[pdal-commits] [PDAL/PDAL] 3810e0: Sibling of eead1c1d047364371530323210e882a09a2c7379
Andrew Bell
noreply at github.com
Fri May 3 05:26:03 PDT 2019
Branch: refs/heads/cherry-pick-backport-2489-to-1.9-maintenance-21a5a946-db40-4277-9b85-be6595582bf5
Home: https://github.com/PDAL/PDAL
Commit: 3810e020e5e59b78f5c528a4555bb8dcbefe0938
https://github.com/PDAL/PDAL/commit/3810e020e5e59b78f5c528a4555bb8dcbefe0938
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2019-05-01 (Wed, 01 May 2019)
Changed paths:
M CMakeLists.txt
M RELEASENOTES.txt
M apps/CMakeLists.txt
M apps/pdal.cpp
M cmake/arbiter.cmake
A cmake/json.cmake
A cmake/modules/FindJSONCPP.cmake
R cmake/nlohmann.cmake
R cmake/openssl.cmake
M cmake/python.cmake
M dimbuilder/CMakeLists.txt
M dimbuilder/DimBuilder.cpp
M dimbuilder/DimBuilder.hpp
M doc/development/compilation/unix.rst
M doc/development/compilation/windows.rst
M doc/development/release-notes/1.9.0.md
M doc/pipeline.rst
M doc/quickstart.rst
M doc/references.rst
M doc/stages/filters.colorization.rst
R doc/stages/filters.covariancefeatures.rst
M doc/stages/reader_opts.rst
M doc/stages/readers.bpf.rst
M doc/stages/readers.ept.rst
M doc/stages/readers.faux.rst
M doc/stages/readers.gdal.rst
M doc/stages/readers.geowave.rst
M doc/stages/readers.greyhound.rst
M doc/stages/readers.i3s.rst
M doc/stages/readers.ilvis2.rst
M doc/stages/readers.las.rst
M doc/stages/readers.matlab.rst
M doc/stages/readers.mbio.rst
M doc/stages/readers.mrsid.rst
M doc/stages/readers.nitf.rst
M doc/stages/readers.numpy.rst
M doc/stages/readers.oci.rst
M doc/stages/readers.optech.rst
M doc/stages/readers.pcd.rst
M doc/stages/readers.pgpointcloud.rst
M doc/stages/readers.ply.rst
M doc/stages/readers.pts.rst
M doc/stages/readers.qfit.rst
M doc/stages/readers.rdb.rst
M doc/stages/readers.rxp.rst
M doc/stages/readers.sbet.rst
M doc/stages/readers.slpk.rst
M doc/stages/readers.sqlite.rst
M doc/stages/readers.terrasolid.rst
M doc/stages/readers.text.rst
M doc/stages/readers.tiledb.rst
M doc/stages/readers.tindex.rst
M doc/stages/writers.bpf.rst
M doc/stages/writers.ept_addon.rst
M doc/stages/writers.ply.rst
M doc/tutorial/iowa-entwine.rst
R filters/CovarianceFeaturesFilter.cpp
R filters/CovarianceFeaturesFilter.hpp
M filters/CropFilter.cpp
M filters/InfoFilter.cpp
M filters/InfoFilter.hpp
M filters/MongoExpressionFilter.hpp
M filters/StatsFilter.cpp
M filters/private/mongoexpression/Comparison.cpp
M filters/private/mongoexpression/Comparison.hpp
M filters/private/mongoexpression/Expression.cpp
M filters/private/mongoexpression/Expression.hpp
M filters/private/mongoexpression/Support.hpp
M io/EptAddonWriter.cpp
M io/EptAddonWriter.hpp
M io/EptReader.cpp
M io/EptReader.hpp
M io/GDALWriter.hpp
M io/LasHeader.hpp
M io/LasWriter.cpp
M io/LasWriter.hpp
M io/PlyWriter.cpp
M io/PlyWriter.hpp
M io/private/EptSupport.hpp
M kernels/PipelineKernel.cpp
M kernels/TranslateKernel.cpp
R pdal/Bounds.cpp
R pdal/Bounds.hpp
M pdal/DimUtil.hpp
M pdal/EigenUtils.cpp
M pdal/EigenUtils.hpp
M pdal/GDALUtils.hpp
M pdal/Geometry.hpp
M pdal/KDIndex.hpp
M pdal/Metadata.cpp
M pdal/Metadata.hpp
M pdal/Options.cpp
M pdal/PDALUtils.cpp
M pdal/PDALUtils.hpp
M pdal/PipelineReaderJSON.cpp
M pdal/PipelineReaderJSON.hpp
M pdal/PointView.hpp
M pdal/Polygon.hpp
M pdal/QuadIndex.hpp
M pdal/QuickInfo.hpp
M pdal/StageExtensions.cpp
A pdal/util/Bounds.cpp
A pdal/util/Bounds.hpp
R pdal/util/Box.cpp
R pdal/util/Box.hpp
M pdal/util/CMakeLists.txt
M plugins/greyhound/CMakeLists.txt
M plugins/greyhound/io/GreyhoundCommon.cpp
M plugins/greyhound/io/GreyhoundCommon.hpp
M plugins/greyhound/io/GreyhoundReader.cpp
M plugins/greyhound/io/GreyhoundReader.hpp
M plugins/greyhound/io/GreyhoundWriter.cpp
M plugins/greyhound/io/GreyhoundWriter.hpp
M plugins/greyhound/io/bounds.cpp
M plugins/greyhound/io/bounds.hpp
M plugins/greyhound/io/point.hpp
M plugins/greyhound/test/GreyhoundReaderTest.cpp
M plugins/i3s/CMakeLists.txt
M plugins/i3s/io/EsriReader.cpp
M plugins/i3s/io/EsriReader.hpp
M plugins/i3s/io/EsriUtil.hpp
M plugins/i3s/io/I3SReader.cpp
M plugins/i3s/io/I3SReader.hpp
M plugins/i3s/io/SlpkReader.cpp
M plugins/i3s/io/SlpkReader.hpp
M plugins/matlab/CMakeLists.txt
M plugins/mrsid/CMakeLists.txt
M plugins/mrsid/io/MrsidReader.cpp
M plugins/mrsid/io/MrsidReader.hpp
M plugins/nitf/CMakeLists.txt
M plugins/nitf/io/NitfFileWriter.hpp
M plugins/pcl/CMakeLists.txt
M plugins/pcl/pipeline/PCLPipeline.h
M plugins/pcl/pipeline/PCLPipeline.hpp
M plugins/python/filters/CMakeLists.txt
M plugins/python/filters/PythonFilter.hpp
M plugins/rdb/CMakeLists.txt
M plugins/rdb/io/RdbPointcloud.cpp
M plugins/rdb/io/RdbReader.cpp
M scripts/appveyor/conda/recipe/meta.yaml
M scripts/appveyor/test/build.cmd
R scripts/conda/osx-setup.sh
M scripts/conda/osx.sh
R scripts/conda/win64-setup.bat
R scripts/conda/win64.bat
A scripts/conda/win64.sh
M scripts/docker/Dockerfile
M scripts/docker/centos/Dockerfile
M scripts/docker/ubuntu/Dockerfile
M scripts/docker/ubuntu/dependencies/Dockerfile
M scripts/linux-install-scripts/packages.sh
M scripts/linux-install-scripts/pdal.sh
M test/data/ply/issue_2421.ply
R test/data/ply/sized_dims.ply
R test/data/ply/unsized_dims.ply
M test/unit/BoundsTest.cpp
M test/unit/CMakeLists.txt
M test/unit/OptionsTest.cpp
M test/unit/ProgramArgsTest.cpp
M test/unit/Support.hpp
M test/unit/apps/pcpipelineTestJSON.cpp
R test/unit/filters/CovarianceFeaturesTest.cpp
M test/unit/filters/MongoExpressionFilterTest.cpp
M test/unit/io/EptAddonWriterTest.cpp
M test/unit/io/PlyWriterTest.cpp
M tools/lasdump/Header.hpp
M vendor/arbiter/CMakeLists.txt
M vendor/arbiter/arbiter.cpp
M vendor/arbiter/arbiter.hpp
A vendor/jsoncpp/dist/CMakeLists.txt
A vendor/jsoncpp/dist/json/forwards.h
A vendor/jsoncpp/dist/json/json.h
A vendor/jsoncpp/dist/jsoncpp.cpp
R vendor/nlohmann/nlohmann/json.hpp
Log Message:
More information about the pdal-commits
