[pdal-commits] [PDAL/PDAL] ce878a: Fix statistics (#2793)
Andrew Bell
noreply at github.com
Mon Nov 4 06:19:56 PST 2019
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: ce878aa29a85cb698fe56a2f9efdcde981c5e4d1
https://github.com/PDAL/PDAL/commit/ce878aa29a85cb698fe56a2f9efdcde981c5e4d1
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2019-11-04 (Mon, 04 Nov 2019)
Changed paths:
M doc/stages/filters.stats.rst
M filters/ColorinterpFilter.cpp
M filters/StatsFilter.cpp
M filters/StatsFilter.hpp
M test/unit/apps/InfoTest.cpp
M test/unit/filters/ColorinterpFilterTest.cpp
M test/unit/filters/StatsFilterTest.cpp
Log Message:
* Fixed normal dimension names (#2723)
* Check if inView is empty before setting m_size (#2727)
* return input PointView in the PointViewSet
* Fix stat calculations.
Add both sample and population statistics and excess kurtosis.
Clarify what we report in docs.
* Fix tests for stats fixes.
* Make baseline test.
Make stat names explicit.
Have stat baseline names return the sample statistics.
More information about the pdal-commits
