[pdal-commits] [PDAL/PDAL] afb371: Eigen (#3315)
Andrew Bell noreply at github.com
Tue Dec 15 04:19:32 PST 2020
  Branch: refs/heads/zsmooth
  Home:   https://github.com/PDAL/PDAL
  Commit: afb371eba13950fdf07db1b044d213d98c88504e
      https://github.com/PDAL/PDAL/commit/afb371eba13950fdf07db1b044d213d98c88504e
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2020-12-14 (Mon, 14 Dec 2020)
  Changed paths:
    M test/unit/filters/IcpFilterTest.cpp
    M vendor/eigen/Eigen/Core
    M vendor/eigen/Eigen/Eigenvalues
    M vendor/eigen/Eigen/Geometry
    A vendor/eigen/Eigen/KLUSupport
    M vendor/eigen/Eigen/LU
    M vendor/eigen/Eigen/OrderingMethods
    M vendor/eigen/Eigen/PaStiXSupport
    M vendor/eigen/Eigen/QR
    M vendor/eigen/Eigen/Sparse
    M vendor/eigen/Eigen/SparseCholesky
    M vendor/eigen/Eigen/SparseLU
    M vendor/eigen/Eigen/SparseQR
    M vendor/eigen/Eigen/src/Cholesky/LDLT.h
    M vendor/eigen/Eigen/src/Cholesky/LLT.h
    M vendor/eigen/Eigen/src/CholmodSupport/CholmodSupport.h
    A vendor/eigen/Eigen/src/Core/ArithmeticSequence.h
    M vendor/eigen/Eigen/src/Core/Array.h
    M vendor/eigen/Eigen/src/Core/ArrayBase.h
    M vendor/eigen/Eigen/src/Core/ArrayWrapper.h
    M vendor/eigen/Eigen/src/Core/Assign.h
    M vendor/eigen/Eigen/src/Core/AssignEvaluator.h
    M vendor/eigen/Eigen/src/Core/Assign_MKL.h
    M vendor/eigen/Eigen/src/Core/Block.h
    M vendor/eigen/Eigen/src/Core/BooleanRedux.h
    M vendor/eigen/Eigen/src/Core/CommaInitializer.h
    M vendor/eigen/Eigen/src/Core/CoreEvaluators.h
    M vendor/eigen/Eigen/src/Core/CoreIterators.h
    M vendor/eigen/Eigen/src/Core/CwiseBinaryOp.h
    M vendor/eigen/Eigen/src/Core/CwiseNullaryOp.h
    M vendor/eigen/Eigen/src/Core/CwiseUnaryView.h
    M vendor/eigen/Eigen/src/Core/DenseBase.h
    M vendor/eigen/Eigen/src/Core/DenseCoeffsBase.h
    M vendor/eigen/Eigen/src/Core/DenseStorage.h
    M vendor/eigen/Eigen/src/Core/Diagonal.h
    M vendor/eigen/Eigen/src/Core/DiagonalMatrix.h
    M vendor/eigen/Eigen/src/Core/DiagonalProduct.h
    M vendor/eigen/Eigen/src/Core/Dot.h
    M vendor/eigen/Eigen/src/Core/EigenBase.h
    M vendor/eigen/Eigen/src/Core/Fuzzy.h
    M vendor/eigen/Eigen/src/Core/GeneralProduct.h
    M vendor/eigen/Eigen/src/Core/GenericPacketMath.h
    M vendor/eigen/Eigen/src/Core/GlobalFunctions.h
    M vendor/eigen/Eigen/src/Core/IO.h
    A vendor/eigen/Eigen/src/Core/IndexedView.h
    M vendor/eigen/Eigen/src/Core/Inverse.h
    M vendor/eigen/Eigen/src/Core/Map.h
    M vendor/eigen/Eigen/src/Core/MapBase.h
    M vendor/eigen/Eigen/src/Core/MathFunctions.h
    M vendor/eigen/Eigen/src/Core/MathFunctionsImpl.h
    M vendor/eigen/Eigen/src/Core/Matrix.h
    M vendor/eigen/Eigen/src/Core/MatrixBase.h
    M vendor/eigen/Eigen/src/Core/NestByValue.h
    M vendor/eigen/Eigen/src/Core/NoAlias.h
    M vendor/eigen/Eigen/src/Core/NumTraits.h
    A vendor/eigen/Eigen/src/Core/PartialReduxEvaluator.h
    M vendor/eigen/Eigen/src/Core/PermutationMatrix.h
    M vendor/eigen/Eigen/src/Core/PlainObjectBase.h
    M vendor/eigen/Eigen/src/Core/Product.h
    M vendor/eigen/Eigen/src/Core/ProductEvaluators.h
    M vendor/eigen/Eigen/src/Core/Random.h
    M vendor/eigen/Eigen/src/Core/Redux.h
    M vendor/eigen/Eigen/src/Core/Ref.h
    M vendor/eigen/Eigen/src/Core/Replicate.h
    A vendor/eigen/Eigen/src/Core/Reshaped.h
    M vendor/eigen/Eigen/src/Core/ReturnByValue.h
    M vendor/eigen/Eigen/src/Core/Reverse.h
    M vendor/eigen/Eigen/src/Core/Select.h
    M vendor/eigen/Eigen/src/Core/SelfAdjointView.h
    M vendor/eigen/Eigen/src/Core/Solve.h
    M vendor/eigen/Eigen/src/Core/SolveTriangular.h
    M vendor/eigen/Eigen/src/Core/SolverBase.h
    M vendor/eigen/Eigen/src/Core/StableNorm.h
    A vendor/eigen/Eigen/src/Core/StlIterators.h
    M vendor/eigen/Eigen/src/Core/Swap.h
    M vendor/eigen/Eigen/src/Core/Transpose.h
    M vendor/eigen/Eigen/src/Core/Transpositions.h
    M vendor/eigen/Eigen/src/Core/TriangularMatrix.h
    M vendor/eigen/Eigen/src/Core/VectorBlock.h
    M vendor/eigen/Eigen/src/Core/VectorwiseOp.h
    M vendor/eigen/Eigen/src/Core/Visitor.h
    M vendor/eigen/Eigen/src/Core/arch/AVX/Complex.h
    M vendor/eigen/Eigen/src/Core/arch/AVX/MathFunctions.h
    M vendor/eigen/Eigen/src/Core/arch/AVX/PacketMath.h
    M vendor/eigen/Eigen/src/Core/arch/AVX/TypeCasting.h
    A vendor/eigen/Eigen/src/Core/arch/AVX512/Complex.h
    M vendor/eigen/Eigen/src/Core/arch/AVX512/MathFunctions.h
    M vendor/eigen/Eigen/src/Core/arch/AVX512/PacketMath.h
    A vendor/eigen/Eigen/src/Core/arch/AVX512/TypeCasting.h
    M vendor/eigen/Eigen/src/Core/arch/AltiVec/Complex.h
    M vendor/eigen/Eigen/src/Core/arch/AltiVec/MathFunctions.h
    A vendor/eigen/Eigen/src/Core/arch/AltiVec/MatrixProduct.h
    A vendor/eigen/Eigen/src/Core/arch/AltiVec/MatrixProductCommon.h
    A vendor/eigen/Eigen/src/Core/arch/AltiVec/MatrixProductMMA.h
    M vendor/eigen/Eigen/src/Core/arch/AltiVec/PacketMath.h
    M vendor/eigen/Eigen/src/Core/arch/CUDA/Complex.h
    A vendor/eigen/Eigen/src/Core/arch/Default/BFloat16.h
    A vendor/eigen/Eigen/src/Core/arch/Default/GenericPacketMathFunctions.h
    A vendor/eigen/Eigen/src/Core/arch/Default/GenericPacketMathFunctionsFwd.h
    A vendor/eigen/Eigen/src/Core/arch/Default/Half.h
    M vendor/eigen/Eigen/src/Core/arch/Default/Settings.h
    A vendor/eigen/Eigen/src/Core/arch/Default/TypeCasting.h
    A vendor/eigen/Eigen/src/Core/arch/GPU/MathFunctions.h
    A vendor/eigen/Eigen/src/Core/arch/GPU/PacketMath.h
    A vendor/eigen/Eigen/src/Core/arch/GPU/TypeCasting.h
    A vendor/eigen/Eigen/src/Core/arch/HIP/hcc/math_constants.h
    A vendor/eigen/Eigen/src/Core/arch/MSA/Complex.h
    A vendor/eigen/Eigen/src/Core/arch/MSA/MathFunctions.h
    A vendor/eigen/Eigen/src/Core/arch/MSA/PacketMath.h
    M vendor/eigen/Eigen/src/Core/arch/NEON/Complex.h
    M vendor/eigen/Eigen/src/Core/arch/NEON/MathFunctions.h
    M vendor/eigen/Eigen/src/Core/arch/NEON/PacketMath.h
    A vendor/eigen/Eigen/src/Core/arch/NEON/TypeCasting.h
    M vendor/eigen/Eigen/src/Core/arch/SSE/Complex.h
    M vendor/eigen/Eigen/src/Core/arch/SSE/MathFunctions.h
    M vendor/eigen/Eigen/src/Core/arch/SSE/PacketMath.h
    M vendor/eigen/Eigen/src/Core/arch/SSE/TypeCasting.h
    A vendor/eigen/Eigen/src/Core/arch/SYCL/InteropHeaders.h
    A vendor/eigen/Eigen/src/Core/arch/SYCL/MathFunctions.h
    A vendor/eigen/Eigen/src/Core/arch/SYCL/PacketMath.h
    A vendor/eigen/Eigen/src/Core/arch/SYCL/SyclMemoryModel.h
    A vendor/eigen/Eigen/src/Core/arch/SYCL/TypeCasting.h
    M vendor/eigen/Eigen/src/Core/arch/ZVector/Complex.h
    M vendor/eigen/Eigen/src/Core/arch/ZVector/MathFunctions.h
    M vendor/eigen/Eigen/src/Core/arch/ZVector/PacketMath.h
    M vendor/eigen/Eigen/src/Core/functors/AssignmentFunctors.h
    M vendor/eigen/Eigen/src/Core/functors/BinaryFunctors.h
    M vendor/eigen/Eigen/src/Core/functors/NullaryFunctors.h
    M vendor/eigen/Eigen/src/Core/functors/UnaryFunctors.h
    M vendor/eigen/Eigen/src/Core/products/GeneralBlockPanelKernel.h
    M vendor/eigen/Eigen/src/Core/products/GeneralMatrixMatrix.h
    M vendor/eigen/Eigen/src/Core/products/GeneralMatrixMatrixTriangular.h
    M vendor/eigen/Eigen/src/Core/products/GeneralMatrixMatrixTriangular_BLAS.h
    M vendor/eigen/Eigen/src/Core/products/GeneralMatrixMatrix_BLAS.h
    M vendor/eigen/Eigen/src/Core/products/GeneralMatrixVector.h
    M vendor/eigen/Eigen/src/Core/products/Parallelizer.h
    M vendor/eigen/Eigen/src/Core/products/SelfadjointMatrixMatrix.h
    M vendor/eigen/Eigen/src/Core/products/SelfadjointMatrixMatrix_BLAS.h
    M vendor/eigen/Eigen/src/Core/products/SelfadjointMatrixVector.h
    M vendor/eigen/Eigen/src/Core/products/SelfadjointProduct.h
    M vendor/eigen/Eigen/src/Core/products/SelfadjointRank2Update.h
    M vendor/eigen/Eigen/src/Core/products/TriangularMatrixMatrix.h
    M vendor/eigen/Eigen/src/Core/products/TriangularMatrixMatrix_BLAS.h
    M vendor/eigen/Eigen/src/Core/products/TriangularSolverMatrix.h
    M vendor/eigen/Eigen/src/Core/products/TriangularSolverMatrix_BLAS.h
    M vendor/eigen/Eigen/src/Core/products/TriangularSolverVector.h
    M vendor/eigen/Eigen/src/Core/util/BlasUtil.h
    A vendor/eigen/Eigen/src/Core/util/ConfigureVectorization.h
    M vendor/eigen/Eigen/src/Core/util/Constants.h
    M vendor/eigen/Eigen/src/Core/util/DisableStupidWarnings.h
    M vendor/eigen/Eigen/src/Core/util/ForwardDeclarations.h
    A vendor/eigen/Eigen/src/Core/util/IndexedViewHelper.h
    A vendor/eigen/Eigen/src/Core/util/IntegralConstant.h
    M vendor/eigen/Eigen/src/Core/util/MKL_support.h
    M vendor/eigen/Eigen/src/Core/util/Macros.h
    M vendor/eigen/Eigen/src/Core/util/Memory.h
    M vendor/eigen/Eigen/src/Core/util/Meta.h
    M vendor/eigen/Eigen/src/Core/util/ReenableStupidWarnings.h
    A vendor/eigen/Eigen/src/Core/util/ReshapedHelper.h
    M vendor/eigen/Eigen/src/Core/util/StaticAssert.h
    A vendor/eigen/Eigen/src/Core/util/SymbolicIndex.h
    M vendor/eigen/Eigen/src/Core/util/XprHelper.h
    M vendor/eigen/Eigen/src/Eigenvalues/ComplexEigenSolver.h
    M vendor/eigen/Eigen/src/Eigenvalues/ComplexSchur.h
    M vendor/eigen/Eigen/src/Eigenvalues/EigenSolver.h
    M vendor/eigen/Eigen/src/Eigenvalues/GeneralizedSelfAdjointEigenSolver.h
    M vendor/eigen/Eigen/src/Eigenvalues/HessenbergDecomposition.h
    M vendor/eigen/Eigen/src/Eigenvalues/MatrixBaseEigenvalues.h
    M vendor/eigen/Eigen/src/Eigenvalues/RealQZ.h
    M vendor/eigen/Eigen/src/Eigenvalues/RealSchur.h
    M vendor/eigen/Eigen/src/Eigenvalues/SelfAdjointEigenSolver.h
    M vendor/eigen/Eigen/src/Eigenvalues/Tridiagonalization.h
    M vendor/eigen/Eigen/src/Geometry/AlignedBox.h
    M vendor/eigen/Eigen/src/Geometry/AngleAxis.h
    M vendor/eigen/Eigen/src/Geometry/EulerAngles.h
    M vendor/eigen/Eigen/src/Geometry/Hyperplane.h
    M vendor/eigen/Eigen/src/Geometry/OrthoMethods.h
    M vendor/eigen/Eigen/src/Geometry/ParametrizedLine.h
    M vendor/eigen/Eigen/src/Geometry/Quaternion.h
    M vendor/eigen/Eigen/src/Geometry/Rotation2D.h
    M vendor/eigen/Eigen/src/Geometry/Scaling.h
    M vendor/eigen/Eigen/src/Geometry/Transform.h
    M vendor/eigen/Eigen/src/Geometry/Translation.h
    M vendor/eigen/Eigen/src/Geometry/Umeyama.h
    M vendor/eigen/Eigen/src/Geometry/arch/Geometry_SSE.h
    M vendor/eigen/Eigen/src/Householder/BlockHouseholder.h
    M vendor/eigen/Eigen/src/Householder/Householder.h
    M vendor/eigen/Eigen/src/Householder/HouseholderSequence.h
    M vendor/eigen/Eigen/src/IterativeLinearSolvers/BiCGSTAB.h
    M vendor/eigen/Eigen/src/IterativeLinearSolvers/ConjugateGradient.h
    M vendor/eigen/Eigen/src/IterativeLinearSolvers/IncompleteCholesky.h
    M vendor/eigen/Eigen/src/IterativeLinearSolvers/IterativeSolverBase.h
    M vendor/eigen/Eigen/src/IterativeLinearSolvers/LeastSquareConjugateGradient.h
    M vendor/eigen/Eigen/src/IterativeLinearSolvers/SolveWithGuess.h
    M vendor/eigen/Eigen/src/Jacobi/Jacobi.h
    A vendor/eigen/Eigen/src/KLUSupport/KLUSupport.h
    M vendor/eigen/Eigen/src/LU/Determinant.h
    M vendor/eigen/Eigen/src/LU/FullPivLU.h
    M vendor/eigen/Eigen/src/LU/InverseImpl.h
    M vendor/eigen/Eigen/src/LU/PartialPivLU.h
    A vendor/eigen/Eigen/src/LU/arch/InverseSize4.h
    M vendor/eigen/Eigen/src/OrderingMethods/Amd.h
    M vendor/eigen/Eigen/src/OrderingMethods/Eigen_Colamd.h
    M vendor/eigen/Eigen/src/OrderingMethods/Ordering.h
    M vendor/eigen/Eigen/src/PaStiXSupport/PaStiXSupport.h
    M vendor/eigen/Eigen/src/PardisoSupport/PardisoSupport.h
    M vendor/eigen/Eigen/src/QR/ColPivHouseholderQR.h
    M vendor/eigen/Eigen/src/QR/CompleteOrthogonalDecomposition.h
    M vendor/eigen/Eigen/src/QR/FullPivHouseholderQR.h
    M vendor/eigen/Eigen/src/QR/HouseholderQR.h
    M vendor/eigen/Eigen/src/SPQRSupport/SuiteSparseQRSupport.h
    M vendor/eigen/Eigen/src/SVD/BDCSVD.h
    M vendor/eigen/Eigen/src/SVD/JacobiSVD.h
    M vendor/eigen/Eigen/src/SVD/SVDBase.h
    M vendor/eigen/Eigen/src/SVD/UpperBidiagonalization.h
    M vendor/eigen/Eigen/src/SparseCholesky/SimplicialCholesky.h
    A vendor/eigen/Eigen/src/SparseCholesky/SimplicialCholesky_impl.h
    M vendor/eigen/Eigen/src/SparseCore/AmbiVector.h
    M vendor/eigen/Eigen/src/SparseCore/CompressedStorage.h
    M vendor/eigen/Eigen/src/SparseCore/ConservativeSparseSparseProduct.h
    M vendor/eigen/Eigen/src/SparseCore/SparseAssign.h
    M vendor/eigen/Eigen/src/SparseCore/SparseBlock.h
    M vendor/eigen/Eigen/src/SparseCore/SparseCompressedBase.h
    M vendor/eigen/Eigen/src/SparseCore/SparseCwiseBinaryOp.h
    M vendor/eigen/Eigen/src/SparseCore/SparseCwiseUnaryOp.h
    M vendor/eigen/Eigen/src/SparseCore/SparseDenseProduct.h
    M vendor/eigen/Eigen/src/SparseCore/SparseMatrix.h
    M vendor/eigen/Eigen/src/SparseCore/SparseMatrixBase.h
    M vendor/eigen/Eigen/src/SparseCore/SparseProduct.h
    M vendor/eigen/Eigen/src/SparseCore/SparseRef.h
    M vendor/eigen/Eigen/src/SparseCore/SparseSelfAdjointView.h
    M vendor/eigen/Eigen/src/SparseCore/SparseUtil.h
    M vendor/eigen/Eigen/src/SparseCore/SparseVector.h
    M vendor/eigen/Eigen/src/SparseCore/SparseView.h
    M vendor/eigen/Eigen/src/SparseLU/SparseLU.h
    M vendor/eigen/Eigen/src/SparseLU/SparseLU_Memory.h
    M vendor/eigen/Eigen/src/SparseLU/SparseLU_SupernodalMatrix.h
    M vendor/eigen/Eigen/src/SparseLU/SparseLU_column_dfs.h
    M vendor/eigen/Eigen/src/SparseLU/SparseLU_gemm_kernel.h
    M vendor/eigen/Eigen/src/SparseLU/SparseLU_panel_bmod.h
    M vendor/eigen/Eigen/src/SparseQR/SparseQR.h
    M vendor/eigen/Eigen/src/StlSupport/StdDeque.h
    M vendor/eigen/Eigen/src/StlSupport/StdList.h
    M vendor/eigen/Eigen/src/StlSupport/StdVector.h
    M vendor/eigen/Eigen/src/SuperLUSupport/SuperLUSupport.h
    M vendor/eigen/Eigen/src/UmfPackSupport/UmfPackSupport.h
    M vendor/eigen/Eigen/src/misc/lapacke.h
    M vendor/eigen/Eigen/src/plugins/ArrayCwiseBinaryOps.h
    M vendor/eigen/Eigen/src/plugins/ArrayCwiseUnaryOps.h
    M vendor/eigen/Eigen/src/plugins/BlockMethods.h
    M vendor/eigen/Eigen/src/plugins/CommonCwiseUnaryOps.h
    A vendor/eigen/Eigen/src/plugins/IndexedViewMethods.h
    M vendor/eigen/Eigen/src/plugins/MatrixCwiseUnaryOps.h
    A vendor/eigen/Eigen/src/plugins/ReshapedMethods.h
  Log Message:
  Eigen (#3315)
* Update Eigen.
* Comment out bad initial Xform test.
* Comment out test.
  Commit: cb6e87a916cb5ffb3a7138574841b1c435ebe51e
      https://github.com/PDAL/PDAL/commit/cb6e87a916cb5ffb3a7138574841b1c435ebe51e
  Date:   2020-12-15 (Tue, 15 Dec 2020)
  Changed paths:
  Log Message:
  Merge remote-tracking branch 'origin/master' into zsmooth
  Commit: 212d0b682039a631f41cc5642441fb6b871d81be
      https://github.com/PDAL/PDAL/commit/212d0b682039a631f41cc5642441fb6b871d81be
  Changed paths:
    M doc/stages/filters.zsmooth.rst
  Log Message:
  Improve doc.
Compare: https://github.com/PDAL/PDAL/compare/f1fdd361ff93...212d0b682039
More information about the pdal-commits mailing list
