[pdal-commits] [PDAL/PDAL] 531b21: Support filtering EPT by OGR datasources (#2771)
Howard Butler
noreply at github.com
Mon Oct 7 09:28:39 PDT 2019
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 531b21c614139495d4f1b62e90322b724a5f80df
https://github.com/PDAL/PDAL/commit/531b21c614139495d4f1b62e90322b724a5f80df
Author: Howard Butler <howard at hobu.co>
Date: 2019-10-07 (Mon, 07 Oct 2019)
Changed paths:
M io/EptReader.cpp
M pdal/GDALUtils.cpp
M pdal/GDALUtils.hpp
M pdal/Geometry.hpp
M pdal/Polygon.cpp
M pdal/SpatialReference.hpp
M scripts/conda/osx.sh
A test/data/autzen/autzen-attribute-cropped.las
M test/data/ept/1.2-with-color/ept.json
M test/unit/io/EptReaderTest.cpp
Log Message:
* initial implementation of OGR filtering with an 'ogr' json block for readers.ept
* remove lint
* remove more lint
* Make EPT streaming occur asynchronously with a lookahead buffer of nodes.
* Handle zero-point overlaps in streaming EPT reader, for when octree bounds overlap a query but no contained points overlap.
* Respect the threads option for EPT reader streaming.
* hammer CFLAGS and CXXFLAGS due to conda injecting them
* support driver specification and openoptions
* Update EPT streaming test, correct usage of the output point layout.
* Remove constness changes unrelated to EPT streaming for PR.
* simplify filtering with OGR
* initialize m_queryGrids in initialize()
* add test of OGR filtering
* clean up ctors that are not needed
More information about the pdal-commits
