[pdal-commits] [PDAL/PDAL] 403608: EPT addon dimension writer (#2391)
Andrew Bell
noreply at github.com
Fri Mar 8 11:30:19 PST 2019
Branch: refs/heads/issue-2390
Home: https://github.com/PDAL/PDAL
Commit: 4036086a303dc48aed363d1f8705f84e30d8706d
https://github.com/PDAL/PDAL/commit/4036086a303dc48aed363d1f8705f84e30d8706d
Author: Connor Manning <connor at hobu.co>
Date: 2019-03-07 (Thu, 07 Mar 2019)
Changed paths:
M .gitignore
M doc/stages/readers.ept.rst
A doc/stages/writers.ept_addon.rst
A io/EptAddonWriter.cpp
A io/EptAddonWriter.hpp
M io/EptReader.cpp
M io/EptReader.hpp
M io/private/EptSupport.hpp
M pdal/StageFactory.cpp
M pdal/util/Utils.hpp
M test/unit/CMakeLists.txt
A test/unit/io/EptAddonWriterTest.cpp
Log Message:
Commit: b33d1cd80078222f20cf57a928ddb77a8ba0ae0b
https://github.com/PDAL/PDAL/commit/b33d1cd80078222f20cf57a928ddb77a8ba0ae0b
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2019-03-08 (Fri, 08 Mar 2019)
Changed paths:
M doc/stages/writers.gdal.rst
Log Message:
Improve writers.gdal doc.
Commit: 4ec3d665702c6bec5b35a6ff390386977ac3445d
https://github.com/PDAL/PDAL/commit/4ec3d665702c6bec5b35a6ff390386977ac3445d
Changed paths:
A .clang-format
M .gitignore
M CMakeLists.txt
M CONTRIBUTING.md
M apps/CMakeLists.txt
M appveyor.yml
M cmake/examples/hobu-config.sh
M cmake/gdal.cmake
R cmake/geos.cmake
R cmake/modules/FindGDAL.cmake
R cmake/modules/FindGEOS.cmake
A cmake/modules/FindTileDB.cmake
M cmake/options.cmake
M cmake/python.cmake
A cmake/tiledb.cmake
M doc/development/compilation/dependencies.rst
M doc/development/compilation/windows.rst
M doc/quickstart.rst
M doc/stages/readers.sbet.rst
A doc/stages/readers.tiledb.rst
M doc/stages/writers.sbet.rst
A doc/stages/writers.tiledb.rst
M doc/workshop/docker.rst.save
M doc/workshop/includes/substitutions.rst
M doc/workshop/osgeo4w.rst
M filters/CropFilter.cpp
M filters/HexBinFilter.cpp
M filters/NormalFilter.cpp
M filters/OverlayFilter.cpp
M filters/OverlayFilter.hpp
M filters/SplitterFilter.cpp
M filters/StatsFilter.cpp
M filters/private/Point.cpp
M filters/private/Point.hpp
M io/EptReader.cpp
M io/EptReader.hpp
M io/Ilvis2MetadataReader.cpp
M io/Ilvis2MetadataReader.hpp
M io/SbetCommon.hpp
M io/SbetReader.cpp
M io/SbetReader.hpp
M io/SbetWriter.cpp
M io/SbetWriter.hpp
M pdal/GDALUtils.cpp
M pdal/GDALUtils.hpp
R pdal/GEOSUtils.cpp
R pdal/GEOSUtils.hpp
M pdal/Geometry.cpp
M pdal/Geometry.hpp
M pdal/Polygon.cpp
M pdal/Polygon.hpp
M pdal/Stage.cpp
M pdal/pdal_config.cpp
M plugins/CMakeLists.txt
M plugins/geowave/io/GeoWaveReader.hpp
M plugins/pcl/CMakeLists.txt
M plugins/rdb/CMakeLists.txt
M plugins/sqlite/CMakeLists.txt
A plugins/tiledb/CMakeLists.txt
A plugins/tiledb/io/TileDBReader.cpp
A plugins/tiledb/io/TileDBReader.hpp
A plugins/tiledb/io/TileDBWriter.cpp
A plugins/tiledb/io/TileDBWriter.hpp
A plugins/tiledb/test/TileDBReaderTest.cpp
A plugins/tiledb/test/TileDBWriterTest.cpp
R scripts/appveyor/build.cmd
A scripts/appveyor/conda/build.cmd
A scripts/appveyor/conda/recipe/bld.bat
A scripts/appveyor/conda/recipe/build.sh
A scripts/appveyor/conda/recipe/meta.yaml
A scripts/appveyor/conda/recipe/scripts/activate.bat
A scripts/appveyor/conda/recipe/scripts/activate.sh
A scripts/appveyor/conda/recipe/scripts/deactivate.bat
A scripts/appveyor/conda/recipe/scripts/deactivate.sh
M scripts/appveyor/config.cmd
R scripts/appveyor/install.cmd
R scripts/appveyor/test.cmd
A scripts/appveyor/test/build.cmd
A scripts/appveyor/test/test.cmd
M scripts/conda/osx.sh
M scripts/conda/win64.sh
M scripts/docker/Dockerfile
R scripts/docker/Dockerfile.alpinedeps
M scripts/docker/alpine/Dockerfile.dependencies
R scripts/docker/master/alpine/Dockerfile
R scripts/docker/master/ubuntu/Dockerfile
M scripts/docker/ubuntu/Dockerfile
M scripts/docker/ubuntu/dependencies/Dockerfile
M scripts/linux-install-scripts/packages.sh
M test/data/pipeline/crop_wkt.json.in
A test/data/tiledb/array/__7683a2d8dd0b48ae809dd3f1a9501da4_1549556043355/OffsetTime.tdb
A test/data/tiledb/array/__7683a2d8dd0b48ae809dd3f1a9501da4_1549556043355/__coords.tdb
A test/data/tiledb/array/__7683a2d8dd0b48ae809dd3f1a9501da4_1549556043355/__fragment_metadata.tdb
A test/data/tiledb/array/__array_schema.tdb
A test/data/tiledb/array/__lock.tdb
M test/unit/PolygonTest.cpp
M test/unit/SpatialReferenceTest.cpp
M test/unit/filters/SplitterTest.cpp
M test/unit/io/SbetReaderTest.cpp
Log Message:
Merge remote-tracking branch 'origin/master'
Commit: c9dbb39e5979d8adedaf8ec58f551abf8195b04d
https://github.com/PDAL/PDAL/commit/c9dbb39e5979d8adedaf8ec58f551abf8195b04d
Changed paths:
M doc/pipeline.rst
Log Message:
Correct pipeline doc.
Commit: c42703406cd993b9f30be4398b5c6fff94af7dbd
https://github.com/PDAL/PDAL/commit/c42703406cd993b9f30be4398b5c6fff94af7dbd
Changed paths:
M .gitignore
M doc/pipeline.rst
M io/EptReader.cpp
M io/EptReader.hpp
Log Message:
Merge remote-tracking branch 'origin/master' into issue-2390
Commit: d29135262daa13537e871073b8347a3c1f80cdc8
https://github.com/PDAL/PDAL/commit/d29135262daa13537e871073b8347a3c1f80cdc8
Changed paths:
M plugins/python/filters/PythonFilter.cpp
M plugins/python/plang/Invocation.cpp
Log Message:
Remove debug.
Compare: https://github.com/PDAL/PDAL/compare/713d8d5c0d8f...d29135262daa
More information about the pdal-commits
