[pdal-commits] [PDAL/PDAL] 2f3f19: Add OptimalNeighborhoodFilter and refactor Covaria...
Andrew Bell
noreply at github.com
Tue Aug 4 12:40:39 PDT 2020
Branch: refs/heads/issue-1468
Home: https://github.com/PDAL/PDAL
Commit: 2f3f198c5a814edf4b81c414be5b9416e869e602
https://github.com/PDAL/PDAL/commit/2f3f198c5a814edf4b81c414be5b9416e869e602
Author: chambbj <brad.chambers at gmail.com>
Date: 2020-07-28 (Tue, 28 Jul 2020)
Changed paths:
M doc/stages/filters.covariancefeatures.rst
A doc/stages/filters.optimalneighborhood.rst
M doc/stages/filters.rst
M filters/CovarianceFeaturesFilter.cpp
M filters/CovarianceFeaturesFilter.hpp
A filters/OptimalNeighborhoodFilter.cpp
A filters/OptimalNeighborhoodFilter.hpp
M pdal/Dimension.json
M test/unit/filters/CovarianceFeaturesTest.cpp
Log Message:
Add OptimalNeighborhoodFilter and refactor CovarianceFeaturesFilter (#3180)
* Add OptimalNeighborhoodFilter and refactor CovarianceFeaturesFilter
OptimalNeighborhoodFilter reports the pointwise optimal number of
neighbors (OptimalKNN) and corresponding radius (OptimalRadius), based
on Weinmann, et al. The optimal neighborhood size is found by minimizing
the Shannon entropy of normalized eigenvalues (the eigenentropy) while
sweeping a range a candidate k-nearest neighbors.
Weinmann, Martin, et al. "Semantic point cloud interpretation based
on optimal neighborhoods, relevant features and efficient
classifiers." ISPRS Journal of Photogrammetry and Remote Sensing 105
(2015): 286-304.
Augment the original CovarianceFeaturesFilter to add optional
specifiation of additional features derived from covariance matrix.
- Omnivariance
- Sum
- Eigenentropy
- Anisotropy
- Surface variation
- DemantkeVerticality
- Density (requires precomputed OptimalKNN and OptimalRadius)
Any feature_set other than "Dimensionality" will output ALL covariance
features. Alternately, covariance features can be passed as a
comma-separated list to the features argument, allowing explicity
definition of the desired features.
Add flexibility to normalize eigenvalues or to compute the standard
deviation along each dimension by taking the square root of the
eigenvalues. The default behavior (a CHANGE!) is to compute features
using the raw eigenvalues.
Update tests to compute all features, setting mode to "SQRT" in keeping
with original defaults.
* Change CovarianceFeaturesFilter mode from string to enum
* Enums/classes for feature types and feature_sets, error checking
* lint
* Remove cerr
* Doc clarifications
* Fix windows errors
* Response to PR comments
* Missed rename location Sum -> EigenvalueSum
* Update docs and tests
* Clean up behavior of features and feature_set and update docs
* Just hardcode pi
* Update tests to actually compute the features being tested
Commit: d821550663c2ab702d7aef96140c4f7f114a53b1
https://github.com/PDAL/PDAL/commit/d821550663c2ab702d7aef96140c4f7f114a53b1
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2020-07-29 (Wed, 29 Jul 2020)
Changed paths:
M doc/stages/expression.rst
Log Message:
Balance parens.
Commit: 8532000bbc85bbce144d42a76111963da9c634bd
https://github.com/PDAL/PDAL/commit/8532000bbc85bbce144d42a76111963da9c634bd
Date: 2020-08-04 (Tue, 04 Aug 2020)
Changed paths:
M io/private/ept/TileContents.cpp
M pdal/PDALUtils.cpp
M pdal/PDALUtils.hpp
M pdal/PluginDirectory.cpp
M pdal/PluginDirectory.hpp
M pdal/util/FileUtils.cpp
M pdal/util/FileUtils.hpp
M test/unit/PluginManagerTest.cpp
Log Message:
Use library-relative path for plugins. (#3195)
* Add DLL-relative path to search path for plugins.
* Fix plugin dir finding for windows.
* Remove dead tests.
* Fix realpath invocation.
* Debug.
* Remove search path test.
Commit: c0bc29b6c223578e2a096ee6df2d1cc1f1a1c070
https://github.com/PDAL/PDAL/commit/c0bc29b6c223578e2a096ee6df2d1cc1f1a1c070
Changed paths:
Log Message:
Merge remote-tracking branch 'origin/master' into issue-1468
Commit: 48c404f2e8ed72b14ac312dea67260aa5a41fdce
https://github.com/PDAL/PDAL/commit/48c404f2e8ed72b14ac312dea67260aa5a41fdce
Changed paths:
M filters/AssignFilter.cpp
R filters/private/expr/AssignExpression.cpp
R filters/private/expr/AssignExpression.hpp
M filters/private/expr/AssignParser.cpp
M filters/private/expr/AssignParser.hpp
A filters/private/expr/AssignStatement.cpp
A filters/private/expr/AssignStatement.hpp
Log Message:
Change AssignExpression to AssignStatement.
Compare: https://github.com/PDAL/PDAL/compare/731565c9a3c8...48c404f2e8ed
More information about the pdal-commits
