[pdal-commits] [PDAL/PDAL] 98cda6: Fix typo (#3021)
Andrew Bell noreply at github.com
Tue Apr 14 12:15:35 PDT 2020
  Branch: refs/heads/issue-3019
  Home:   https://github.com/PDAL/PDAL
  Commit: 98cda6455295351fa659d78975dca765efe2777e
      https://github.com/PDAL/PDAL/commit/98cda6455295351fa659d78975dca765efe2777e
  Author: Paul Blottiere <blottiere.paul at gmail.com>
  Date:   2020-04-10 (Fri, 10 Apr 2020)
  Changed paths:
    M filters/NeighborClassifierFilter.cpp
  Log Message:
  Fix typo (#3021)
  Commit: 9927a4b6235e286f87db4c59d52b4a3bdb9a6cc3
      https://github.com/PDAL/PDAL/commit/9927a4b6235e286f87db4c59d52b4a3bdb9a6cc3
  Author: cgodkin <carl at dgi.com>
  Date:   2020-04-13 (Mon, 13 Apr 2020)
  Changed paths:
    M tools/lasdump/Dumper.cpp
  Log Message:
  Modified not to assume std namespace. (#3023)
* Fixed hiding of local variable (principally the warning)
* Proposed fix to Issue #3008
Here's a simple fix to the issue I just opened.
Hope these trivial fixes aren't too annoying but we always compile on Windows with -W4 so I'm going to find things that are technically incorrect but don't affect behavior.  Thanks.
* Update Dumper.cpp not to assume std namespace
If a fix to https://github.com/LASzip/LASzip/issues/69 is applied, then Dumper.cpp won't compile since it inherits "using namespace std" from laszip_api.h.  This commit adds "std::" in three places to avoid the dependency.  (Alternatively, "using namespace std" could be added to the top of this source file.)
* Revert proposed change
https://github.com/PDAL/PDAL/issues/3008
  Commit: 954beaf3e4ff4d614d43674c0872852710983d07
      https://github.com/PDAL/PDAL/commit/954beaf3e4ff4d614d43674c0872852710983d07
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2020-04-14 (Tue, 14 Apr 2020)
  Changed paths:
    R test/data/las/tile/file1.las
    R test/data/las/tile/file2.las
    R test/data/las/tile/file3.las
    A test/data/tile/tile.txt
    M test/unit/CMakeLists.txt
    M test/unit/apps/TileTest.cpp
    M test/unit/io/EptReaderTest.cpp
  Log Message:
  Fix tests to support various reprojection behavior (#3025)
Create data on the fly to support proj 6 + 7.
  Commit: f7d69d0efa5e358e93a56288e7e729a8418b0f4b
      https://github.com/PDAL/PDAL/commit/f7d69d0efa5e358e93a56288e7e729a8418b0f4b
  Changed paths:
    M plugins/matlab/filters/MatlabFilter.cpp
    M plugins/matlab/filters/MatlabFilter.hpp
  Log Message:
  Fix busted code. (#3024)
  Commit: d381da7c2055a29d34aef58cecc19eae9c892cd7
      https://github.com/PDAL/PDAL/commit/d381da7c2055a29d34aef58cecc19eae9c892cd7
  Changed paths:
    M filters/CropFilter.cpp
    M filters/HexBinFilter.cpp
    M filters/OverlayFilter.cpp
    M filters/StatsFilter.cpp
    M io/EptReader.cpp
    M pdal/GDALUtils.cpp
    M pdal/Geometry.cpp
    M pdal/Geometry.hpp
    M pdal/Polygon.cpp
    M pdal/SpatialReference.cpp
    M pdal/SpatialReference.hpp
    M pdal/pdal_types.hpp
    M test/unit/SpatialReferenceTest.cpp
  Log Message:
  Better transform() error handling. (#3026)
* Better transform() error handling.
* Change structure name.
  Commit: b8960d0665f128ee9a80de84449fe2c016dc0a55
      https://github.com/PDAL/PDAL/commit/b8960d0665f128ee9a80de84449fe2c016dc0a55
  Changed paths:
    M io/EptReader.cpp
    M pdal/Geometry.cpp
    M pdal/Geometry.hpp
    M pdal/Polygon.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into issue-3019
Compare: https://github.com/PDAL/PDAL/compare/1fe24959dc16...b8960d0665f1
More information about the pdal-commits mailing list
