[pdal-commits] [PDAL/PDAL] 22d7d8: Update ground filtering tutorial
chambbj
noreply at github.com
Wed May 15 07:49:13 PDT 2019
Branch: refs/heads/ground-tutorial-refresh
Home: https://github.com/PDAL/PDAL
Commit: 22d7d82cf0833db75149be6a0190b2c9b43bf9c7
https://github.com/PDAL/PDAL/commit/22d7d82cf0833db75149be6a0190b2c9b43bf9c7
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2019-05-15 (Wed, 15 May 2019)
Changed paths:
R doc/tutorial/pcl_ground/after-front1.png
R doc/tutorial/pcl_ground/after-front2.png
R doc/tutorial/pcl_ground/after-front3.png
R doc/tutorial/pcl_ground/after-top1.png
R doc/tutorial/pcl_ground/after-top2.png
R doc/tutorial/pcl_ground/after-top3.png
A doc/tutorial/pcl_ground/csite-denoised-front.png
A doc/tutorial/pcl_ground/csite-original.png
A doc/tutorial/pcl_ground/csite-pmf-cellsize.png
A doc/tutorial/pcl_ground/csite-pmf-default.png
A doc/tutorial/pcl_ground/csite-pmf-denoise.png
A doc/tutorial/pcl_ground/csite-pmf-front.png
A doc/tutorial/pcl_ground/csite-smrf-cut.png
A doc/tutorial/pcl_ground/csite-smrf-default.png
A doc/tutorial/pcl_ground/csite-smrf-denoise.png
M doc/tutorial/pcl_ground/index.rst
R doc/tutorial/pcl_ground/original.png
A doc/tutorial/pcl_ground/outlier-smrf-range-cut.json
A doc/tutorial/pcl_ground/outlier-smrf-range.json
A doc/tutorial/pcl_ground/smrf-range.json
R doc/tutorial/pcl_ground/sor_pmf.json
R doc/tutorial/pcl_ground/sor_pmf2.json
Log Message:
Commit: 099d7fde0754745b51ffcc33fffc0064c0b0dd29
https://github.com/PDAL/PDAL/commit/099d7fde0754745b51ffcc33fffc0064c0b0dd29
Changed paths:
A doc/tutorial/ground/csite-denoised-front.png
A doc/tutorial/ground/csite-original.png
A doc/tutorial/ground/csite-pmf-cellsize.png
A doc/tutorial/ground/csite-pmf-default.png
A doc/tutorial/ground/csite-pmf-denoise.png
A doc/tutorial/ground/csite-pmf-front.png
A doc/tutorial/ground/csite-smrf-cut.png
A doc/tutorial/ground/csite-smrf-default.png
A doc/tutorial/ground/csite-smrf-denoise.png
A doc/tutorial/ground/index.rst
A doc/tutorial/ground/outlier-smrf-range-cut.json
A doc/tutorial/ground/outlier-smrf-range.json
A doc/tutorial/ground/smrf-range.json
R doc/tutorial/pcl_ground/csite-denoised-front.png
R doc/tutorial/pcl_ground/csite-original.png
R doc/tutorial/pcl_ground/csite-pmf-cellsize.png
R doc/tutorial/pcl_ground/csite-pmf-default.png
R doc/tutorial/pcl_ground/csite-pmf-denoise.png
R doc/tutorial/pcl_ground/csite-pmf-front.png
R doc/tutorial/pcl_ground/csite-smrf-cut.png
R doc/tutorial/pcl_ground/csite-smrf-default.png
R doc/tutorial/pcl_ground/csite-smrf-denoise.png
R doc/tutorial/pcl_ground/index.rst
R doc/tutorial/pcl_ground/outlier-smrf-range-cut.json
R doc/tutorial/pcl_ground/outlier-smrf-range.json
R doc/tutorial/pcl_ground/smrf-range.json
Log Message:
Move the tutorial, no longer PCL
Commit: 0cab15bab3dde83c6e5e4b8eef0ce520cf503f22
https://github.com/PDAL/PDAL/commit/0cab15bab3dde83c6e5e4b8eef0ce520cf503f22
Changed paths:
M doc/tutorial/ground/index.rst
M doc/tutorial/index.rst
Log Message:
Renaming
Commit: 4f8456bd4ccd1402920d04994a6d886ea02f536b
https://github.com/PDAL/PDAL/commit/4f8456bd4ccd1402920d04994a6d886ea02f536b
Changed paths:
M doc/project/contributors.rst
M doc/stages/filters.hag.rst
M doc/tutorial/pcl_block_tutorial.rst
M doc/workshop/exercises/analysis/ground/ground.rst
Log Message:
More refs to pcl_ground changed to ground
Compare: https://github.com/PDAL/PDAL/compare/a4f968c0b9be...4f8456bd4ccd
More information about the pdal-commits
