[pdal-commits] [PDAL/PDAL] dd51c4: update windows compilation docs to point to GitHub...
Andrew Bell
noreply at github.com
Mon Dec 14 12:05:07 PST 2020
Branch: refs/heads/issue-3288
Home: https://github.com/PDAL/PDAL
Commit: dd51c47dd9d32498cc78688c5d727ff8bdc4169e
https://github.com/PDAL/PDAL/commit/dd51c47dd9d32498cc78688c5d727ff8bdc4169e
Author: Crghilardi <Crghilardi at yahoo.com>
Date: 2020-11-21 (Sat, 21 Nov 2020)
Changed paths:
M doc/development/compilation/windows.rst
Log Message:
update windows compilation docs to point to GitHub Actions instead of Appveyor.yml (#3290)
Commit: 0f319a51cb3cb67b10328176ebbefcbe6ca4fc9b
https://github.com/PDAL/PDAL/commit/0f319a51cb3cb67b10328176ebbefcbe6ca4fc9b
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2020-11-23 (Mon, 23 Nov 2020)
Changed paths:
M filters/CovarianceFeaturesFilter.cpp
M filters/FaceRasterFilter.cpp
M filters/RelaxationDartThrowing.cpp
M filters/SampleFilter.cpp
M io/GDALWriter.cpp
M io/GltfWriter.cpp
M io/Ilvis2MetadataReader.cpp
M io/LasVLR.cpp
M io/private/ept/EptInfo.cpp
M io/private/ept/Key.hpp
M pdal/Geometry.cpp
M pdal/PointView.hpp
M pdal/Polygon.cpp
M pdal/private/Raster.hpp
M pdal/private/gdal/BaseBand.cpp
M pdal/private/gdal/GDALUtils.cpp
M pdal/private/gdal/Raster.cpp
M pdal/util/FileUtils.hpp
M pdal/util/ThreadPool.cpp
M pdal/util/ThreadPool.hpp
M plugins/pgpointcloud/test/PgpointcloudTest.cpp
M test/unit/filters/NormalFilterTest.cpp
M test/unit/io/EptReaderTest.cpp
Log Message:
Fixes for VS 2019 (#3292)
Commit: 78c0d7f3f313c8be7b32a2d52ab3e553a4a950da
https://github.com/PDAL/PDAL/commit/78c0d7f3f313c8be7b32a2d52ab3e553a4a950da
Changed paths:
M .github/workflows/linux.yml
M io/ObjReader.cpp
M io/ObjReader.hpp
M pdal/util/CMakeLists.txt
M plugins/tiledb/CMakeLists.txt
M plugins/tiledb/io/TileDBReader.cpp
M plugins/tiledb/test/TileDBWriterTest.cpp
M test/unit/io/LasWriterTest.cpp
Log Message:
Misc. Changes To Fix CI and Memory Leaks (#3294)
* Link thread library to pdal_util.
* Remove condition preventing tiledb writer test build on osx.
* See
* See
* Test.
* More test.
* Comment out faux readers.
* Use vector instead of raw buf.
* Fixes.
* Just factory.
* Run all TileDB writer tests for now.
Commit: a5a08a689ce39fdc3e1b674fdfc1b7ed997f88c9
https://github.com/PDAL/PDAL/commit/a5a08a689ce39fdc3e1b674fdfc1b7ed997f88c9
Author: theirix <theirix at gmail.com>
Date: 2020-11-25 (Wed, 25 Nov 2020)
Changed paths:
M filters/private/expr/Lexer.cpp
M pdal/util/Bounds.hpp
Log Message:
Add missing libc includes (#3296)
Commit: f6bb0acf1cce0a5e3a2274480187aaa894f316f5
https://github.com/PDAL/PDAL/commit/f6bb0acf1cce0a5e3a2274480187aaa894f316f5
Author: Stephen Knox <stephenknox73 at gmail.com>
Date: 2020-11-30 (Mon, 30 Nov 2020)
Changed paths:
M doc/stages/writers.ogr.rst
Log Message:
Fix JSON format for example (#3295)
Commit: 2c87bb8ed46bc16c840a95466aa12d7a08346bf9
https://github.com/PDAL/PDAL/commit/2c87bb8ed46bc16c840a95466aa12d7a08346bf9
Author: chambbj <brad.chambers at gmail.com>
Changed paths:
M cmake/options.cmake
M doc/references.rst
A doc/stages/filters.teaser.rst
M plugins/CMakeLists.txt
A plugins/teaser/CMakeLists.txt
A plugins/teaser/filters/TeaserFilter.cpp
A plugins/teaser/filters/TeaserFilter.hpp
A plugins/teaser/filters/registration.h
A plugins/teaser/test/TeaserFilterTest.cpp
Log Message:
Initial commit of TEASER++ (#3265)
* Initial commit of TEASER++
* Addressing PR comments
* Make TEASER work with C++11
Vendor the TEASER registration header from v2.0 release tag,
implementing workaround documented at
https://stackoverflow.com/a/17903225/1620549 to provide
std::make_unique.
Commit: c6abbef2aefa3d73862a227e323d58dbfd98392a
https://github.com/PDAL/PDAL/commit/c6abbef2aefa3d73862a227e323d58dbfd98392a
Changed paths:
M doc/stages/filters.litree.rst
M doc/stages/filters.lof.rst
M filters/ApproximateCoplanarFilter.cpp
M filters/ApproximateCoplanarFilter.hpp
M filters/EigenvaluesFilter.cpp
M filters/EigenvaluesFilter.hpp
M filters/EstimateRankFilter.cpp
M filters/EstimateRankFilter.hpp
M filters/LOFFilter.cpp
M filters/LOFFilter.hpp
M filters/LiTreeFilter.cpp
M filters/LiTreeFilter.hpp
M filters/MiniballFilter.cpp
M filters/MiniballFilter.hpp
M filters/OptimalNeighborhoodFilter.cpp
M filters/OptimalNeighborhoodFilter.hpp
M filters/PlaneFitFilter.cpp
M filters/PlaneFitFilter.hpp
M filters/RadialDensityFilter.cpp
M filters/RadialDensityFilter.hpp
M filters/ReciprocityFilter.cpp
M filters/ReciprocityFilter.hpp
M pdal/Dimension.json
Log Message:
Minor updates to several filters (#3270)
* Minor updates to several filters
Initial focus is on updating static filters to always register official
Dimensions.
* LiTreeFilter now registers existing ClusterID instead of custom
TreeID.
* LOFFilter now registers existing NNDistance instead of custom
KDistance.
* OptimalNeighborhoodFilter now registers existing OptimalRadius and
OptimalKNN.
* Register the following as "official" Dimensions: Coplanar,
Eigenvalue0, Eigenvalue1, Eigenvalue2, LocalOutlierFactor,
LocalReachabilityDistance, Miniball, PlaneFit, RadialDensity, Rank,
Reciprocity
While updating Dimensions, also took the opportunity to:
* Be more explicit about datatypes, instead of relying on auto, to
improve readability.
* Use PointView range-based for loops where it make sense. Generally
makes code a little more succinct.
* Do not pass KDIndex as frequently, when it can typically be grabbed
off the view at no cost.
Commit: 788e130e55c5d50a9efb08e5fb28434a5235cdac
https://github.com/PDAL/PDAL/commit/788e130e55c5d50a9efb08e5fb28434a5235cdac
Changed paths:
A doc/apps/chamfer.rst
A kernels/ChamferKernel.cpp
A kernels/ChamferKernel.hpp
M pdal/PDALUtils.cpp
M pdal/PDALUtils.hpp
M test/unit/CMakeLists.txt
A test/unit/apps/ChamferTest.cpp
Log Message:
Add chamfer distance to PDALUtils and expose via kernel (#3183)
Commit: 5ab42b6d0a9869fdac705169dcea9037a39527d4
https://github.com/PDAL/PDAL/commit/5ab42b6d0a9869fdac705169dcea9037a39527d4
Changed paths:
M scripts/ci/linux/setup.sh
Log Message:
Debugging tiledb failure. (#3300)
Commit: 50fd6cd24a8696b74939139c0dd24306980506e8
https://github.com/PDAL/PDAL/commit/50fd6cd24a8696b74939139c0dd24306980506e8
Author: Matyáš Hollmann <49728202+matyas-hollmann at users.noreply.github.com>
Date: 2020-12-03 (Thu, 03 Dec 2020)
Changed paths:
M pdal/Scaling.cpp
Log Message:
LasWriter: proposed solution to autoscale with autooffset bug (0 variance data) (#3305)
* LasWriter: proposed solution to autoscale with autooffset bug.
* LasWriter: improved precision when using auto-offset
Commit: 585e4cee2837c5a43ad3392e5b5c43257d214189
https://github.com/PDAL/PDAL/commit/585e4cee2837c5a43ad3392e5b5c43257d214189
Author: Howard Butler <howard at hobu.co>
Date: 2020-12-07 (Mon, 07 Dec 2020)
Changed paths:
M .github/workflows/conda.yml
M scripts/ci/conda/compile.sh
M scripts/ci/conda/setup.sh
Log Message:
Use conda-forge pins for Conda package GHA (#3308)
* STANDALONE prefix for building RDB plugin
* use conda-forge pins for package generation
* dont use clone for build
* path
* path again
Commit: d703f7fd2f09335825f02e854994e11765aa6252
https://github.com/PDAL/PDAL/commit/d703f7fd2f09335825f02e854994e11765aa6252
Date: 2020-12-08 (Tue, 08 Dec 2020)
Changed paths:
M doc/apps/pipeline.rst
M doc/apps/translate.rst
M kernels/PipelineKernel.cpp
M kernels/PipelineKernel.hpp
M kernels/TranslateKernel.cpp
M kernels/TranslateKernel.hpp
M pdal/PointLayout.cpp
M pdal/PointLayout.hpp
M test/unit/PointTableTest.cpp
Log Message:
Allow limiting of dimensions. (#3311)
Commit: 504b22b1b228a825a84848b6f25c88128276476a
https://github.com/PDAL/PDAL/commit/504b22b1b228a825a84848b6f25c88128276476a
Author: Connor Manning <connor at hobu.co>
Date: 2020-12-09 (Wed, 09 Dec 2020)
Changed paths:
M io/EptReader.cpp
Log Message:
Fix typo in an EPT reader error message.
Commit: 99c8b49286a25e3517937736877e70f32513eba8
https://github.com/PDAL/PDAL/commit/99c8b49286a25e3517937736877e70f32513eba8
Date: 2020-12-14 (Mon, 14 Dec 2020)
Changed paths:
M io/EptReader.cpp
M io/GDALWriter.cpp
M io/GltfWriter.cpp
M io/LasVLR.cpp
M io/ObjReader.cpp
M io/ObjReader.hpp
M pdal/Geometry.cpp
M pdal/Polygon.cpp
M pdal/Scaling.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into issue-3288
Compare: https://github.com/PDAL/PDAL/compare/4ce1fbd218a4...99c8b49286a2
More information about the pdal-commits
