[pdal-commits] [PDAL/PDAL] 1652d5: TileDB stats and read split buffers (#3045)
Norman Barker noreply at github.com
Fri Apr 24 12:40:47 PDT 2020
  Branch: refs/heads/2.1-maintenance
  Home:   https://github.com/PDAL/PDAL
  Commit: 1652d5573b5cb6b6e4046c3803b57b2747c8c832
      https://github.com/PDAL/PDAL/commit/1652d5573b5cb6b6e4046c3803b57b2747c8c832
  Author: Norman Barker <norman at tiledb.io>
  Date:   2020-04-24 (Fri, 24 Apr 2020)
  Changed paths:
    M plugins/tiledb/io/TileDBReader.cpp
    M plugins/tiledb/io/TileDBWriter.cpp
    M plugins/tiledb/test/TileDBReaderTest.cpp
    R test/data/tiledb/array/__20c2cf6f2bf546adbc7fe83cb44f180b_1554218258459/OffsetTime.tdb
    R test/data/tiledb/array/__20c2cf6f2bf546adbc7fe83cb44f180b_1554218258459/__coords.tdb
    R test/data/tiledb/array/__20c2cf6f2bf546adbc7fe83cb44f180b_1554218258459/__fragment_metadata.tdb
    R test/data/tiledb/array/__array_schema.tdb
    R test/data/tiledb/array/__lock.tdb
    R test/data/tiledb/array/pdal.json
  Log Message:
* refactor tiledb stats to include opening
* Use split coordinates on read
More information about the pdal-commits mailing list
