[pdal-commits] [PDAL/PDAL] 36a848: Obj texture fix -- simplified. (#3222)
Ryan Pals
noreply at github.com
Thu Aug 27 13:03:44 PDT 2020
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 36a848813d547c0244804ee2271edc7909407866
https://github.com/PDAL/PDAL/commit/36a848813d547c0244804ee2271edc7909407866
Author: Ryan Pals <ryan at hobu.co>
Date: 2020-08-27 (Thu, 27 Aug 2020)
Changed paths:
M io/ObjReader.cpp
M io/ObjReader.hpp
M pdal/Dimension.json
A test/data/obj/box_texture.obj
A test/data/obj/hyper_box.obj
M test/unit/io/ObjReaderTest.cpp
Log Message:
* Texture 2 element fix
* Allow for 0-3 fields in texture and 3-4 fields in vertex position
* Rename texture dimensions, add W
* Allow all dimensions
* Allow more than 4 fields in vertex specification
* Remove unused
* Copy over tests
* Add W dimension
* Check vertex length
More information about the pdal-commits
