[pdal-commits] [PDAL/PDAL] d19d43: Add warnings/errors for bad return information in ...
chambbj
noreply at github.com
Tue May 7 09:06:41 PDT 2019
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: d19d43b769a61f88ee44f12d805e2bdf94fcf534
https://github.com/PDAL/PDAL/commit/d19d43b769a61f88ee44f12d805e2bdf94fcf534
Author: chambbj <brad.chambers at gmail.com>
Date: 2019-05-07 (Tue, 07 May 2019)
Changed paths:
M filters/PMFFilter.cpp
M filters/SMRFilter.cpp
M filters/private/Segmentation.cpp
M test/unit/SegmentationTest.cpp
Log Message:
Add warnings/errors for bad return information in PMF and SMRF (#2417)
* Add initial logic to check for valid return information in SMRF
* clang-format
* Add initial logic to check for valid return information in PMF
* clang-format
* Append the view rather than appending points in loop
* Push logic of possibly empty returns string into segmentReturns
* Add segmentReturns unit tests, does not cover all cases
More information about the pdal-commits
