[pdal-commits] [PDAL/PDAL] d21e66: AzP initial setup (#2568)
Howard Butler
noreply at github.com
Thu Sep 5 08:41:49 PDT 2019
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: d21e663e344bc8bcc0e48da91dcecab910811f01
https://github.com/PDAL/PDAL/commit/d21e663e344bc8bcc0e48da91dcecab910811f01
Author: Howard Butler <howard at hobu.co>
Date: 2019-09-05 (Thu, 05 Sep 2019)
Changed paths:
R appveyor.yml
A azure-pipelines.yml
M cmake/macros.cmake
M cmake/python.cmake
M cmake/win32_compiler_options.cmake
M examples/writing-filter/CMakeLists.txt
M examples/writing-kernel/CMakeLists.txt
M examples/writing-reader/CMakeLists.txt
M examples/writing-writer/CMakeLists.txt
M examples/writing/CMakeLists.txt
M io/PcdReader.cpp
M plugins/i3s/lepcc/CMakeLists.txt
M plugins/i3s/lepcc/src/BitStuffer2.cpp
M plugins/i3s/lepcc/src/ClusterRGB.cpp
M plugins/i3s/lepcc/src/FlagBytes.cpp
M plugins/i3s/lepcc/src/Huffman.cpp
M plugins/i3s/lepcc/src/Intensity.cpp
M plugins/i3s/lepcc/src/LEPCC.cpp
M plugins/nitf/CMakeLists.txt
M plugins/python/test/PythonFilterTest.cpp
M plugins/sqlite/io/SQLiteCommon.cpp
M plugins/sqlite/test/SQLiteTest.cpp
M plugins/tiledb/CMakeLists.txt
A scripts/azp/doc.yml
A scripts/azp/linux.yml
A scripts/azp/osx.yml
A scripts/azp/win.yml
M scripts/docker/ubuntu/Dockerfile
M scripts/docker/ubuntu/dependencies/Dockerfile
M vendor/pdalboost/boost/config/compiler/visualc.hpp
A vendor/pdalboost/boost/exception/all.hpp
M vendor/pdalboost/boost/exception/current_exception_cast.hpp
M vendor/pdalboost/boost/exception/detail/error_info_impl.hpp
M vendor/pdalboost/boost/exception/detail/exception_ptr.hpp
M vendor/pdalboost/boost/exception/detail/is_output_streamable.hpp
M vendor/pdalboost/boost/exception/detail/object_hex_dump.hpp
A vendor/pdalboost/boost/exception/detail/shared_ptr.hpp
M vendor/pdalboost/boost/exception/detail/type_info.hpp
M vendor/pdalboost/boost/exception/diagnostic_information.hpp
A vendor/pdalboost/boost/exception/enable_current_exception.hpp
A vendor/pdalboost/boost/exception/enable_error_info.hpp
A vendor/pdalboost/boost/exception/errinfo_api_function.hpp
A vendor/pdalboost/boost/exception/errinfo_at_line.hpp
A vendor/pdalboost/boost/exception/errinfo_errno.hpp
A vendor/pdalboost/boost/exception/errinfo_file_handle.hpp
A vendor/pdalboost/boost/exception/errinfo_file_name.hpp
A vendor/pdalboost/boost/exception/errinfo_file_open_mode.hpp
A vendor/pdalboost/boost/exception/errinfo_nested_exception.hpp
A vendor/pdalboost/boost/exception/errinfo_type_info_name.hpp
A vendor/pdalboost/boost/exception/error_info.hpp
M vendor/pdalboost/boost/exception/exception.hpp
M vendor/pdalboost/boost/exception/get_error_info.hpp
M vendor/pdalboost/boost/exception/info.hpp
A vendor/pdalboost/boost/exception/info_tuple.hpp
M vendor/pdalboost/boost/exception/to_string.hpp
M vendor/pdalboost/boost/exception/to_string_stub.hpp
M vendor/pdalboost/boost/throw_exception.hpp
Log Message:
* AzP initial setup
[skip ci]
* AzP linux attempt
* shut off
* remove appveyor and travis
* try using ubuntu-dependencies image for now
* win build for azp
* yaml typo
* update gdal to get conda-forge
* update gdal to get conda-forge2
* manual install of pdal deps
* remove manual cmake on win. we have conda's
* whoops
* use msvc
* manual setting of msvc paths
* TR1 namespace warning
* -DWIN32 b/c msvc17 no longer defines it
* try to shut off C4716
* shut off /wd4530
* build verbose
* remove VERBOSE=1
* try latest visualc.hpp
* Boost exception updates.
* Update compiler config.
* Test.
* Test.
* Don't build PCL.
* try win test running
* set PYTHONHOME and PYTHONLIB
* set variables try again
* yml stuff
* use CONDA_PREFIX for PYTHOHHOME
* use CONDA_PREFIX for PYTHOHHOME only on test target
* env instead of variables
* env var setting
* Remove debug.
* linux fixes
* gdal-3.0 build for pdal/ubuntu-dependencies container
* echo env vars
* env var quoting
* win env vars
* verbose doesn't do anything on ninja
* try different PYTHONHOME
* try different PYTHONHOME2
* trigger a build
* trigger linux build
* don't test sqlite major version
* python testing stuff
* install into different dir
* add pdal-config to path
* LD_LIBRARY_PATH for test running
* examples
* point to PDAL_DIR for examples
* fix PDAL_DIR directory
* set PDAL_LIBRARY_DIRS for examples
* missed link directory on example
* osx azp
* yml typo
* more yml typo
* activate pdal for osx
* attempt to fix AzP OSX tests for now
* only log sqlite calls to PDAL logger with PDAL_SQLITE_LOG environment variable set
* pip3/python3
* setup conda compiler for osx
* wipe so_extension for sqlite
* try bumping up win stack size
* shut off sqlite tests for azp osx
* try PDAL_DRIVER_PATH
* linux container adjustment for azp
* azp/linux churn
* azp/linux churn
* shut off sqlite
* try to get output from python filter test failure
* log portable_popen
* set PDAL_PYTHON_LIBRARY
* try different PDAL_PYTHON_LIBRARY
* try to print PDAL_PYTHON_LIBRARY
* reprint PDAL_PYTHON_LIBRARY
* remove PDAL_PYTHON_LIBRARY printing
* Fix Windows tests.
* Fix plugins with updated Log code.
* handle conda/osx situation of static python executable by using PYTHON_LDSHARED information from the python executable we were given
* osx churn
* use Log::makeLog
* Forgtten commit.
* shut off fancy osx linking
* use active pdal/python branch for testing
* osx examples build
* try explicitly setting azp/win python stuff
* set c++11
* argument quoting
* remove PYTHONHOME for win
* PYTHONHOME for win
* fix typo in PYTHONHOME
* is_array for nlohman json test
* fix up RdbReader
* turn down container timeout for linux/azp
* review responses
* win compilation of nitf
* Try turning off some options.
* Eliminate or suppress warnings.
* Get full debug output.
* Build static libs with PIC.
* Remove header to unused pragma stuff.
* Remove unused include.
More information about the pdal-commits
