[pdal-commits] [PDAL/PDAL] f25e34: I3S streaming support (#3113)
Andrew Bell
noreply at github.com
Tue Aug 4 12:36:02 PDT 2020
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: f25e34d7b1a05497c05ccdb2af4850219d6f6909
https://github.com/PDAL/PDAL/commit/f25e34d7b1a05497c05ccdb2af4850219d6f6909
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2020-08-04 (Tue, 04 Aug 2020)
Changed paths:
M io/EptAddonWriter.cpp
M io/EptAddonWriter.hpp
M io/EptReader.cpp
M io/EptReader.hpp
R io/private/ept/Pool.cpp
R io/private/ept/Pool.hpp
M pdal/private/MathUtils.cpp
M pdal/private/MathUtils.hpp
M pdal/private/SrsTransform.cpp
M pdal/private/SrsTransform.hpp
M pdal/util/CMakeLists.txt
M pdal/util/FileUtils.cpp
A pdal/util/ThreadPool.cpp
A pdal/util/ThreadPool.hpp
M plugins/i3s/CMakeLists.txt
M plugins/i3s/io/EsriReader.cpp
M plugins/i3s/io/EsriReader.hpp
M plugins/i3s/io/EsriUtil.cpp
M plugins/i3s/io/EsriUtil.hpp
M plugins/i3s/io/I3SReader.cpp
M plugins/i3s/io/I3SReader.hpp
A plugins/i3s/io/Obb.cpp
A plugins/i3s/io/Obb.hpp
R plugins/i3s/io/SlpkExtractor.cpp
R plugins/i3s/io/SlpkExtractor.hpp
M plugins/i3s/io/SlpkReader.cpp
M plugins/i3s/io/SlpkReader.hpp
R plugins/i3s/io/pool.hpp
M plugins/i3s/lepcc/src/utl_const_array.h
A plugins/i3s/test/ObbTest.cpp
M plugins/i3s/test/SlpkReaderTest.cpp
M plugins/i3s/test/i3sReaderTest.cpp
Log Message:
* Streaming support.
* Remove unnecessary assignment.
* Esri notemp (#3116)
* Remove SLPKExtractor.
Load data from SLPK without writing to temp space.
* Fix type mismatch for threads.
* Typo #1.
* Move win header.
* Fix Windows min.
* More header.
* Fix CreateFileMapping args.
* PDAL_DLL
* Windows build fixes.
* Formatting.
* Clean up esri build file.
* Obb code.
* Specific OBB Test.
* Better comments and separate test.
* Don't try to filter with invalid OBB.
Filter points based on OBB if it's valid.
* Remove dead bounds boxes.
* Add math function to build for plugin.
* Fix incorrect use of m_pointId.
More information about the pdal-commits
