[pdal-commits] [PDAL/PDAL] b88c03: Fix the broken Conda links (#2514)
Andrew Bell noreply at github.com
Fri May 24 10:57:20 PDT 2019
  Branch: refs/heads/projfix
  Home:   https://github.com/PDAL/PDAL
  Commit: b88c0390fcd99a79e002faaa50e692c9a1f21049
      https://github.com/PDAL/PDAL/commit/b88c0390fcd99a79e002faaa50e692c9a1f21049
  Author: chambbj <brad.chambers at gmail.com>
  Date:   2019-05-14 (Tue, 14 May 2019)
  Changed paths:
    M doc/quickstart.rst
  Log Message:
  Commit: f99564b6fb9a4b66b47cd8f301f39bbeb534d92c
      https://github.com/PDAL/PDAL/commit/f99564b6fb9a4b66b47cd8f301f39bbeb534d92c
  Date:   2019-05-15 (Wed, 15 May 2019)
  Changed paths:
    M doc/references.rst
    R doc/stages/filters.mongus.rst
    M doc/stages/filters.rst
    R filters/MongusFilter.cpp
    R filters/MongusFilter.hpp
  Log Message:
  Remove Mongus filter and all references (#2516)
* Remove Mongus filter and all references
* One more Mongus ref to be removed
  Commit: 7f49aaefed883a380b1a0cee8bee8235fd61c94b
      https://github.com/PDAL/PDAL/commit/7f49aaefed883a380b1a0cee8bee8235fd61c94b
  Date:   2019-05-16 (Thu, 16 May 2019)
  Changed paths:
    R doc/stages/filters.kdistance.rst
    R filters/KDistanceFilter.cpp
    R filters/KDistanceFilter.hpp
  Log Message:
  Remove KDistance filter and references, replaced by NNDistance (#2518)
  Commit: 416f99516221925d250956f30e57774b90ef5539
      https://github.com/PDAL/PDAL/commit/416f99516221925d250956f30e57774b90ef5539
  Changed paths:
    M filters/ApproximateCoplanarFilter.cpp
    M filters/CovarianceFeaturesFilter.cpp
    M filters/EigenvaluesFilter.cpp
    M filters/GreedyProjection.cpp
    M filters/NormalFilter.cpp
    M pdal/EigenUtils.cpp
    M pdal/EigenUtils.hpp
  Log Message:
  Shift to using double precision Eigen vectors and matrices (#2519)
  Commit: 305f56c9fc5bf3b037693f450ba1d72aaf135e24
      https://github.com/PDAL/PDAL/commit/305f56c9fc5bf3b037693f450ba1d72aaf135e24
  Changed paths:
  Log Message:
  Add covariancefeatures to the main filters documentation (#2517)
  Commit: 31e5cca10d7fae909b5cfd93adac15bfafd4a04c
      https://github.com/PDAL/PDAL/commit/31e5cca10d7fae909b5cfd93adac15bfafd4a04c
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2019-05-24 (Fri, 24 May 2019)
  Changed paths:
    M io/LasReader.cpp
    M io/LasWriter.cpp
    M test/unit/io/LasReaderTest.cpp
    M test/unit/io/LasWriterTest.cpp
  Log Message:
  Read data from the metadata child "data" rather than the VLR node's data
for forwarded VLRs.
  Commit: 13588c7bd335ebfd7afdb75546cd72803d0f8c7c
      https://github.com/PDAL/PDAL/commit/13588c7bd335ebfd7afdb75546cd72803d0f8c7c
  Changed paths:
    M io/LasReader.cpp
    M io/LasWriter.cpp
  Log Message:
  Merge branch 'issue-2542' into projfix
  Commit: c29de76d527c6c264420b4a0602f99a45c71debf
      https://github.com/PDAL/PDAL/commit/c29de76d527c6c264420b4a0602f99a45c71debf
  Changed paths:
    M test/data/las/lots_of_vlr.las
  Log Message:
  Add test LAS file with valid WKT.
Compare: https://github.com/PDAL/PDAL/compare/d9f6e89c08d9...c29de76d527c
More information about the pdal-commits mailing list
