc
    M vendor/gtest/test/gtest_unittest.cc
    M vendor/gtest/test/gtest_xml_outfile1_test_.cc
    M vendor/gtest/test/gtest_xml_outfile2_test_.cc
    M vendor/gtest/test/gtest_xml_outfiles_test.py
    M vendor/gtest/test/gtest_xml_output_unittest.py
    M vendor/gtest/test/gtest_xml_output_unittest_.cc
    M vendor/gtest/test/gtest_xml_test_utils.py
    M vendor/gtest/test/production.cc
    M vendor/gtest/test/production.h
    M vendor/gtest/xcode/Config/DebugProject.xcconfig
    M vendor/gtest/xcode/Config/FrameworkTarget.xcconfig
    M vendor/gtest/xcode/Config/General.xcconfig
    M vendor/gtest/xcode/Config/ReleaseProject.xcconfig
    M vendor/gtest/xcode/Config/StaticLibraryTarget.xcconfig
    M vendor/gtest/xcode/Scripts/versiongenerate.py
    M vendor/gtest/xcode/gtest.xcodeproj/project.pbxproj
  Log Message:
  Commit: 056d89273709760238471457fa5b4a1fdf6f79bd
      https://github.com/PDAL/PDAL/commit/056d89273709760238471457fa5b4a1fdf6f79bd
  Author: Connor Manning <connor at hobu.co>
  Date:   2019-06-26 (Wed, 26 Jun 2019)
  Changed paths:
    M io/EptReader.cpp
    M io/EptReader.hpp
    M test/unit/io/EptReaderTest.cpp
  Log Message:
  Add ifdef guards around EPT reader Zstandard code.
Compare: https://github.com/PDAL/PDAL/compare/2eb274f66721%5E...056d89273709
More information about the pdal-commits mailing list
