[pdal-commits] [PDAL/PDAL] 326eca: Additional updates to e57 support PR #2442. (#2486)
Howard Butler noreply at github.com
Thu May 2 12:31:44 PDT 2019
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 326eca6386d3dda3045149d2c94e351d36ffd5e3
      https://github.com/PDAL/PDAL/commit/326eca6386d3dda3045149d2c94e351d36ffd5e3
  Author: Howard Butler <howard at hobu.co>
  Date:   2019-05-02 (Thu, 02 May 2019)
  Changed paths:
    M cmake/options.cmake
    M plugins/CMakeLists.txt
    A plugins/e57/CMakeLists.txt
    A plugins/e57/io/E57Reader.cpp
    A plugins/e57/io/E57Reader.hpp
    A plugins/e57/io/E57Writer.cpp
    A plugins/e57/io/E57Writer.hpp
    A plugins/e57/io/Scan.cpp
    A plugins/e57/io/Scan.hpp
    A plugins/e57/io/Utils.cpp
    A plugins/e57/io/Utils.hpp
    A plugins/e57/io/Uuid.cpp
    A plugins/e57/io/Uuid.hpp
    A plugins/e57/libE57Format/CHANGELOG.md
    A plugins/e57/libE57Format/CMakeLists.txt
    A plugins/e57/libE57Format/LICENSE.md
    A plugins/e57/libE57Format/README.md
    A plugins/e57/libE57Format/cmake/Modules/CMakeGenerateDocumentation.cmake
    A plugins/e57/libE57Format/cmake/Modules/FindICU.cmake
    A plugins/e57/libE57Format/cmake/Modules/Tags.cmake
    A plugins/e57/libE57Format/cmake/c_flag_overrides.cmake
    A plugins/e57/libE57Format/cmake/cxx_flag_overrides.cmake
    A plugins/e57/libE57Format/contrib/CRCpp/LICENSE
    A plugins/e57/libE57Format/contrib/CRCpp/README.md
    A plugins/e57/libE57Format/contrib/CRCpp/inc/CRC.h
    A plugins/e57/libE57Format/include/E57Exception.h
    A plugins/e57/libE57Format/include/E57Format.h
    A plugins/e57/libE57Format/src/CheckedFile.cpp
    A plugins/e57/libE57Format/src/CheckedFile.h
    A plugins/e57/libE57Format/src/Common.h
    A plugins/e57/libE57Format/src/Decoder.cpp
    A plugins/e57/libE57Format/src/Decoder.h
    A plugins/e57/libE57Format/src/E57Exception.cpp
    A plugins/e57/libE57Format/src/E57Format.cpp
    A plugins/e57/libE57Format/src/E57FormatImpl.cpp
    A plugins/e57/libE57Format/src/E57FormatImpl.h
    A plugins/e57/libE57Format/src/E57Version.h
    A plugins/e57/libE57Format/src/E57XmlParser.cpp
    A plugins/e57/libE57Format/src/E57XmlParser.h
    A plugins/e57/libE57Format/src/Encoder.cpp
    A plugins/e57/libE57Format/src/Encoder.h
    A plugins/e57/libE57Format/src/ImageFileImpl.cpp
    A plugins/e57/libE57Format/src/ImageFileImpl.h
    A plugins/e57/libE57Format/src/NodeImpl.cpp
    A plugins/e57/libE57Format/src/NodeImpl.h
    A plugins/e57/libE57Format/src/Packet.cpp
    A plugins/e57/libE57Format/src/Packet.h
    A plugins/e57/libE57Format/src/SourceDestBufferImpl.cpp
    A plugins/e57/libE57Format/src/SourceDestBufferImpl.h
    A plugins/e57/libE57Format/src/StructureNodeImpl.cpp
    A plugins/e57/libE57Format/src/StructureNodeImpl.h
    A plugins/e57/test/E57ReaderTest.cpp
    A plugins/e57/test/E57UtilsTest.cpp
    A plugins/e57/test/E57UuidTest.cpp
    A plugins/e57/test/E57WriterTest.cpp
    A plugins/e57/test/ScanTest.cpp
    M scripts/ci/script.sh
    A test/data/e57/A4.e57
    A test/data/e57/A4_moved.e57
    A test/data/e57/A_B.e57
    A test/data/e57/A_merged_B.e57
    A test/data/e57/A_moved_B.e57
    A test/data/e57/B2.e57
  Log Message:
* Adding files
* Code fully ported, tests passing
* Adding copyright notice
* Fixing warnings
* File name
* Code cleanup
* Formatting
* Adding e57 tests to travis
* Formating and code style updates
* fix up my conda build script
* set PYTHON_EXECUTABLE
* add python3-dev
* libe57 doens't actually use icu
* libe57 doesn't get to hammer install prefix
* remove debugging cruft
More information about the pdal-commits mailing list
